Question about OKI C3200 Led Printer
Need the part where the paper exits. it has the pop out idle roller and a gear on it
    Champion:
  • 220 Answers
Paper exit assy.contact oki.
Posted on Jun 30, 2009
Erro code e02 in toshiba estudio 181
hello
dear you have to verify all the exit sensor related
1. do u have look on fuser unit drive gears.
2. is the exit rollers are good some time exit roller got damaged they don't hold hold paper to run out from machine.
3. do u have clean the exit sensor.
4. do you have verify that the exit sensor actuator is free to operate the sensor.
5. some time exit sensor actuator broken.
Aug 28, 2014 | Office Equipment & Supplies
My Toshiba 1360 is jamming every other sheet at the exit from the heated roller. It seems that the paper is curving down slightly and catching on the ribs before the paper exit sensor switch. The switch...
At the exit of the printer, there is the fuser unit (heating roller, which heats the paper to fuse the toner on to the paper. The fuser (heater) is covered with the Teflon sheet Sleeve. So that the paper is never directly in contact with the heater and heat is transferred through Teflon sleeve.
I have noticed Paper Jam at the outer paper bin in case of damaged Teflon sleeve. A very clear indication of broken Teflon is that there is a loud cracking noise, when the printer initializes (printer power on) or while printing a page. Secondly, the toner fails to fuse properly to the paper and gets erased when rubbed. You may use a torch to inspect it as well. Secondly, inspect the paper path for any obstructions. There may be a torn piece of paper. Inspect the gears and roller from the input tray to the paper exit point and look for any stuck roller.
So, it is recommended that make sure that the Teflon Sleeve is OK and there is no obstruction in the paper exit path.
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Jun 14, 2011 | Toshiba 1360 Black and White Copier
Brother MFC 8220 -- paper keeps getting stuck in the drum. Replaced drum but still happening. Makes a loud noise when trying to print.
sounds to me like your fuser gear has broken. look for your exit rollers. they're right where your paper exits the machine. while watching them closely, open door, then close so that machine goes through its little warmup. if you don't see those rollers turning, chances are very good that your gear has broke.
hth,
razors
Feb 01, 2010 | Brother MFC 8220 All-In-One Laser Printer
REPEATED REAR PAPER JAMS-BROTHER INTELLIFAX 2820
Try making prints or copies with the rear door open. If it does not jam your fixing unit (hot area) is functioning properly. With the rear door closed try again making copies or prints. If it jams it's most likely the exit rollers acting up.
1. I've seen the exit sensor break on these units and sometimes the drive gears wear and do not feed properly.
2. If using after market toner or refills this may also coat the exit roller with a film which prevents the exit rollers from feeding parper out by reducing the friction of theses rollers. Clean with fantastic untill cloth does not turn black.
Sep 01, 2009 | Brother IntelliFax-2820 Laser Fax
I hear noise from the paper exit rollers as they turne
You need to replace fuser gears RU-5-0077, 78 and 79.
Aug 03, 2009 | HP LaserJet P3005 Printer
Ruppled printed paper cannot exit output tray
you need do follow steps:
1) check fuser unit, the fuser hot roller is hot or not? if not the fuser heater fail.
2) check hot roller should spin with the pressure roller which is against hot roller, and check there is no gap between them, and also nothing pieces paper obstruct there, because if it losts pressure balance that jam should be occured there.
3) check the output roller after fuser unit(if there is), check them are spin or not, this roller kit use for pull the paper goes out the tray. if not spin means the roller drive belt or gear loosen.
3) check paper sensor that is micro swtch around pulling roller or output area and to clean it (could be a optical sensor).
hope help you something fixed, please take a rating let me know how much helped you thanks! keep in touch your question
May 25, 2009 | Samsung ML-2510 Laser Printer
13 Paper Jam - but there is no paper inside!
I have a long solution (possibly) to your issue:
Error 13 Paper Jam
  • Paper jams can occur in 3 places: Entry, registration and exit.
  • If the paper isn't picking up out of the paper tray, visually inspect the pickup roller. If it looks shiny, replace it. You should also replace the separation pad as they work together. On the 4L/4P/5P/6P the pickup roller has a plastic shaft that breaks. You'll have to replace the whole pickup assembly. This requires major disassembly of the printer. Check our printer repair kits for your model printer. If you don't see it listed, email us.
  • If you have an HP 4/4+/5 with an optional 500 sheet feeder that's jamming, check the balance knob adjustment. Center it with a full **** of paper for proper operation.
