Question about Saeco Magic De Luxe Espresso Machine
Coffee grinds and then there are 10-12 load clicking noises. No water or coffee comes out and grounds start piling up at the bottom of the central dispensing area. Can you help?
  • 1,089 Answers
Hi
If you take the brew unit out and there is coffee in the chamber, you have a broken brew drive. It is usually from over dosing or using too much coffee in the pre-ground mode. The brew drive is what compresses the coffee. If there is too much coffee in the chamber, it can't compress the coffee and the drive breaks.
Posted on Jun 29, 2009
No coffee will come out
Maybe the coffee is down, around the waste container. In this case the grinder must be opened probably the cofee funnel is jammed or is not in his place to direct the grinded coffee.
Jul 29, 2014 | Saeco Odea Giro Plus Coffee Maker
Loud drilling noise when coffee switch is turned on - rather than the usual purring noise - and no coffee delivery either
How old is your machine ? and what maintenance have you done over time such as replacing the shower curtain located at the pourring end of the hot water ? I had too very loud noise coming occasionnally from the stainless steel rack holding the cup while coffee is delivered. If your ground coffee is too fine it will stop flow during making a shot. Is water coming out when no coffee is placed in the portafilter.The water pump on this machine is a cheap pump that has to be replaced over time. Mine is 7 years old and has delivered four cups of expresso everyday of the year, and still working.3841c994-fb4b-459f-8d1f-710e0aafc3c0.jpg 2ead4f70-37c6-4236-a9c2-992dba149c4c.jpg
May 29, 2014 | Rancilio Silvia Espresso Machine
Miele Coffee maker CVA 615 makes clicking noise when first turned on. Grinds the coffee but the coffee will not come out. Makes the clicking noise again. It dispenses the used ground coffee correctly to...
If the Hot water and the steam function work fine - then I would say the water system and heaters are good. Are the grounds being dumped in the waste dry? I would guess so. The brew unit drive sounds to be the issue - it has a valve on it that dumps the water to waste if the pressure is to great - the waste valve sometimes gets stuck, but in your scenario it sounds as if the brew unit is not being driven to full compression (the clicking sound) and if that is the case the operation is cancelled. One thing you may try - set the grind to coarse and try a small cup - this is easier on the drive and may work - showing the Valve is good and the brew unit drive is starting to weaken.
Hope that helps
Jan 01, 2018 | Miele CVA615 Espresso Machine
We recently purchased a refurbished Cuisinart DGB-600 Coffee Maker at a yard sale. So far, we've had three batches of horrible coffee that tastes more like water with coffee flavoring. The first two...
It sounds like the water isn't flowing through the coffee grounds correctly. Perhaps you don't have the right kind of filter installed (either the right-sized paper filter, or the "gold" filter that comes with the machine) ... or, if uising pre-ground coffee, and if the coffee is all in a pile in the middle of the basket... the water will follow the path of least resistance, so much of it may run "downhill" and around the coffee, through the filter and into the carafe, without passing through the coffee. (That would be more likely if you're brewing only a few cups rather than a full pot.) Or, you might not be using enough coffee; I would use about 7-8 tablespoons of ground coffee for 10 cups of water. I'd recommend getting it working properly with pre-ground coffee before trying the grinder. It's also important that the lid of the carafe is in place while brewing, and that the carafe is fully seated in its chamber; the bump on top of the carafe's lid triggers a spring-loaded mechansim on the bottom of the basket, which regulates the flow of water into the carafe... so if any parts of this system aren't lined-up right, you may get unexpected results (including, in some cases, water all over the countertop).
I also recall, once upon a time, using one of those pre-packaged "packets" of coffee... sort-of like a large tea bag full of coffee grounds... and getting unsatisfactory results; again, the water found it easier to run over/around the coffee packet, rather than through it.
Oct 10, 2010 | Cuisinart DGB-600 Coffee Maker
Saeco Odea Go - Hot water leaks from bottom of machine
That's leaking from the hoses coming out from the boiler,if the machine is new it should be still under warranty, may have to take it back to the service center.When making coffee the lines are under pressure and the water never have a chance to pass through the ground coffee.
Feb 03, 2010 | Saeco Odea Go
Beans ground but continuous grinding but not brewing
The grind switch is stuck. Try to free it and clean it.
Mar 15, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Incanto Sirius - grinds but cannot hear coffee getting ground
The chute is clogged or the grind is too fine on the machine. To clean chute remove the brew unit and check to the right, clean chute.
Mar 12, 2009 | Saeco 00034 Incanto Sirius Super Automatic...
Saeco magic deluxe machine is making crunching noises when makes coffee and when returning to start position. Sometimes does not make the coffee grinds coffee but not letting water through almost seems...
There is a lever inside the door on the right. It is at the top in the center. Pull it back one click and try again. The crunching noise does it sound like a clicking noise?
Aug 31, 2008 | Saeco Magic De Luxe Espresso Machine
Revere Ware old fashioned coffee pot
1) Boil the water you’ll need in another pot.
2) Put 1 tablespoon of ground coffee (drip grind, not percolator grind) in the reduced diameter, perforated bottom of the brewing chamber.
3) Put the grind/water separator (the perforated, flat handled plate with cup markings on the handle) in the Brewing Chamber, over the coffee grounds.
3) Put the Brewing Chamber on top of the Holding Chamber.
4) Pour the appropriate number of cups boiling water into the brewing chamber; put the lid with the black knob on the brewing chamber.
5) Let the water drain through the coffee grinds (5-10 minutes).
6) Remove Brewing Chamber, clean out the coffee grounds, and replace the lid on the holding chamber.
7) Enjoy your coffee! Keep it warm on the stove at LOW heat setting.
for the most information on the Revere cookware lines, go to: http://mysite.verizon.net/vzeoywo4/theshineshop2/id1.html
Charlie
Jun 16, 2008 | Coffee Makers & Espresso Machines
Saeco Magic De Luxe Espresso Machine Logo
181 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
just-ice
eyecam
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
