Question about ASUS P5GD1-VM Motherboard
ASUS P5GD1 VM Mboard
All of a sudden the PC that is built on this mboard will not boot normally. It will boot alright to SAFE MODE, but not normal boot.
I have tried to run Norton A/V, Ad-Aware and Spybot, but none of them will finish running before the PC restarts itself and once again fails to boot.
I noticed that when it is attempting to boot it comes up and says IDE 0: Failed to Detect and IDE 1: Failed to Detect. I have checked the connections on both drives, even disconnected and tried to boot that way, but it came up just like it did earlier.
Any suggestions would be appreciated.
  • 1,601 Answers
Check the bios and see if the ide controller is on.
Posted on Nov 09, 2007
I don't have driver asus P4VPMX
hi, hot to determie if my motherboard is broke, if i turn on my pc the only things will appear is the name of the Mboard and didnt finish the loading, can any one help me what is wrong of my cpu, coz i dont know if my Mboard or my vediocard was broked? please anyone help me JFOX
Jan 05, 2011 | ASUS P4VP-MX Motherboard
My computer runs normally.. all of a sudden, my computer stops working. i try to power on the computer. nothing happened as it is dead. i remove the side cover. the green light for the...
Test your PSU or replace it if your power supply units fan is not working your PSU is faulty
One bad lead can cause a computer to continue on a cycle or to shutdown or fail to detect/ boot up
Test all leads that attach to your hard drive including electrical extensions,IDE,SATA
the leads from your ((motherboard to your hard drive)) make sure they have a secure connection and are not faulty or just replace them there probably old and faulty
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
hope this helps
Jan 02, 2011 | ASUS P5GD1-VM Motherboard
Asus p5gd-1vm motherboard no picture on display
in that case start system in safe mode after start safe mode please delet vga drive and then reinstalled it then after its worked.
May 11, 2010 | ASUS P5GD1-VM Motherboard
Problem with ASUS P5GD1 mobo
Try taken the bios battery out for about 30 secs, replace it and then reboot, after post press F8 untill you have a screen pop up with a safe mode option use the arrows keys to navigate to safe mode and press enter. In safe mode goto my conputer c:drive(boot drive) windows. In the windows folder look for a file called prefetch, delete all it contents. Exit out of everything and restart the pc. If same thing happens post back.
Feb 05, 2010 | ASUS P5GD1-VM Motherboard
Not booting up no video
try reinstalling it from your device manager and the wizard program will guide you and make sure you have the disc for the driver youll need it.. thank you for using fixya have a nice day,..
Dec 11, 2008 | Sony VAIO PCV-RS720G (027242658103) PC...
model gfxcel pc133 multimedia audio controller driver
Sep 21, 2008 | ASUS P5S800-VM Motherboard
Hi melnavz,
Hello Mayfield.
Since that your computer is still booting. the processor, memory is good. The only problem you encountered is cannot hold the time when you totally unplug the unit to the wall. iN that case, maybe something wrong with your mboard. maybe there some connection or jumper that was unnoticeally remove which make the battery open circuit. Please refer to the manual of the maboard for some jumper setting.
Mar 14, 2008 | ASUS P5RD1-VM Motherboard
Burnt down printed compartment part
Your mboard is killed.The chipset is the most difficult thing to handle with and if you have change in color in the board (normal color to a black color) its all over. You remove your HDD and get the inside data by fixin on to another machine.
Mar 09, 2008 | ASUS P5P800-VM Motherboard
Installed GeForce 8500 GT PCI-E video card and pc will not turn on
If your mboard has a builtin video card you should configure that b4 u can use that add on card.
1. connect the add on card.
2. connect the monitor to the built in VGA.
3. start system and press "F2 or Delete" to go to bios setup.
4. on bios setup " refer to the manual on installing addon PCI express card".
you find it here:
or enlosed in the board.
After configuring your system restart and unplug in the wall outlet and then connect the monitor in the add on card.
Hope you find in order.
Jan 18, 2008 | ASUS P5GD1-VM Motherboard
No harddisk detection or cdrom
please check the bus whether they r working. if they r working please check the jumper settings in the harddisk and the cdrom. this will solve ur problem
Oct 08, 2007 | ASUS P5GD1-VM Motherboard
ASUS P5GD1-VM Motherboard Logo
103 people viewed this question
Top ASUS Computers & Internet Experts
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
