Question about Garmin NUVI40LM 4.3" GPS US Mapping Text to Speech, Lifetime Map Updat
Low battery I did not have my Garmin plugged into the cigarette lighter and it told me I had a low battery and shut off. Do I just need to plug it in to the lighter to recharge it or do I have to buy a new battery? If so, where do I find the panel to remove the battery and what kind of battery do I need. Id there an electrical charge cord to charge the battery indoors? I can't find any data with my purchased unit.
    Habit-Forming:
    New Friend:
  • 42 Answers
You need to plug it into to the cigarette lighter or your pc. I take mine in the house and connect it to the pc to charge, but it will charge with the cigarett lighter too.
Posted on Jul 18, 2014
SOURCE:
SOURCE: Not Charging ?
I have the same problem and have read on other web blogs that the battery is dead.  You need to either send it back to garmin for a battery replacement or you need to order a 3.7volt lithium battery online and replace it yourself.  If you replace it yourself you may need to solder the wires.
Thanks
Mark
Posted on Oct 19, 2007
  • 35 Answers
SOURCE: how to recharge the unit
you can charge it via the usb or cigarette lighter.  either method will work and i am not aware of any problems created by using the lighter.  that really should be the primary charge method as it is expected to be used in the car.  is it charging on your computer.  if it is, but not on the lighter you may want to ensure that the lighter is itself working correctly and then also check to make sure that the fuse in the car charger is intact.  just a few suggestions
Posted on Dec 28, 2007
  • 5 Answers
SOURCE: Charging unit with AC adapter
I have a 100v A/C power / charger unit for my garmin C340 GPS that I use to charge my Garmin's battery every day. I can use thj adapter to run the GPS, or just turn it off and let it charge the GPS. But it connects dirctly to the Garmin GPS unit, not to the cradle like the Cigarrette lighter unit does. .
Posted on Apr 08, 2008
Harleyknut
  • 83 Answers
SOURCE: How can I recharge the battery on my Garmin Nuvi?
Just use your USB cable that came with it to connect it to your computer. It will charge just fine. You can also use a cell phone charger that has a USB connector. A lot of cell phones use this type of charger now and the charge will work fine with the GPS>
Posted on Apr 01, 2009
  • 589 Answers
SOURCE: I have purchased a Garmin nuvi 255W from a local
I'm not sure there, but the USB to Mini-usb cord will recharge unit in about 20 minutes
My camera usb cord fit my Nuvi 760 and charges it well,
Posted on Oct 23, 2010
'93 Jeep won't start - used cigarette lighter for gps instead of power socket
Sounds like a bit of a stretch... (nah).
"Lighter" is a GREAT OUTLET...
Has been for decades.
Perhaps it is just time to consider some BATTERY MAINTENANCE... cable and terminal cleaning
or even A REPLACEMENT battery.
I ASSURE you a cigar/cigarette lighter ELEMENT
pulls a lot more power than your Garmin Nuvi 1450LMT.
Get your JEEP battery checked...!!
Carnac the Magnificent
Jan 07, 2018 | Garmin Nuvi 1450LMT
No light on vehicle power cable
If this is a cigarette lighter plug, the fuse may be blown. Unscrew the top where it plugs into the cigarette lighter and check the fuse. But, more than likely the fuse in your car for the cigarette lighter is blown. Check the car fuse first.
Aug 18, 2012 | Garmin nuvi 1490T GPS Receiver
Garmin says low battery and now will not work in the car. Does this Garmin have a battery inside the unit that I have to replace?
There is a battery in the satnav but it's not user replaceable. It can only be replaced by returning it to Garmin. Before sending it away to replace the battery you could check the following;
  • Have you the satnav connected to the charger?
  • If it's connected to the charger is the cigarette lighter socket working. You can check by plugging in another device to see if it works
  • If the cigarette lighter socket is working and the battery of the satnav is not charging it's possible that the fuse in the plug, that goes into the cigarette lighter socket, is blown.
To change the fuse;
Unscrew the ring that's at the end of the plug and the plug comes apart. Be careful not to lose the silver coloured tip. When the plug comes apart you can take out the fuse and get a replacement at any car accessory shop or a shop that sells garmin satnavs.
If you have to return your satnav to garmin you can find their contact details at http://www.garmin.com/garmin/cms/home/support/supportcontact
May 23, 2011 | Garmin nuvi 255W GPS Receiver
When using wire in car, Garmin won't turn on, it starts, shows a low battery sign and shuts down. Was working fine on recent trip. It seems no power is reaching GPS. Nuvi 765T
Most likely the fuse in the charger plug has blown. The plug that goes into the cigarette lighter socket has a ring near the end. On most chargers it's silver but some of them are black. If you unscrew this ring the plug comes apart. Be careful not to lose any parts. You'll see the fuse in there. Replace it and it should be ok.
The other possibility is that the cigarette lighter socket is not working. You can check that easily enough by trying something else in it.
Oct 14, 2010 | Garmin nuvi 765T GPS Receiver
My Garmin nuvi 780 will not turn on. When I turn on, the Garmin logo shows on the screen. However, when "Loading Maps" is displayed, 1-2 seconds later the screen goes blank. This occurs when the unit is...
I had the same problem. When you have your nuvi plugged into your cigarette lighter it doesn't charge. Your battery is probaly near dead. I called Garmin and they told me to plug it into my computer via the usb cable. Turn the Garmin off and let it charge for several hours. That did the trick
Apr 03, 2010 | Garmin nuvi 780 GPS
GARMIN KEEPS SHUTTING OFF
Check the fuse for the cigarette lighter socket. Chech that power is getting to the socket. Try plugging something else into the lighter socket to see if it delivers power.
HTH
Peter
Feb 24, 2009 | Garmin StreetPilot C330 GPS Receiver
WILL NOT CHARGE SAID BATTERY LOW AND WILL NOT CHARGE
I used another charger in house and charged battery must be the car charger adapter I haven't used it yet but I will today and let you know if it works
Jul 24, 2008 | Garmin StreetPilot C330 GPS Receiver
Low Battery
Recharge the battery or plug it into your car cigarette lighter and turn the unit on.
Jan 06, 2008 | Garmin Nuvi 660 GPS Receiver
Garmin NUVI40LM 4.3" GPS US Mapping Text to Speech, Lifetime Map Updat Logo
Top Garmin GPS Experts
Marvin
Marvin
Jean-Luc Steffann
Sheldon Dedek
Are you a Garmin GPS Expert? Answer questions, earn points and help others
