Question about AT&T EP5962 Phone
T23 pd code keeps appearing what do i do? - AT&T EP5962 Phone
How to restore my imei for my myphone t23 dou
just type a restore code 1122 and then enter .............done to restore your my phone t23 duo.....
Jul 01, 2013 | Duo T23
What is the format code for my phone t23 duo?
how to reformat my phone t23 duo???
Apr 15, 2012 | Duo T23
I put new batteries in my At&T cordless phones and I am getting a message on phone screen T23 PD
To register a handset to your telephone base
Make sure the handset battery is installed and charged properly. You have to enter a 15-digit telephone base ID to register the handset to the telephone base.
To find the telephone base ID and register the handset:
1. On the telephone base, press the MENU softkey when in idle mode to enter the feature menu. Press the or softkey to scroll to the DISPLAY BASE-ID menu, then press the OK softkey. The telephone base ID will be displayed.
2. On the handset, use the keypad buttons to enter the telephone base ID and press the OK softkey.
Press the softkey to move the cursor.
3. The handset will first display PLEASE WAIT!!, then T23 PD followed by SEARCHING FOR BASE. The screen will finally display HANDSET X when the registration is successful.
NOTES:
1. If the registration is not successful, the display will show NO BASE SUBSCRIPTION. Try the registration process again.
2. If an incorrect base ID is entered, the base ID will disappear and ENTER BASE ID will be displayed.
In case of a problem or clarification or my solution was insufficient, don't hesitate to post me a reply.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Jun 09, 2011 | Cell Phones
I have a PD code on a Hobart LXI dishwasher. What does that mean
PD is not an error code. It shows that when it draining water out shortly after power-up and when shutting down. If it seems to be showing "PD" longer than usual, it means the dishwasher's control circuitry believes there is still water in the tank, due to a faulty water level probe, most like the one under the lift-out screen. It has a plastic body with a metal probe coming out the center.
There is also a dual probe at the rear of the machine, but I believe the dishwasher uses the front probe to determine when to stop draining the machine during "PD" - most likely meaning "Power Drain" or "Power Draining".
If you are not seeing any E- codes (E1, E2, E3, etc.) then these water level probes are likely just fine and the "PD" is appearing normally, as it should during draining conditions.
Feb 08, 2011 | Hobart 24 in. LXIH-3 Built-in Dishwasher
Can you tell me how to fix this T23 PD error message on a handset for the AT&T EP 5962 2-line phone?
Well this worked for me so hopefully it will work for everyone else also... I had dropped my handset and the battery popped out.. well upon reinserting the battery i got the T23 PD Blinking error on my phone, well after trying multiple things from what the manual was stating I eventualy gave up and unplugged the handset from the wall... well we received a call in our office and all of a sudden my "unplugged" phone, that was still sitting in the handset charger began to ring and all the normal numbers and name were on the face of the handset... I then plugged the phone back in and went into the menu to Register, then entered the Base ID which is found at your Base Phone. Once this was complete it said please wait.. although for a short while it kept on saying System Busy if you tried to hit line 1 or 2 but by the next morning it is working fine! :) Hope this helps for you also.
Jun 15, 2010 | AT&T EP5962 Phone
Turned on my Pioneer PD M501 one day and it would not play. Disc tray will not retract into cartridge and cartridge will not eject.
Sometimes the little ball bearings that keep the cart trays separated come out causing tray jams.
Make sure your tray retracts all the way into the player flush with the face plate, gently push it in while retracting for those occasional no-read situations. (Also for Denon that takes these same carts). Also note that the CDs go in the Upside Down position.
Applicable to:
Lexus Models: CDX-M9071zt CDX-M8036, CDX-M9071, CDX-M9741, CDX-M9751
also:
Philips CDC-875 Pioneer CDX-FM35 Pioneer CDX-FM45 Pioneer CDX-M30 Pioneer CDX-M40 Pioneer PD-DM802
* Pioneer PD-DM902 Pioneer PD-M403 Pioneer PD-M423 Pioneer PD-M426 Pioneer PD-M450 PD-M453 PD-M455
* Pioneer PD-M501 Pioneer PD-M502 PD-M503 Pioneer PD-M510 Pioneer PD-M530 Pioneer PD-M550 Pioneer PD-M552 Pioneer
* PD-M600 PD-M601 PD-M603 Pioneer PD-M610 Pioneer PD-M630 Pioneer PD-M650
* Pioneer PD-M701 Pioneer PD-M702 Pioneer PD-M703 Pioneer PD-M710 Pioneer PD-M730
* Pioneer PD-M801 Pioneer PD-TM1 Pioneer PD-TM2 Pioneer PD-TM3 Pioneer CCS-430
* DCM-444 and DCM 777
BMW 740 OEM and others.
Feb 18, 2010 | Pioneer PD-M603 6-Disc CD Changer
Have ASTAR PD 3010 PORTABLE DVD PLAYER - NEED REGION CODE
Properties like region are built in features. Keep that region setting to "0". Remember u can change it only 5 times, after that it stays locked in the last entered region!...sodeep
Jun 20, 2009 | Astar PD-3010 Portable DVD Player
Cordless phones display searching for base.
Same problem: registering base ID on cordless get T23 PD error and subsequently, Searching for Base
Jan 09, 2009 | AT&T EP5962 Phone
Handset can't find base.
I just got a 3rd handset for the same phone system and were having the same error message,,, the at&t help line does not know what it is,.,. We returned it once and got another one because of the same problems, and were still having it.. AT & T help line said to return it again and try another one .. then he actually said to replace the whole phone system .. thats easier said than done! we paid 199 plus tax on the system and then another 81.00 for the third handset!
Nov 20, 2007 | Office Depot Ativa D5772 Phone
AT&T EP5962 Phone Logo
972 people viewed this question
Top AT&T Lands Phones Experts
Paul C.
Are you an AT&T Lands Phone Expert? Answer questions, earn points and help others
