Question about GE Kitchen Ranges
Stove burners will not light
Hello, I am trying to find a parts diagram for my kitchen stove, it is a GE XL 44 model # JGBS02 EN4WH I think we need to replace the module (??) for the electric start.
The burners will not light, they no longer have the clicking noise. Would anyone happen to know where I can find a diagram of this stove showing the proper part names and part numbers to order. ? (and ...the least expensive place to order parts from ?? )
Thank you, Penny
I went directly to GE's website and found the diagrams for my stove with the parts listed. Thats what I needed !
Thank you,
Penny
Posted on Jun 30, 2009
I have a GE Profile XL 44 gas range, Model #JGBP79BEA2BB, Serial #RV224810P. The Broiler works, the oven does not. I am fairly certain the problem is the round style oven Igniter. I am trying to verif
What have you got to lose , 25.00-65.00 I would see if the ignitor works . Have someone else turn it on while you watch underneath if it sparks the try to get it closer to burner .
Jan 20, 2015 | GE Kitchen Ranges
GE GAS STOVE XL-44 [?17B034] Oven broiler works; however, lower oven ignites and burner comes on but flame is low and DOES NOT HEAT to selected temperature; e.g. 350 degrees.
The problem is usually the igniter not reaching the correct amp draw .When the igniter does not reach the correct amp draw it may allow the gas valve to partially open or not open at all. The igniters are inexpensive and easy to replace. This video will walk you thru the correct procedure for testing an oven igniter. It may be a different model but the testing will be the same.You can also enter your model # for diagrams and illustrations of your specific model. Not all models are available. All parts come with installation instructions.
Dec 10, 2010 | GE Kitchen Ranges
Can the Ge spectra xl 44 be converted to propane
Yes.You will need to find the conversion kit.Not sure how old the XL44 is.Your local GE apliance parts store may be able to get you the kit.It will require swapping out the orifice on the four burners as well as the stove.Well hope this helps.
Mar 12, 2010 | Kitchen Ranges
Getting to the Pilot
Your model JGBP28DED2WH uses spark ignition on the stove top burners, and a glow bar ignitor, part number WB2X9154 for the oven and broiler. To get to the bake ignitor if oven will not light: Take the racks out of the oven. Remove oven floor by removing two screws at back of oven floor and lifting floor. Remove the square metal flame spreader to get to the burner / ignitor assembly. (note: The ignitor may still glow when you try it, but usually is still the problem)
Feb 22, 2009 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL 44 Kitchen Range
replace the ignighter bar in the lower oven pull the racks out remove the two screws in the oven bottom pemove the panel under that remove the metel flame spredder the ignighter is at the back of the burner bar get your model number and go to appliance parts store for a new one and follow inst even if it glowes doesnt mean its good it should light the oven whithen 30 seconds
May 24, 2008 | GE JGBC20 Gas Kitchen Range
Converting GE XL 44 Gas range from propane to natuiral gas
I needed parts for my GE XL44 propane converted stove. This site was very helpful. I found the part and there is online live help or toll free help. Go to: AppliancePartsPros.com
Thanks,
nnb704
May 23, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Ge spectra gas stove top not lighting
no gas flow sounds like a bad gas regulato on the stove. as for the 5 year old ge profile with ignitors not working, you need a part called a spark modual
Nov 16, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE XL44 and soot from burners
propane burns very dirty.you need to remove the burners and orfices and clean them good with oven cleaner.make sure their rinsed and dried well before installing,this should solve your problem.
Nov 08, 2007 | GE Profile Spectra JGBP90 Gas Kitchen...
GE Spectra XL 44 Self Cleaning
Ray, sometimes the burners get gunked up. Remove the cap and burner and see if the small orifice that is located by the spark electrode is clogged. Clean it out with a paper clip. Make sure the burner cap has good contact with the burner. Catriver..post back.
Dec 06, 2006 | GE Profile Spectra JGBP90 Gas Kitchen...
Open Questions:
Kitchen Ranges Logo
159 people viewed this question
Top Kitchen Ranges Experts
Ismael Rodriguez...
Craig Butler
Craig Butler
Sal De
Are you a Kitchen Range Expert? Answer questions, earn points and help others