  • If the paper is jamming at registration or anywhere between pickup and exit it could be a number of things. Check the paper path for torn bits of paper or label residue. On the II/III series, remove the metal registration guide plate (2 screws) and check underneath it. If the pickup rollers are moderately worn, the paper will stop just short of the registration roller. On the 4L/4P/5P/6P remove the screw holding the oblique roller assembly (Inside front of printer) and pull out and inspect the assembly and the area under it. On the HP 4/4+/5 pivot up the metal plate and check underneath it. Check the roller assembly on the left side for torn scraps of paper (a flashlight or torch is necessary).
  • Make sure paper cassettes are firmly seated, corner tabs aren't bent. Some trays have lifting springs that could pop out if tray has been dropped.
  • On HP IIP/IIP+/IIIP printers if the paper scrunches up at the toner cartridge you'll need our Inside Accordion Jam Repair Kit.
  • Check your software settings in the program you are attempting to print from. Do you have the correct paper size specified? If you have a different paper size than what is in the tray, you'll get a paper jam.
  • Exit jams are frequently caused by exit sensors. These sensors are typically mounted on the fuser assembly or adjacent to it. They are plastic arms that block and unblock an optical sensor. The arms can get stuck or knocked out of place when clearing paper jams. The optical sensors can also get dirt blocking the photo cell. Clean the sensor and check for free movement and proper installation of the sensor arms.
  • On HP II/III series exit jams are mostly caused by worn gears. The best way to troubleshoot this is to defeat the door interlock (see door interlock photo on troubleshooting page). Press down on the arm on the top right of the fuser. Initiate a test page. While holding down the arm, press one of the metal cartridge detect switches just below the door interlock. Watch the movement of the gears. You will get a 51 error because the door is open. Recycle power to get rid of error. There is an arm gear on the lower right of the fuser that can shed teeth. There is also a 14 tooth gear below the large gear on top of the fuser. You can also manually rotate the large gear and check for binding or crunching. If that happens, then replace the 14 tooth gear. On the door, there are some delivery coupler gears that mate with the fuser and drive the exit roller. Check the gears for excessive wear. Replace if necessary. If the paper gets almost all the way out and jams, replace the exit roller or the exit roller assembly. If the error occurs after fuser replacement, check and see if the connector on the left of the fuser is properly mated with the one in the printer.
  • On HP IIP/IIP+/IIIP printers if the paper has accordion folds on the bottom and jams on exit, order our Top Output Accordion Jam Repair Kit.
  • On HP 4/4+/5 printers the most common cause of exit jams is the exit assembly. Order our 4/4+/5 Exit Jam Repair Kit. Exit jams in the fuser can be caused by a broken fuser drive gear or a broken gear on the fuser. Remove the fuser and check the gear inside the printer for broken teeth. Manually turn the gears on the fuser and check for smooth operation. Check the paper exit sensor arm for proper mounting and free movement.
  • Check to make sure the rear door is closed on the printer. Open doors can cause 13 paper jam indications.
  • On the 5L/6L check the registration sensor arm below the pickup roller. Also check the exit sensor arm (bottom center of the fuser). These arms frequently get stuck or dislodged clearing paper jams. On these printers, if you are experiencing frequent paper jams, order our 5L/6L Multi-Sheet/No Feed Repair Kit
All this comes from:
http://www.fixyourownprinter.com/reference/errorcodes/hp
Good luck with it, I love the HP LaserJet 4 series of printers. I used to warm my coffee on the top of the fuser when I was doing large print jobs :-)
If this information helps, please give me a rating, thanks!
OpenSource13
Apr 07, 2009 | HP LaserJet 4 plus Printer
Paper jam on Xerox XC1040
Sounds like the fuser gear (the long rollers where the paper exits that get hot) is broken. It is on the upper roller. Precision roller.com sells this gear.
Mar 12, 2009 | Xerox Office Equipment & Supplies
Paper dents
I believe you have two problems. One the dent you are talking about unless I see it I don't know for sure but I believe this is minor and something you need to live with. The paper goes through a fuser which uses a teflon sleeve over a heater surface and a lower pressure roller made of rubber. It may be that you need a new lower pressure roller they get little cuts in them sometimes. Two the spots are probably from a faulty toner cartridge. It has a leak.
Feb 13, 2008 | Canon imageCLASS D761 Copier
OKI C3200 Led Printer Logo
Top OKI Office Equipment & Supplies Experts
Jimbras
Level 1 Expert
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you an OKI Office Equipment and Supply Expert? Answer questions, earn points and help others
