Question about Nokia 1100
Set dead - Nokia 1100
  • 3 Answers
Throw it asol
Posted on Aug 24, 2009
  • rjologs Aug 24, 2009
    throw it asol
How many chain link do I count to set the timing
When you are setting timing you are setting top dead center and bottom dead center. Once established based on the marks on the crank and cam you adjust top dead and BDC by degrees in ADVANCED timing or behind/retarded timing by degrees by counting links. Each link used to be 5 degrees. Check repair manual on link values! they change with each engine and maker.
Sep 04, 2016 | Cars & Trucks
Tip
Need For Speed Shift Keyboard tips
For anyone who uses keyboard in playing NFS Shift try one these settings.
Steering Dead Zone-15%
Accel Dead Zone-10%
Brake Dead Zone-10%
Steering sensitivity-5%
Acell Sensitivity -5%
Brake sensitivity-5%
Speed steering Sensitivity 100%
Steering Dead Zone: 50%
Accelerator Dead Zone: 25%
Brake Dead Zone: 5%
Clutch Dead Zone: 10%
Steering Sensitivity: 100%
Acceleration Sensitivity: 40%
Braking Sensitivity: 50%
Clutch Sensitivity: 40%
Speed Steering Sensitivity: 0%
Inverse Shifting: Off
Camera Y Axis: Normal
AI Difficulty: Medium
Handling Model: Normal
Steering Assist: Low
Braking Assist: Off
Anti-Lcok Brakes: On
Traction Control: Low
Stability Control: On
Damage Effects: Full
Gears: Automatic or Manual
At least anyone can now enjoy the game without having the hassle of wheels and other devices cluttering up their desk.
These settings work well in the new 1.02 Patch hope these helps.
on Dec 15, 2009 | Video Game Consoles & Games
NOKIA 1280 WATER DAMAGE STE DEAD
Aug 14, 2011 | Cell Phones
Need to know where to set low power set up for amp thanks
There is no specific dead key setting for an ampifier. Each amplifier requires different dead key to operate at it peak effeciency AND to sound the best it can. If I knew what type of amp it was I could give you a better idea. Just for a reference point I will give you these numbers. For your basic amplifier ( 2 pill - 4 pill non high-drive) you could safely set the carrier at 1 - 3 watts. This is why the majic number for most people is a 2 watt dead key. For a High-Drive amplifier you really have a broad range of settings for deadkey. Generally anywhere between 2 - 8 watts. Some can even handle 10 watts. This DOES NOT mean that they need a HIGH dead key to operate properly. Just FYI, what you run into with improper dead key is either a really choppy, splattery, overmodulated sound with a deadkey that is to low, OR, a really pinched up, tight sound with a dead key that is to high. Also, a HIGH dead key can cause an amplifier to over heat, causing the transistors (pills) to fail prematurely.
To set your dead key "properly" you really should have a technician "match up" the radio with the amplifier. This means, he will hook up the radio and amp that you plan to use with one another in line and tune (set dead key) the radio to "match" the amp. This will give you the optimal audio and performance without overdriving the amp.
Hope this helped. Lost Jeep, Athens GA, 10-7 !!
Feb 17, 2011 | Connex 3300 240-Channels Base CB Radio
No video or sound set completely dead.
Could just be a dead bulb and dirty cooling fans.
May 19, 2010 | Panasonic PT-50LC14 50" Rear Projection...
CyberPower UPS - unit fan does not work. Is the
It may not be dead yet. Does it supply output? You have not mentioned. It would be considered dead if it does not give any output. Is the battery fine? If the battery is fine and there is no output then it may be dead.
So, check the battery for any sign of life.
Check the output.
Check output with it plugged into mains.
If all are negative then it is dead.
Nov 15, 2009 | CyberPower Computers & Internet
Cell phone dead
check the batteries..charge them and use it..may the battery must be worn out so replace the batteries...or only keypad lights are on and display is off then replace the display..an new display would b around 300 INR.
Apr 10, 2008 | Nokia 3310 Cellular Phone
Lg 5552 v set is dead
try to resolder all points in fbt including fly back trans itself area also resolder the crt pcb area i had the same problem the reason was cold soders also put a good 2sc5297 for hor out.
Dec 02, 2006 | LG Studioworks 552V 15" CRT Monitor
Nokia 1100 Logo
69 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
