There is an adjustment on your icemaker that controls the amount of water that enters the tray during the fill cycle. Find it and turn it counterclockwise to lessen the water in tray so it does not overflow.
Or, check to make sure that the fill solenoid is shutting down properly (could be sticking)- if not excessive water will enter the tray with same result.
If the icemaker refill solenoid does not close properly or stays open too long excess water enters freezer compartment and that will freeze over the ice making machine plus other areas of freezer. There is an adjustment on the ice maker to regulate the amount of water going in - locate the screw (behind front panel of maker) and turn counter clockwise to lessen time of fill operation). Problem is not with the GE
Refrigerator - Icemaker Not Dispensing,or Not Making Ice
Check that the feeler arm on the icemaker is in the down position and is not blocked.
If the icemaker does not have a feeler arm make sure the icemaker paddle is not blocked under the icemaker.
For more information on the causes of new icemakers not making ice.
For more information on normal ice production.
Side by Side models:
The filter may be loaded with sediment that can cause low water pressure.
The water pressure must be between 40 and 120 psi.
Pressures below 40 psi may cause a malfunction of the icemaker (i.e. producing hollow cubes or no ice production).
Test the water pressure:
Dispense water from the dispenser into a large measuring cup for 20 seconds. If the measuring cup contains less than 13.5 ounces (400 metric centimeters), the water flow is inadequate.
If the amount of water is less than 13.5 ounces then the refrigerator fails the test, remove the filter and test the refrigerator again with the by-pass plug in place.
If the refrigerator dispenses the proper amount of water with the by-pass plug in place, then the filter should be replaced.
If you no longer have the by-pass plug and it has been over three months since the filter has been replaced, you should replace the filter.
If the refrigerator fails the test again and you know you have the proper water pressure in your home, you should call service to check the refrigerator.
If the amount of water collected is over 13.5 ounces then the refrigerator passes the test and the dispenser is working correctly.
Ice not Dispensing Due To Clumping Ice:
Your dispenser may not be dispensing due to clumping ice cubes. The ice cubes in your icemaker may be clumping for a couple of reasons:
Low food load:
The defrost cycle radiates heat into the freezer. The ice in the freezer will naturally absorb the heat. This will cause the ice to melt slightly during defrost, then eventually freeze together in clumps. Increasing the food load in the freezer will buffer the warmth from the defrost cycle and keeps the ice from melting.
Lack of use:
When the ice bin is full, the pressure from the weight of the cubes can cause the bottom cubes to fuse and clump. To prevent this from happening, discard the clumped ice and check the bin periodically to ensure the ice is not building up.
If you do not use a large amount of ice, move the feeler arm on the icemaker to the up position to turn off the icemaker and stop ice production.
For more information on the causes of clumping cubes.
If the ice bucket is not seated correctly, ice will not dispense properly. Make sure the ice bucket is in the correct position. Refer to Use & Care manual.
Could be that the water shut off valve is stay open too long and excess water is not in tray and freezing over. There is an adjustment on the icemaker for the length of time it loads water. Lessen it.
the ice cubes stick together because the water level in the tray is to high and the cubes can not be separated so turn the valve on the wall behind the unit closed some to lessen the amount of water in the tray
What you need is a new ice maker the front gear is not engaging the contacts, you can buy the front module only ( what u put the wire in to on the l & v contact ) but a whole new ice maker assy is the same price.
Is the amount of water to much for the tray size , you can adjust it with the small screw behind the icemaker cover . is the line entering the back of the icemaker jammed up to far causing it to spray ? Or is the icemaker or refrigerator not level
Four things cause icing up:
( 1 ) Is your filter clean? dirty filter blocks air flow causing iceing up. replace filter
( 2 ) Do you hear the Indoor fan running? If the fans not running the unit ices up. Check Capacitor to fan if good.
Bad fan motor... replace fan motor and cap. If both good
( 3 ) Check Air Handler evap coil if dirty and or clogged, restricts air flow causing unit to ice up. Use toilet brush to clean.
This is always a big possibility if you have pets.
( 4 ) If the above are not present then you are low on refrigerant.
Low refrigerant will cause icing up because the gas does not flash properly. This will require a service tech.
refrigerant leaks can be as simple as a loose cap on the king valve, leaking schrader core, to coil leak.
Have the service tech show you the leak. If it is in a copper line it can be fixed. If the system is over 10 years old limit the amount you want to spend. 10 years is the standard life expectantcy anymore. Good luck
** the y do sound directly related. water is dripping down your ice maker falling on to bucket? well a small amount of water is also falling onto the evaporator fan assy, freezing and the **ise you hear is that fan blade "cutting" through the ice.you can lift the arm turning the Ice maker to the off position, itll stop calling for water,and your **ise should stop as well
