Question about Kenmore 72622 Gas Dryer
Flame starts fine, then after first cycle fails to get hot
Same exact problem.
Initial cycle works fine, then after the gas turns off, it never turns back on.
Ignitor get's hot, I hear the click, then nothing.
I suspect the coils also, but wonder why it works the first time.
    President:
  • 744 Answers
You need to relace the saftey valve coils, You can find instructions on this web site. http://www.acmehowto.com/howto/appliance/dryer/gdryer/check/gascoil.php Hope this helps...Please feel free to comment again if you have any questions of concerns. Good luck!
Posted on Jun 29, 2009
  • Mike Price
    Mike Price Jun 29, 2009
    Hi, Basically the coils over time get heat damaged and go bad,initially when the dryer first starts up the coils open the valve, as the dryer heats up the coils expand and then short out. the coils will not open the valve there after until they cool down.
Furnace fails to start, either flame won't ignite right away, or will go out before blower starts.Replaced flame sensor, and it went through cycle 1st time fine, but same problem after that, it won't fire...
sounds like your gas pressure isnt adjusted properly or u have some blocked burners. Too high pressure is just as bad as too low. watch the initial flame, it should just be gently hitting the flame rod sensor.if you own a tester u can test the milliamps reading, that will tell you for sure
Apr 05, 2016 | Heating & Cooling
Gas dryer heating up, then not heating up.
Easy fix. Here is the problem. We know the ignitor is ok because you hear the click. The click is the flame sensor shutting down the ignitor because the temp off of the ignitor is hot enough to bend the bi-metal inside the flame sensor so the flame sensor is also doing it's job. The thermal fuse is fine because power is getting to the gas valve and the control thermostat is also ok because it is supplying power to the gas valve assembly. The only other thing in the circuit is the solenoids. They are know to fail when they get hot after they get a bit of age on them.
Sep 11, 2011 | Maytag Dryers
After the initial startit runs for approx. fiv minutes, than flames is off, after a few minutes ignator goes on but no flame.
The reason your gas heated dryer starts off heating ok,but a part way through the cycle it is no longer heating as it did when it started,is beacuse the coils that open the gas valve are getting hot and breaking down when they are warm. At start up of cycle the coils are cool,but when the dryer heats up as it runs the coils that are weak can not handle the heat and do not open the gas valve. Replacing the gas valve coils with fresh,strong ones will open the gas valve the entire duration of the drying cycle. All appliance manufactures use the same exact gas valve coils and label them with their unique part number. Having been in the service business i know they are all the same and the part number for the least expensive gas valve coils is 279834
They can be purchased at your local appliance parts store on online at
searspartsdirect.com
repairclinic.com
apwagner.com
apdepot.com
midwestapplianceparts.com
To replace the coils,remove bracket over them(dont worry about where it says dont grip thats for when dryer is plugged in) unplug them and install new ones,that bracket has notches in it and the coils have tabs that inter lock so they position them self exactly where they fit.
Aug 27, 2011 | Dryers
The igniter glow bar gets bright and hot on the first burn in the drying cycle, however on subsequent urns it doesn't glow bright or long enough to ignite. What's up?
The ignitor is either going to be good or bad. If it fires off it is fine and if it is shutting down then the flame sensor is also working. That tells me your coils are weak and old.
