Question about Refrigerators
I recently bought a norfrost chest freezer model c6aew,the freezer did not come with a manual or guide.i switched on the freezer set the dial to seven and put some food into the freezer to freeze,two days later the food is still not frozen,any thoughts,thanks, al.
fridgetech
  • 473 Answers
SOURCE: food stays frozen regardless of temperature setting
It is possible it has a bad thermostat but most likely cause would be a bad damper motor.  It is the vent inside the fridge that opens and closes, based on temp. setting, to allow cold air from the freezer into the fridge section.
Posted on Oct 14, 2007
Cerfer39
  • 709 Answers
SOURCE: GE Frigerator has intermittant Freezing
It sounds like the defrost heater is burned out. Remove the inside back cover in the freezer to see if the coils are frozen up. If so, more than likely your defrost heater has bit the dust. It is located at the bottom of the inside coil of the freezer.
Also, you could be have a clogged condensor coil. It is located on the out side back of the Fridge. You need to remove the panel from the lower part of the fridge and do a thorugh cleaning.
Posted on Nov 03, 2007
  • 272 Answers
SOURCE: frozen foods collecting ice crystals in my freezer
Your freezer is getting too warm during the defrost cycle, causing condensation in your veggies and eventually freezer burn. Likely your door seals are leaking as well after 17 years which introduces even more humidity into your freezer, but I'm assuming your talking about sealed bags of veggies? You need to decrease the temp in your freezer. Get a thermometer and make sure you average around zero degrees. The cause? When is the last time you cleaned the coils at the back of the fridge. Or if they are sealed, perhaps you need to have it serviced. You can try moving your freezer setting to a colder setting it may take care of the problem.
Posted on May 20, 2009
  • 5 Answers
SOURCE: Freezer not freezing properly, ice on back wall
Ice on the back wall indicates a problem with the defrost cycle. The ice builds up and starts to choke off the air flow, so your symptoms would indicate that may be happening.
Defrost problems are usually any of the three components, the heater element, the defrost termination temp switch, or the defrost timer.
Posted on May 29, 2009
Sea Breeze
  • 4655 Answers
SOURCE: Leaking water inside fridge/freezes the food
Most likely your defrost condensate drain in the rear of your freeze is frozen over. I have put together a long page on the link below. Little too much about leaks in refrigerators and how to solve the problem to fit this page. Choose the part that applies most to your situation and let me know how I may help you resolve yours. I'll be here if you need so click on the link below, Thanks, Sea Breeze
HOW TO FIX A DRAIN LEAK INSIDE REFRIGERATOR AND FREEZER PART 2
Posted on Aug 13, 2009
Have a second hand Homemaker chest freezer model hmbd155....recently noticed fluid around the floor....? Leaking..don't have a manual and noticed a dial on the bottom left hand corner .What this do..?
The dial Adjusts the temperature. If it is adjusted too cold you might have ice build up underneath the freezer thus causing the fluid that you see. As the freezer is old it can also be that the insulation underneath is a bit old causing the ice build up and fluid leakage. A broken thermostat (dial) will also cause too low temperature inside and possible ice build/fluid leakage.
Oct 04, 2017 | Refrigerators
Norfrost c4bew chest freezer
Goggle to find out the company that built it and see if they will send you a copy or if its available for download. This is a common problem with private sales without all the manuals that come with it. Sometimes you have to look up each appliance or model. Start with a phone number to the manufacturer and work from there. Also you can find someone that is selling one like yours and call them to see if they can send you a copy from their manuals.
Oct 16, 2013 | Freezers
Norfrost c6aew chest freezer compressor wiring
What is the make and model of this freezer?
Mar 14, 2013 | Freezers
My norfrost chest freezer hardly opens.until a couple of hours?is there any timing for norfrost chest freezers?
switch of your freezer. and turn it on after half an hour. may be it works.
Dec 13, 2011 | Freezers
I recently bought a norfrost chest freezer model c6aew,the freezer did not come with a manual or guide.i switched on the freezer set the dial to seven waited 24hrs and put some food into the freezer to...
Can't help I'm afraid, but we have exactly the same problem with exactly the same model. Ours did work for nearly 2 years, but recently only works with the boost button pressed in. I suspect the thermostat is not working as the boost button over-rides the thermostat to give max cooling. Your freezer is new so get it exchanged; it certainly doesn't need to be full to work!
May 29, 2010 | Freezers
My Norfrost chest freezer has stopped working will only freeze when the turbo button is switched on. Please help
which means that it is operating manualy...could be the thermostat needs replacing...
Feb 28, 2010 | Freezers
I have a Norfrost 100ltr chest freezer that is defrosting on normal setting but the fast freeze and compressor run when switched on. Any suggestions as to the problem
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Jan 07, 2010 | Freezers
GE 5CF CHEST FREEZER
I got delivery today for the same freezer and had the same question.
I just called GE's customer service number (800-626-2005) and the agent told me that GE uses this button panel (which has the green on/off light switch, the two white switches, and the round control dial) for all or most of its freezers. But the buttons do not do anything on the 5 cubic foot chest freezer. They are not connected to anything and are non-active buttons. On other freezer models above this one, the two switches serve a purpose, but not the 5CF model. This is a simple, inexpensive freezer and it doesn't have bells and whistles--but it does have the same control panel as the multi-feature freezers. Hope that helps.
Sep 05, 2009 | GE 5 cu. ft. / 142 liter Chest Freezer...
Refrigerators Logo
980 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
