Question about Sony Cyber-shot DSC-W70 Digital Camera
SHUTS OFF BY ITSELF
I have to keep pressing the on button again and again to get it to turn on. When it DOES turn on, it shuts off by itself. One time I let the battery charging the whole night, does that have anything to do with it?
  • 80 Answers
Yes,, when we charge the battery for a longtime. the battery's will automatically decrease, this is the reason the camera is getting turned off by itself, change your battery to make it work well.,, thank you.. plzzz rate me,,,
Posted on Jun 29, 2009
Shows 99% won't open and can't shut down
You can first try doing what's called doing a Soft Reset. It's the first and preferred method to try as you don't lose any files or settings. Hold the power button until the Nook turns itself off. In most cases that will be twenty seconds or more. Then turn the power back on by holding the power button down for about two seconds. Hopefully this will allow you to complete a normal boot process. The second and more dramatic way to get a working Nook back is what's called doing a Hard Reset. This process will put your Nook back to "Just Out of the Box" mode. You will lose any files and settings stored internally inside the Nook itself. The good part in all this is it won't touch anything stored externally on your external SD Cards. To do a Hard Reset Turn the NOOK off completely. Hold the Power button and Home (n) buttons. The device will turn on. Continue to hold both buttons until the device shuts off once again (~15-20 seconds). Turn the device on normally. It will prompt for a factory reset. Press the Home button twice to confirm. ------- The important part in the above is to be sure you start the Nook via holding down both the power button and the Home (n) buttons at the very same time and keep them both pressed down until the Nook turns itself off.
Mar 07, 2015 | Nook HD+
Tip
Kodak EasyShare Z740 Turns Off Fix Does your Kodak EasyShare Z740 Turns On...
Does your Kodak EasyShare Z740 Turns On Then Turns Off right away?
Does your Kodak EasyShare Z740 Turns Itself Off with new AA batteries in it?
Many of these Kodak EasyShare Z740 cameras that shuts off right away and will not stay on, will actually stay on if you select FAVORITES to view pictures, but just flash back and turn off if set to auto or camera mode. Try this.
If the lens cannot extend, the camera will turn itself off. You can try giving the camera a thump with the heel of your hand, but I would recommend servicing the camera rather than smashing a delicate digital instrument. After trying the steps below, a last chance alternative that works for some people is to grab and actually PULL the lens out as it tries to extend itself. Again, its delicate; if you can afford it, maybe pay for servicing before hitting and pulling on your camera.
However, before servicing your Kodak Z740 try this fix:
  1. Hold down the Time/Ascending Folder button (the button under OK on the circular panel)
  2. While holding that down, press and hold the ON/OFF button.
  3. The camera may turn itself on and stay on this time, acting normally again.
If this doesn't work for your try this:
  1. Hold down the '>' button (the one that brings you to picture review)
If that doesn' t work, try again with the 'Trashcan' button, and ON/OFF button.
I hope that helps.
____________________________________
Kodak EasyShare Z740 Manual Download
on May 01, 2010 | Cameras
Tip
I hope that helps.
on May 01, 2010 | Kodak EasyShare Z740 Digital Camera
My problem with my phone is that everytime I turn it on it just automatically shuts down by itself (without me pressing the TURN OFF/ON button).. Whenever also if it's off, it just turns on by itself.....
hi:) i think your phone software has been crack,mad eit automaticaly on and off. i suggest u do a reload software buy your self or send for nearby mobile shop.
pls voted me if my solution useful,thank..
Aug 02, 2010 | Nokia 6070 Cellular Phone
IPhone 3G shuts off by itself
Try replacing the battery. Also check to make sure that the battery itself is secure and can't move within the phone casing.
Oct 02, 2009 | Apple iPhone 3G
Tv shuts itself down
This is due to bad caps read here what a cap is www.badcaps.net see you tv is getting hot as normal but the caps cannot stand it any more thus shutting the tv down. The bad caps would be more or less in the power supply unit of this TV. So you can buy a new psu or get it repaired by a expert.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
May 25, 2009 | Mitsubishi VS-6055 60" Rear Projection...
Tv turns on but no picture. Then Tv shuts off by itself.
Try turning it on again and quickly press the source button several times until the source menu on the screen appears. Keep trying this method, and if the tv does not do anything then it needs to be serviced. If the tv turns on and functions normally after this wacky method then your power supply is developing a problem....its probably a bad capacitor or TO style diode.
Feb 26, 2009 | HP PL4260N 42 in. Plasma HDTV
Coolpix 775 shuts off all by itself
The auto shut off should be around 30 seconds to allow the built in memory to store everything and rest.If it keeps repeatedly turning off and then on again in a short space of time it will use alot more power from the batteries just Like a car engine uses more petrol stopping at traffic lights. The other factor, I am repeatedly typing on this site is Digital cameras need to run on rechargeable batteries, If you are already using rechargeables,have a look at tha mAh value which should be written on the side. Retailers recomend a value of at least 1800,personally i would go for 2100.
Oct 25, 2008 | Nikon Coolpix 775 Digital Camera
Assistant
check your sleep timer settings thats the most comman prob
Dec 18, 2007 | Philips 27PT81S 27" TV
Sony Cyber-shot DSC-W70 Digital Camera Logo
194 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
