Question about Craftsman 4 Cycle Blower/Vac
32 cc blower not starting
I have a 32cc craftsman blower that wont start, i replaced the fuel line because it had disenegrated and cleaned the carb. wont pull gas up the tube to the carb, is this a problem with the pickup in the gas tank or the carb? if i shoot carb cleaner into the carb it will fire but wont stay running. thanks
  • 181 Answers
Your problem is inside the carburator.there is a small screen inside that needs to be cleaned out.take the single screw from one side of carb.there is a small screen in side.carefully take an air hose and blow it out.do not blow to hard or the screen will blow out.once it's clean the unit will start right up.hope this helped,let me know.................................
Posted on Jun 29, 2009
Hello, I have a sears leaf blower 358.794762 that will not start. It's almost like the primer bypasses the carb
Craftsman Leaf Blower Model 358.794762 (358794762) Parts
www.repairclinic.com/.../Model-358794762-Craftsman-Leaf-Blower-Par...
This part fits your Leaf Blower. Husqvarna fuel filter. If the fuel filter is clogged, it willrestrict the flow of fuel to the carburetor. As a result, the engine may not start.
Hello, I have a sears leaf blower 358.794762 that will not ...
Nov 25, 2015 | Sears 25 cc Gas Blower
I have a Craftsman 32cc blower/vac model #358.797251. Replaced fuel lines and primer bulb. Getting fuel but won't start
Check for spark and air filter in good shape. Make sure bulb side gasket is OK! No leaks! Good luck!
Oct 16, 2012 | Garden
I have a craftsman convertiable, 32 cc line trimmer that will not stay started. have tried everything. serial number 9mtds0324sooc
My work and research show that most problems of this type are fuel system related. There is no "miracle" cure to keep the 32cc engine running. Many different things come into play here. The most common problem is dried out parts inside the carburetor. There is a small gasket and diaphragm kit to cure this however.
Your fuel system must be fairly new and with a clean fuel filter inside the fuel tank. The old fuel lines tend to become brittle and flakes of them break off and enter the carb. They get lodged on a very small screen filter that allows fuel to flow thru the carb.If fuel lines are old or brittle, replace them.
Another problem is that the carb has gone "out" of adjustment or never was adjusted correctly in the first place (not uncommon). With new, stringent EPA and CARB laws and regs, the manufacturers of these carbs set them to run very "lean". This means a lot of air and very little fuel. The problem here being that the lubricant for the engine (in this case) is IN the fuel.
Check the condition and color of the spark plug. It will tell you how the engine is performing. Clean the black carbon off of it and reinstall, or just put a new one in.
So brittle fuel lines, old, stale fuel, clogged up screen strainers inside carb, weak spark and misadjusted carbs can ALL contribute to your machine's problem. It is NOT rocket science but some standard diagnostics and testing is required to narrow down exactly what the problem is. Take a look at the things I have mentioned and remember, I have no idea how OLD or in what mechanical condition your machine is (even though I own one just like it). Post back as needed.
Sep 04, 2011 | Craftsman Garden
32 cc craftsman trimmer starts but will not run at full rpm
Air fuel mixture problem,,,you need to have the filter pulled out and cleaned. Check fuel system for debris and clean, that includes all the fuel lines and possibly disassemble carb and clean and reassemble.
Apr 27, 2010 | Craftsman 25cc Gas Line Trimmer
CRAFTMAN LEAF BLOWER WONT START
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Nov 19, 2009 | Craftsman 4 Cycle Blower/Vac
Craftsman 32cc weed eater wont start. Push in the primer bulb and it does not refill, stays stuck in!
Check the fuel lines for cracks/breaks. If they are o.k., then:
You willneed to disassemble the carburetor and spray with carb.cleaner. Makesure the small screen is free of debris.(Should be able to see daylightthrough it.)
Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152),to clean the small portals in carb. These portals can become blocked. Reassemble and start.
If the carb. parts are more than 4 years old, you may have to replace them.
If you need further assistance, just let me know.
Jim
Jun 27, 2009 | Craftsman 25cc Gas Line Trimmer
CRAFTSMAN 32CC/2.1CU.IN 4 CYCLE MODEL 358.796121 WAS WORKING STOPPED AND NOE WON'T START
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen is free of debris.(Should be able to see daylight through it.)
Jim
Jun 25, 2009 | Craftsman 25cc Gas Line Trimmer
Trimmer wont run when i take it off choke
No, it will not. Don't take the fuel mix screws out, it's not necessary.
You will need to disassemble the carburetor and spray with carb.cleaner. Make sure the small screen in the carb. is free of debris. Use a Den Tek Brush, (http://www.drugstore.com/products/prod.asp?pid=165357&catid=1152), to clean the small portals in carb. Reassemble and start.
(NOTE: If the cleaning doesn't work, then buy a carb. kit and replace all appropriate parts.)
Jim
Jun 15, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman 32cc blower stalls
Your carb is leaning out, causing the thing to die. Try adjusting the mixture screw (out) to richen the mixture. If there is a cap, you can pull it off to go richer. If that doesn't work, either the filter/pickup is plugged, the fuel line is kinked/smashed, or the carb needs to come apart to be cleaned.
Jun 10, 2009 | Craftsman 4 Cycle Blower/Vac
CRAFTSMAN LEAFBLOWER TROUBLE
After you do the above, try to clean out the fuel line. It may only be letting in a small amount no matter the throttle control.
Dec 30, 2008 | Craftsman 4 Cycle Blower/Vac
Craftsman 4 Cycle Blower/Vac Logo
1,427 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
