Question about Disney Mix Max Digital Media Player
Okay so I have an orange Disney Mix Max and I want to put songs on it from itunes can you do this and tell me how if you can?
    President:
  • 563 Answers
I don't think your player will recognize the format your iTunes music is in, so you have to convert the music to mp3 format using iTunes and then it can be played by any and all portable players.
To learn how to convert the music in your iTunes library, click on help in iTunes and type, "convert to mp3" It will give you step-by-step instructions.
Posted on Jul 04, 2009
How do i download music on my mp3 player?
How to Put Songs on Disney Mix Max
The Disney Mix Max portable media player is capable of playing audio files in the MP3 format. It can also play videos formatted as WMV and display photos formatted as JPEG. You can convert audio files into MP3 using the Disney Mix Max software -- Mix It Plug-in. The plug-in works with Windows Media Player 10. This software CD came with the player and is not available online. To download music to the device, you can use Windows Media Player 10 or Windows.
Things You'll Need:
* USB cable
* Mix It Plug-In installation CD
Instructions
Convert Non-MP3 Files
Install Mix It Plug-In. Insert the Mix It Plug-in installation CD into the computer's optical drive. Click "Install Mix It Plug-In" when prompted. If no screen opens, double-click on the "My Computer" icon. Double-click on the installation CD icon. Then double-click on the setup or installation file; this file is often formatted as EXE. Select to have the program saved to your desktop. Then double-click on the desktop icon -- "disneymixitplugin" to open the setup wizard. Click "Next" in the setup screen. Follow any additional setup prompts.
Open Windows Media Player 10 and create a playlist. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Open Mix It Plug-In. Select "Yes" when asked to save analysis information for your music files. The software will analyze each track's compatibility with the Disney Mix Max player.
Press "Go!" to start the conversion process. Once the process is complete, an inactive "Go!" will be displayed. All music that has been converted is still listed in your Windows Media Player 10 playlist. You are now ready to download music to the player using Windows Media Player.
Open Windows Media Player 10 on your computer.
Remove the USB jack cover located on the bottom of the Disney Mix Max. Insert the compatible end of the USB cable into the USB port on the Disney Mix Max. Insert the other end of the cable into the computer's USB port.
Click "Library" and click a playlist name. To create a playlist, click "Library" and select "Now Playing." Drag songs from your computer to the "Now Playlist List" pane. Click the "Now Playing List" title to open the menu and select "Save Playlist As." In the "Save As" dialog box, enter a name for the playlist and select "Save."
Select the "Sync List" tab and choose "Sync List" from the menu.
Verify the items to be synced to the Mix Max, or right-click on a song title and select "Delete" to remove it. Click "Start Sync" to download music to the Mix Max.
Windows
Insert the USB cable to the Disney Mix Max USB jack. Connect the player to the computer with the USB cable.
Click on the desktop "Start" menu and choose "My Computer."
Double-click on the "Removable Disk" that corresponds with your connected device.
Drag songs saved on your computer with your mouse into the Removable Disk folder.
Tips & Warnings
If you converted files using the Mix It Plug-In, you will need to use Windows Media Player 10 to sync them to the player.
Mar 11, 2011 | Disney Mix Max Digital Media Player
What is wrong with it ?
unistall then reinstall and if that dosent work return the intem
May 30, 2009 | Disney Mix Max Digital Media Player
Songs on device will not play
Try adding the songs on the the device with Winamp.
(take the songs off and put then in a folder on your computer 1st)
Apr 20, 2009 | Disney Mix Max Digital Media Player
Getting different music
You need to find a site that is compatible with the mix max. Most sites will work. You just pick the songs you want and download them. I would try a sample first before I commit to buying anything, just to make sure the site is compatable. However, music in a WMA format should be fine.
I've heard that the itunes store doesn't work on other players. Then I heard they changed that. Walmart.com and Amazon both have songs. They are usually around 99 cents.
Apr 17, 2009 | Disney Mix Max Digital Media Player
Deleting music on a mix-max
As far as why it's stopping it could be several things; there could be a problem with the track itself being corrupted or, depending on where you got the tracks, they could be protected with Digital Rights Management. The memory in the player could also be corrupt as well. I would start with reformatting the memory in the player to correct any potential corruption there might be. Below are three links that will answer both of your questions. Always make sure you properly disconnect the player from your computer to reduce the risk of corrupting the memory and causing these types of problems.
Format
http://digiblue.com/customer-service/faqs/disney/mixmax/06.html
Delete songs
http://digiblue.com/customer-service/faqs/disney/mixmax/05.html
Properly disconnect
http://digiblue.com/customer-service/faqs/disney/mixmax/03.html
Aug 29, 2008 | Disney Mix Max Digital Media Player
How do I deleate unwanted files from mix max???I
You just put songs she does want on it then click shuffle it will put new songs on and delete old
Jul 30, 2008 | Disney Mix Max Digital Media Player
Shuffle mix max
That's not actually how you delete songs from the player. When you connect it to your computer you will see a new removable disk called Mix Max in your My Computer icon or in Computer if you have Vista. Open up that Mix Max icon and then you can highlight and delete only the songs you don't want or all of them.
Mar 28, 2008 | Disney Mix Max Digital Media Player
Disney Mix Max problems
The memory could be corrpt in the player. It some times happens so try reformatting the memory to clear it up. This will erase everything and then you can put your songs and stuff back on it. Here's a link to the manufacturers instructions on how to format the player.
Mar 21, 2008 | Disney Mix Max Digital Media Player
Disney Mix Match
You may need to update the firmware on the player in order to be able to play the Max Clips.
http://digiblue.com/customer-service/faqs/disney/mixmax/14.html
As far as putting songs on the player goes check out the FAQ's page on the manufacturers website. The specific FAQ for adding songs is here...
http://digiblue.com/customer-service/faqs/disney/mixmax/02.html
Mar 17, 2008 | Disney Mix Max Digital Media Player
How do you put music on a Disney Mix Max (512 MB) Digital Media Player
I have Windows Vista and the first time I plugged in the Mix Max it immediately downloaded the device drivers. I opened my Windows Media Player and it already recognized the player. I just transferred songs over walla they are on the player. Hope that helps.
Jan 03, 2008 | Disney Mix Max Digital Media Player
Disney Mix Max Digital Media Player Logo
80 people viewed this question
Top Disney Audio Players & Recorders Experts
Lyle Siemens
Lyle Siemens
Rick
Are you a Disney Audio Player and Recorder Expert? Answer questions, earn points and help others
