Question about Microsoft Windows Vista Home Premium Edition for PC
No sound recorder
I have windows vista and I can't find sound recorder. I looked in the start menu under accesories, but I can't find it anywhere.
  • 258 Answers
Located in your windows\system32 directorys file is called SoundRecorder.exe no problem just please vote
Posted on Jun 29, 2009
Testimonial: "I found it on the master user and made a shortcut in mine, so yeah."
  • Microsoft Master
  • 4,806 Answers
You can search for the word 'sound' in the Start Menu search box.
How to record sound
Once you have started Sound Recorder check that your microphone is plugged into the sound card. Also, don't forget to check its sound level in the Volume Mixer. If it is on mute you won't be able to record anything.
When you are ready, click on the Start Recording button. Job done :)
Testimonial: "I found it in the master user, then made a shortcut in my user, so it worked that way..."
    Problem Solver:
  • 12 Answers
I have windows vista and the sound recorder is under accesorys and it has a mic symbol.
Cant record music
You must have mic connected and enable it from sound devices.
Open Sound recorder from Start menu->Accesories
Click on the red button and it should record the music.
Nov 11, 2013 | Computers & Internet
Tip
Where has the run command gone/how to show run command.
In Windows Vista and Windows 7 , the run command is hidden by default. This was probably done to declutter the start menu , but I like having the run command available as it does come in handy for more advanced users.
So , how do I get it back?
Right click anywhere on your startbar and select properties.
Now , under the start menu tab , select customize.
Now , just under the recorded TV section , there is a check box with the run command. Check the box and select okay.
Your run command will now once again feature in your start menu.
Please remember to rate this solution if you found it helpful.
Kind Regards
StephanSA
on Feb 24, 2010 | Computers & Internet
Xitel Inport De luxe with window 7
The directions for using the Xitel Inport Deluxe under Win7 are the same as those for using the device with Vista. The drivers are built into the OS. You will need to set the audio input to the Xitel device. For most installs of Windows 7 (Aero capable), with the Inport Deluxe plugged into a USB port on the computer, click Start > Control Panel > Hardware and Sound. Under the Sound listing, click on Manage Audio Devices. In the Recording tab, right click on Microphone Input and select Disable. Right click on the Line INport and select Enable. Right click again on Line INPort and make this the default device. Click on the Playback tab and right click on Speakers INport and select Disable.
If Aero isn't available, it's Control Panel > Sound.
You can use any recording software that runs under your version of Windows 7. The LP Recorder software manual starts on page 8 of the Xitel Inport Deluxe manual. If you do not have the original disc, LP Recorder is available here: http://www.cfbsoftware.com/lprecorder/lprecorder.aspx . (Audacity, http://audacity.sourceforge.net/ , works much the same way as LP Recorder. However the drop down menus for the source and output are available from the main program with the default toolbars enabled.)
I hope this helps.
Sep 26, 2012 | Televison & Video
Hi. I bought a new Acer computer last spring. I have no difficulties recording sound from the Inet, but if I try to record with a mic, I can hardly hear what I recorded.
Hello, If you're using Windows XP you can go to the small speaker icon in the taskbar and double click on it, coose the menu options and choose Advanced controls, you'll be able to see a button under the MIC slider, click on it and then check Mic boost, click the close button and you're done, please don't hesitate to ask again if you are using vista or windows 7, have a nice day :)
Mar 08, 2011 | Acer (54.AA806.001) Sound Card
Driver usb 2.0
you can download a driver http://download.cnet.com/VIA-USB-2-0-Host-Controller-Driver/3000-2098_4-10163319.html for older computer pre 2000
but to get drivers for 2000 xp vista or windows 7 use the windows update which should be found either in the control panel or the accesories or at the top of your start menu (i use linux thats why im not totally sure)
also how did you lose the 2.0 driver?
Mar 05, 2011 | Computers & Internet
Need drivers for windows 7 for my sony icd p620 cannot find anywhere
This IC Recorder is not compatible with the Windows 7, Vista and Macintosh Operating Systems and at this point of time, there are no Drivers available.
However, you can transfer the files by connecting the Headphone OUT of the IC Recorder to the LINE IN of the Computer. Then, use any Sound Recording Software. You can also use the Sound Recorder Software that is pre installed in the Windows Operating System.
Feb 10, 2010 | Sony ICDP620 Digital Voice Recorder
Microphone Help
Go to your sound properties and make sure it's not muted. Also, the recordind device should be the mic. Then open a recording application and give it a try.
Nov 30, 2009 | Toshiba Satellite PSAG0U-02D00M Notebook
Hypercam 3 will not record sound under Vista.
umm sorry no solution but it is NOT because of vista (i have it and it records fine) hope that narrows the problems down lol (
Nov 29, 2009 | Microsoft Windows Vista Home Premium with...
Acer crystal eye webcam
How to Record Webcam Video with Earlier Versions of Windows Movie Maker If you're still using Windows XP, your Windows Movie Maker version might still support capturing video from a webcam. To do this, go to your WMM Movie Tasks and then select "Capture from Video Device". Select webcam from the list of analog devices. You must also select the video input line you want to use for capturing your webcam video. Then enter a name for your captured video file and the location of the drive where you want to save it. Select your video setting preferences for the video you want to capture. To stop capturing, you can either
choose to stop anywhere during the recording session or indicate a specific time limit before the recording stops.
How to Record Video on Your Webcam with Newer Versions of Windows Movie Maker When we say newer versions, we are referring to Windows Movie Maker version 6 which comes pre-loaded with the Windows Vista system. Since Windows Vista is a pretty advanced OS, we expected the latest version of the WMM to support webcam video capture as well. It's very helpful and economical since it comes packaged with Windows Vista, and you don't have to pay the extra cost just to have that tool.
So, the next question now is, how can you record a webcam video using Windows Movie Maker 6. Actually, like we said - you can't. You won't see the "Start Capture" tool in the File Menu of your latest Windows Movie Maker.
Your best bet is to look for alternative and cheaper software that would help you capture whatever you want to record from your webcam. Or, better yet, use the software that comes with your webcam to capture video and then import it into Windows Movie Maker for editing and enhancements. If your webcam didn't come with video capture software, you're in luck because there are free software appllications available for you to download to do such tasks. You can find a good list of webcam video capturing software from this list:
http://www.sharewareconnection.com/titles/webcam-video.htm
Apr 12, 2009 | Acer Aspire 5315 Notebook
How to restore windows vista side bar
2 solution for this problem
1) start - all programmes - accessories - windows side bar or
open the Start menu and in the search line type this word: sidebar
and hit Enter key
Feb 27, 2008 | Microsoft Windows Vista Ultimate Edition
Microsoft Windows Vista Home Premium Edition for PC Logo
116 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
