Question about Vaper 10" Random Orbital Buffer Polisher 3000 Rpm 115v
Reduced speed smoke smell - Vaper 10" Random Orbital Buffer Polisher 3000 Rpm 115v
  • 80 Answers
Motors shot
Posted on Oct 07, 2009
2002 Jaguar 2.5 X Type 5 speed Manual 69,000 miles. Fuel pump recently replaced Black smoke exhaust pipes Gasoline smell
Fuel pressure regulator or several injectors stuck open. Both will cause excessive fuel to be dumped into the cylinders. Cause of the black smoke and gas smell.
Apr 03, 2016 | Jaguar Cars & Trucks
What would be causing what sulfur smelling exhaust smoke?
The Smell is-- Sulfur Dioxide-- from an over heated
Exhaust Converter
Yes-- it will be ruined soon
White Smoke all the time, could be a head gasket
It could also be-- lots of fuel-- that is overheating the converter
Have to look at fuel trim on scan tool data
Aug 23, 2014 | 2012 Ford Fusion S Sedan 2.5L 4-cyl....
White smoke when the blower in high speed
Smell the WHITE EXHAUST.. Does it smell like Coolant? You have a blown Head Gasket
Feb 12, 2014 | Volvo S40 Cars & Trucks
Smoke smells when ac on nissan sentra
The speed control of your fan has resisters that are in the venting system to blow air on them to keep them cool. If they overheat and or burn you will lose your low and medium speeds of the fan. If you run the fan at full see if the smell goes away. Your engine could be burning oil on the outside of the engine block, make sure that the weatherstrip where your hood meets the fresh air intake grill is sealing tight.
Nov 26, 2013 | 2001 Nissan Sentra
Reduced power,sparks and smoke shooting out of the back of the vacuum,strong smokey smell
Sounds like you may have a bad clog in it somewhere , I recommend Taking it apart and cleaning it out . Look to see if anything is wound around the wheel , check the belt . These are all reasons the vaccum could be smoking ect.
Oct 05, 2013 | Kenmore Vacuums
Puff of smoke from glove box, smell of electrical burning
Check the fan speed position switch and if you have only one speed for the fan or no speeds then look for the fan speed resistors as burnt out.
Sep 06, 2013 | 1992 Mitsubishi Diamante
Washer started to smoke during spin cycle then a cracking noise began after that.
You may just have a defective drive belt. The motor itself will smoke under certain failing circumstances. Can you give me a model # ?
Jan 07, 2013 | Washing Machines
Rubber smell and slight smoke
a rubber smell?? the best thing you can do is diagnose it properly by blocking it up high enough of the ground and let it smoke then slide yourself under there and see where it originates ... check for witness drip marks on the exhaust first??
Dec 04, 2009 | 2004 Honda Accord
Reduced RPM and smell smoke
Could be electrical problem, (brushes burnt, armature grounded or bearings starting to seize up) I don't think that I would use it till the problem is fixed. Could cause or create more expensive repair. Let me know and I will try and help
Jul 20, 2009 | Craftsman 10" Table Saw
Toyata TownAce Pick-Up problem
if its a diesel then disconnect the the vacumn pipe from the unit that connects a pipe from the exhaust manifold into the inlet manifold.this will not affect the emmisions test on the anual inspection
Nov 12, 2008 | 1996 Toyota Corolla
Vaper 10" Random Orbital Buffer Polisher 3000 Rpm 115v Logo
90 people viewed this question
Top Vaper Tools & Hardware - Others Experts
John Trevino
Are you a Vaper Tool and Hardware - Other Expert? Answer questions, earn points and help others
