Question about Braun Health & Beauty
Need exploded view of Braun 6520 shaver.I opened shaver to replace batteries and 2 springs and a clear plastic lever dropped out. I have no idea how to put these parts back. Thanks: Richard
SOURCE: Braun 6520 shaver stops working after one use on batteries
dear sir, i have one like yours,your shaver need to change the battery.
Posted on Aug 12, 2007
SOURCE: Braun battery replacement
Unfortunately this is almost impossible. The batteries are part of the circuit board, and Braun only authorize their service agents to replace the whole unit, and my local agent found that it had been discontinued. If you still want to have a go, two screws are hidden beneath the two grey plastic caps either side of the charging socket on the underside of the shaver which can be prized off quite easily. Once you have removed the screws, the small plastic section comes off. Now you can slide the outer casing off. A thin black cover at the back can then be unclipped, revealing the circuit board and batteries. The whole unit simply lifts out and would be easy to replace if you could find one! Rplacing the batteries would be far more difficult and risky. Good luck.
Posted on Sep 02, 2008
Cytherian
  • 124 Answers
SOURCE: Battery replacement for Braun 8585
If the "reset" described didn't work all that well, as a last resort you can replace the batteries. You have two choices: put in a battery/circuit-board part replacement (drop in), or solder in new batteries. If you've got some soldering experience, I recommend replacing just the batteries. You can buy new NiMH AA 1.2v flat top batteries rather cheaply (less than $4 per cell) and using a soldering iron, take out the old ones and secure the new ones. Look for batteries with at least a 1650mAh rating. Good luck!
Posted on Oct 22, 2009
Testimonial: "I believe this is a more viable solution. I will try your advice this weekend. Thanks,."
brector3
  • 1625 Answers
SOURCE: Braun 6520 is not charging after changing the battery board.
there may not be anything wrong with the batteries and circuit board at all. you may have a bad motor
Posted on Jan 16, 2010
brector3
  • 1625 Answers
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Posted on Aug 23, 2010
Where can i take my Braun 6520 to have the battery replaced?
If your shaver works but will not longer hold a charge as long as it should, the batteries need to be replaced. If the shaver is dead and the green indicator no longer illuminates when plugged in, you have waited too long and the circuit board is now damaged and can not be repaired.
For battery replacement, see shaveroutlet.com at the link below
Professional Battery Replacement for Most Models
Dec 28, 2016 | Braun Health & Beauty
Capacity of recharge went down to from 60 to 20 min after 3 years of usage. How to open for battery replacement.
You will find compatible batteries for model 6520 at shaveroutlet.com. See link below. You will need two
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
To open shaver, remove the two round screw covers on the bottom by prying them out. Remove screws underneath. Slide outer case off the bottom. You may need to reposition the lock to get it all the way off. Inside, you will need to unsnap and remove the black cover to access the batteries. For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to repair the shaver yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
Dec 30, 2010 | Braun Flex Integral 6520 Electric Shaver
How I change the battery and what is the cost of a battery.
If the shaver still works but just will not hold a charge as long as it should, you can fix this by replacing the batteries. If the shaver is dead and will not run and the green charging light no longer illuminates when you plug it in, you will need to change the whole circuit board.
You will find the batteries and the circuit board with batteries at shaveroutlet.com. You can order which you require by viewing the links below
http://shaveroutlet.com/shaver-replacement-parts/braun-printed-circuit-board-with-batteries-p-106.html
To open the shaver, you will need to pry out the two round plastic screw covers on the bottom then remove the screws underneath. You can then remove the outer case by sliding it down and off of the shaver bode. Then remover the black plastic cover inside to access the circuit board and batteris.
If replacing the entire circuit board, you will simply lift it out and replace. If just replacing the batteries, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Nov 05, 2010 | Braun Flex Integral 6520 Electric Shaver
Battery is fine - but green light showing recharge is no longer lighting and no electricity is getting to battery. It has NEVER been dropped or mishandled. Shaves fine but only on minimal battery power...
Assuming that your cord is not damaged, the circuit board is bad. This most often happens when you continue to use the shaver well after the batteries have lost their ability to hold a charge well.
You will find a new circuit board for model 6520 at shaveroutlet.com. See link below
http://shaveroutlet.com/braun-printed-circuit-board-with-batteries-p-106.html
Apr 01, 2010 | Braun Flex Integral 6520 Electric Shaver
Dec 27, 2009 | Braun Flex Integral 6520 Electric Shaver
Braun 5520 Shaver Stopped Working
The "Braun 5520" doesn't have the 2 screws under 2 small caps on bottom, as described by so many on these boards.
The round plastic plug receptacle 'itself' is the release. (Twist-Release the outer ring.)
Look on the base, where you plug the AC cord in.... Just inside the rim, you will see two small 'recesses', opposite each other, that allow a wedge tool (like a large screw driver) to turn the rim counter-clockwise (left) 45 degrees, releasing the base and housing.
Once this is unlocked, slide the cover off and pop the black retainer cover off to reveal the "PC Board W/Batteries" module/assembly. (Batteries are NOT replaceable by themselves.)
There is a tiny (and I mean "tiny"!) resistor that burns out in the circuit board and causes the majority of power malfunctions in these models.
You can order a new PC Board (with batteries) for approx. $40.00. (+ S&H)
One place is: "http://www.electricshaverstore.com/get_item_5505631_braun-pc-board-w-batteries.htm".
(Fits Models: 5510, 5515, 5520, 6515, 6520, 6510, 6512 - Types: 5505, 5506, 5705, 5706)
Or, find other by Googling "Braun 5520 Circuit board assembly", and/or replace this model with your number.
Nov 03, 2007 | Braun Flex Integral Shaver 5520
Braun 6512 shaver stop working
hi i would say that you have major problem with this did you drop it sounds like a problem with the circuit contact braun or shavers uk kevin.
Oct 30, 2007 | Braun Flex Integral 6520 Electric Shaver
Jun 10, 2007 | Braun Flex Integral 6520 Electric Shaver
Health & Beauty Logo
139 people viewed this question
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Gary
Gary
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