Here is how it works and why I believe you need to get new coils: When the dryer is cool first thing in the morning the initial start up the fuse and control besidethemobilian_2632.jpg
it allow power to the gas assembly, the flame detector/sensor allows power to get to the ignitor and it begins to glow. 1800 degrees is what that baby puts out and at that point the flame sensor bi-metal bends and shuts down the ignitor. The holding coil and secondary coil will then have enough power partially because the ignitor is off and partially because the ignitor is now acting as a thermocouple. If for some reason the gas did not ignite then the ignitor would cool down and shut off the gas. themobilian_2633.jpg
When the temp inside the drum gets to 160f that control beside the fuse shuts off the gas assembly, IF it don't shut down the gas then that fuse melts and shuts down the power to the gas assembly but it doe not shut down the dryer. The fuse is good though because you are getting power to the gas assembly AND the gas assembly is shutting down at 160f. The dryer keeps a tumbling around till the temp in the drum drops to 105f at that time the dryer wants another blast of hot air, trouble is the coils have gotten hot now, the ignitor is doing its thang, the flame sensor is doing its thang, the control is doing its thang. The only thing that ain't happening now is the coils ain't allowing gas to come out. Replace the coils and party on! More here
Jul 18, 2011 | Kenmore 400 6942 Dryer
Bosch GWH 715 ES flashing EA code. This unit was working fine for over a year so I am assuming gas pressure can't be the problem? The spark is flashing and the unit lights for about 2 seconds then...
http://www.digelair.net/pdfs/TECHLIT/BOSCH/MANUALS/Bosch-ProTankless_AM.pdf
http://www.bosch-climate.us/files/201009031238250.GWH715ES_English_12.2008.pdf
Above are the manuals required to diagnose and service your error code.
EA: No flame ionization detected with water flow.
Verify that all manual gas shut off valves are open. Check gas type. Reset error code and open a water tap to cycle the heater in an effort to purge air on new installations. Cycling hot water tap on and off multiple times may be necessary. If heater still faults with EA error code, have a licensed gas technician properly purge air out of the gas line leading to the water heater. Check three wire connections to ignition group on the lower front of the heat exchanger are secure. Check gas pressure. Check venting specifications are met. Improper venting may cause premature failure of the flame sensor rod. Check that the minimum power fan speed has been adjusted to the proper value. Observe inside the viewing window of the heat exchanger when a hot water tap is opened. Sparking should be followed by a steady blue flame. If flame is unstable or yellow with proper gas pressure.
Jul 07, 2011 | Bosch & Tankless LP Hot Water Heater
Dryer won't get hot
First thing to check is the ignitor underneath the drum. (You have to open the panel to see it) It should glow shortly after the dryer starts, then the flame starts and the ignitor shuts off. If the ignitor does not glow then it or the thermostat is bad. If the ignitor is glowing but the gas does not light then the gas valve coils may have to be replaced. If the gas ignites but does not stay on either the flame sensor or the coils are at fault.
Aug 12, 2009 | Dryers
Dryer comes on then will not continue heating
Hi, You will need to change the coils on top of the gas valve. Remove the screws on each side of the door opening and the fron panel will release. The door will hange there on the hinges. The two black doils on the gas valve will work early in the cycle and then after they get hot, they will not open later in the cycle.
I hope this helps you. Please let me know if I can assist you further,
Vic
Jun 20, 2009 | Maytag MDG7600AW Gas Dryer
Kenmore front load washer won't heat
The gas burner assembly uses solenoid coils in a circuit with the flame sensor to safely ignite the burner. When the dryer starts a heated cycle, the circuit through those components is energized. The igniter glows until it reaches the proper temperature to ignite the gas, at which point the flame sensor trips open and the current flowing through that circuit is diverted to the gas valve coils so the gas valves open, and the burner lights and continues to burn. If the solenoid coils on the gas valves fail, the gas valves won't open for ignition. If the gas valve coils are weak, the burner lights during the initial ignition sequence from a cold start but it fails to light the burner on subsequent ignition attempts. In this situation, replace the valve coils. I Had the same problem with mine and I fixed for like $25.00 US. Its not hard to do look at the video. Either buy your part from them or to get it fast and not out of this world go to "repairclinic.com
Nov 17, 2017 | Dryers
Kenmore elite gas dryer won't fire up
replace the coils on burner valve ..they will fail sometimes after initial heat up both are in kit change both
Jun 04, 2008 | Kenmore Elite HE4 Electric Dryer
Kenmore 72622 Gas Dryer Logo
169 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
