Question about Fisher and Paykel DD605I Dishwasher
F1 code displayed
Dishwasher is displaying F1 code
  • 315 Answers
Power off at the breaker for a few minutes and then back on is usually the way.
BTW that port on the garbgae disposal that the drain line gets hooked onto does not get drilled out. It get knocked out so the entire port hole is open. If you drilled you may not have the hole all the way open. A flat blade screwdriver and a hammer from outseide to inside and when its knocked inside the G/D turn the diposal over and llet the pug fall into your hand.
Posted on Jun 29, 2009
How do I stop the F1 error even after assessing there is no water in the bottom tray and dried it with hair dryer just in case
There should be F1 on both displays. "If power fails to the bottom tub it will cause the top tub to go F1. Test heater plate." (from the service manual).
If there is F1 on both displays it could be a faulty flood switch or PCB.
Jan 30, 2015 | Fisher and Paykel Dishwashers
F1 and beeping
F1 means the drawer lid is not closing properly - (lid seal leaking) which caused water to splash out when you started the wash cycle. The flood circuit on base of dishwasher housing (under the bottom drawer) has tripped. You will have to find the source of leakage and also dry the base of dishwasher housing. Make sure the dishwasher is unplugged form mains socket when you work in it.
Jan 16, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 code
F1 is a flood sensor fault code. The problem sometimes comes from loading the machine above the top of the drawer. When the inside lid comes down before the dishwasher starts, it cannot seal completely and water can spray into the outer cavity. The water accumulates in the inner bottom where there is a sensor. The sensor protects the electronic components from getting wet by warning you of the water which you cannot see. The solution is to remove the bottom drawer and wipe out, then dry the compartment with a fan or a small space heater. Once dry, the machine will function as usual.
Jan 24, 2013 | Fisher DD603FCSS Dishwasher
Eletronic oanel displays F1
The reason for F1 fault code in your dishwasher is due to the flood switch that has been activated in your unit. The best way to solve your problem is to turn off the water supply and power supply to your unit and call an authorized service center. These problems cant be fixed on your own.
Thank you !!
Jun 21, 2010 | Fisher and Paykel DS603SS Stainless Steel...
F1 in F&P 2 drawer dishwasher
You will need to be a bit more specific when you say "no flood".
Are you having this F1 fault in one or both drawers?
What did the engineer do when he was there last time?
Does the F1 code flash with beeps?
What happens when you turn the mains power off and on after a short delay?
Please provide the actual model number of your fisher and paykel 2 drawer dishwasher.
May 19, 2010 | Fisher and Paykel Dishwashers
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
My fisher paykel nautlis dishwaher display error code F1
What is the Model #? If both drawers, if a double, display F1 and won't shut-up then the flood switch is tripped and you have to unplug it to keep it from beeping and the drain motor running. The causes for the F1 fault can be numerous but not excluding bad lid lifts, broken link support, cracked drain line and wrong soap. Call F/P
Jul 19, 2009 | Fisher DS603W / DS603B / DS603I Dishwasher
Fi code washer wont stop beeping
See this site for a full explanation of how to fix this problem, I don't want to type it alll again. F1 error code is 'overfill' most frequently due to a clogged drainhose. If not see here;
http://fixitnow.com/2004/10/appliance-repair-revelation-fisher.htm
May 08, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 Error code on fisher paykel softouch dishwasher
F1 means that water is in your basepan--- you can pull the bottom drawer out and soak up the water with a towel... you will have to use a hair dryer to dry underneath the control sensor in the back left corner.
Apr 11, 2009 | Fisher Dishwashers
Clearing F1 Fault
Hi, Dexters Dad,
I cannot help you without the make and model of your dishwasher. Please provide this by posting a comment here. I should get a email from Fixya telling me you posted the comment. Thankyou and looking forward to helping you get rid of the F1 error code.
Nov 23, 2007 | Dishwashers
Open Questions:
Fisher and Paykel DD605I Dishwasher Logo
97 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
