I Have i Dodge neon and im trying to see if a fuse is bad for the air conditioning system in the car. what do I look for?
  • 6,927 Answers
If the fan inside is running ,it probley needs freon need more info
Posted on Jun 29, 2009
Is there an air filter for the air conditioning unit on a 2005 dodge neon?If so were is it located
Check the owners manual it will show you where its at if it has a cabin air filter .
Sep 30, 2017 | 2005 Dodge Neon
Fix code 1193 on a 2002 dodge neon
Emission system -- Inlet Air Temp. Circuit High
voltage. The sensor is detecting too hi a voltage at the throttle body - could indicate plugged air filter, not enough air getting to engine OR the sensor has gone bad.
Oct 08, 2014 | 2002 Dodge Neon
2000 neon air conditioning electrical problem
You either have a bad refrigerant pressure sensor or a low refrigerant level.
May 30, 2010 | 2000 Dodge Neon
2000 Dodge Neon. When the key is turned into the
it means you have a bad fuse. check or have someone check your fuses to find the bad fuse and replace.
Jan 16, 2010 | 2000 Dodge Neon
Air Conditioning needs recharged
Ok this port for charging in the pipe thicker tries to recharge the system with a UV dye that this is where you said because if you drain your A / C because it has no gas is leaking
Aug 18, 2009 | 2005 Dodge Neon
Dodge Neon 2005) Car will not start.
I was having the same exact problem with my 2005 neon as well. The guy at Discount auto suggested the starter itself was the problem(cost approx $200). The car isn't old enough to be having a starter issue so I figured it was something more simplilar. My dad took a look and founf out it was the starter relay. It is located in the black fuse/relay box on the driver's side right next to the battery. I had to get a new relay at the dealership(cost $20) and my car starts perfectly. Hope this helps
Jun 26, 2009 | 2005 Dodge Neon
2004 dodge neon fuse problem.
yes thats possible, because sometimes like you've explainde some items are on the same fuse, but some items are on the same ground, thus causing something else to appear faulty. so its possible that all of these items are on the same ground and because a fuse or relay for the a/c is faulty, it may cause something else like the dome light and door locks not to work , very crazy with these newer cars.
May 27, 2009 | 2004 Dodge Neon
Air conditioning problem
Go to your fuse box. Look on the lid to see what fuse goes to your A/C or blower. See if they are blown. Look through them to see if there is a burnt spot. thats a good start.
Apr 08, 2009 | 1999 Dodge Neon
The air conditioning quit blowing the front power windows quit working and the air bag light cam on all at once
Check the fuses for each circuit. Fuses may be blown. Cause for a fuse to blow is a short in the circuit. Hope this helps
Jul 30, 2008 | 2000 Dodge Neon
Heating & Cooling Logo
32 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
