I have a Power Pro self propelled lawn mower that the cogs on the inside of the left front wheel are constantly stripping.I have replaced the wheel three times.The last time I replaced both the wheel and the metal gear that attaches to the drive shaft.Within about a half on hour of mowing most of the plastic cogs inside the wheel are stripped.
We have a riding mower that is a Poulan Pro, that has stopped going forward, it will go in reverse....
(More)
We have a riding mower that is a Poulan Pro, that has stopped going forward, it will go in reverse. What is the problem?
When I try to engage the self propel function on my poulan pro lawnmower, the front wheels lock...
(More)
When I try to engage the self propel function on my poulan pro lawnmower, the front wheels lock instead of engaging, so I must use the mower in push only mode.
I have a poulan pro 24hp model #96012003200, serial #012805b002898, cat# DB24YT RIDDING MOWER. NOT...
(More)
I have a poulan pro 24hp model #96012003200, serial #012805b002898, cat# DB24YT RIDDING MOWER. NOT GETTING FUEL TO THE CARB. FUEL FILTER JUST CHANGED, FUEL LINES CHECKED FOR CLOGS, IF CARB IS PRIMED IT WILL RUN FOR A COUPLE OF SECONDS AND THEN DIE. FUEL PUMP?
Describe your Poulan Pro " Pro" Self Propelled Mower Problem IT gets...
(More)
Describe your Poulan Pro " Pro" Self Propelled Mower Problem IT gets to much gas and turns the plug black
