Question about RCA Televison & Video
My 52 inch rear projecter rca tv model number r52wh74 picture goes black after a little wile and dont come back for awile staying off longer and longer all the time. but there is sound.
  • 261 Answers
It seems that you have either a defective lamp or ballast, i recommend that you replace the lamp first, if it doesn't work it means that it's most probable that your ballast doesn't have enought voltage to keep up with your lamp. I recommend you get a Philips lamp since it's going to give you a brighter image and also it has a longer life spand 6-8 thousand hours, on the other hand, the generic lamps last 3-6 thousand hours and the image is not that bright, so if you're looking for quality get the Philips.
Posted on Jun 29, 2009
I HAVE A 52 INCH RCA PROJECTION TV THE PICTURE LOOKS LIKE IT IS IN 3D. WHAT CAN I DO?
look carefully on back of set where model number is, is there a chassis number like PTK195?
If there is I can tell you what part is bad.
SD TECH
Dec 07, 2010 | RCA P52926 52" Rear Projection Television
I have a RCA R52WH74. When you turn it on there's
replace the deflection board. You need the ITC222A deflection board PSB-260 you can get a replacement deflection board from www.tvrepairworld.com which also has the CD that shows how to remove the old board.
Apr 11, 2010 | RCA HD52W56 52" Rear Projection HDTV
My 52 inch rca tv power button blinks on and off
my rca tv will not power on power button blinks four times
Aug 17, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA r52wh74 tv powers on then powers right off
one solution to maybe solve the problem of it not staying powered would be to take the panel off the back and use a blow dryer in the lower left hand corner and heat it up. It worked to get our tv turned on.
Jun 13, 2009 | RCA HD52W56 52" Rear Projection HDTV
RCA Model #R52Wh74 HDTV Rear Projection
Do you have the convergence option in the customer setup menu? IF YOU DO NOT consult the tips and tricks section of this website for the article ' "The fl231 fuse problem" If you do then it will need some more trouble shooting
Apr 04, 2009 | RCA P52921 52" Rear Projection Television
RCA 52 inch
three strikes and it's out... rca does this, it is just showing it has tried 3 times for you and untill it is unplugged it won't try again.. you need to provide model #.. could be a few different things
hissing usually meens you have high voltage...that's good but then what don't you have?
ctc 169 - 179 could be high voltage divider... need more info
Oct 17, 2008 | RCA R52WH73 Projection Television
RCA Model # R52WH74
ALL of you have a problem in power supply/deflection board 3 capacitors open located cp150 2200uf 16volt and two 220uf 35 volt, check them first then resolder around FBT other wise order new deflection board 125.00
Jul 02, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
RCA 52-inch (rear projection) big screen television
tv worked great, turned it off one day and back on the next and the on light would not come on nor would the tv work, rear projection 52 inch rca
Jun 18, 2008 | RCA P52926 52" Rear Projection Television
52 inch RCA - green light turns on & off, BUT no picture
CP150 is a capacitor in the power supply circuit....feel top to
see if flat....change if "pooched" or swollen..................T.
Apr 15, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Televison & Video Logo
171 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
