Question about Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+
Door reverses for no reason, 3 or 4 times, but finally closes
I bought this garage door open in Feb2009 and it's already not working right. When I click either the wall button or the remote to close it, it starts to go down, then reverses and comes back up for no reason. It does this 3 or 4 times then it finally closes.
I've already made sure there are no cobwebs or bugs on the sensors, and they are showing the right colors on the LED.
We have followed the troubleshooting guide and adjusted the force but that didnt help.
Suggestions?
Thanks in advance
  • 2 more comments
  • Pandorra Jun 29, 2009
    Ok. Im a garage door idiot, what is the best way to re-align the sensors? The door is only 4 months old, I would hope a circuit board isnt bad already!!! As luck would have it, it's just out of warranty for labor
    The main light does flash. I have never really counted but it's more than the amount of times listed in the user manual for the door reversing problem. It's intermittent, which makes it very difficult to troubleshoot. I'll count next time it happens. I just went out there and wiggled the sensor that has the green light.
    Ok..well heres the next glitch..I am looking at the manual, this is a craftman 139 53990d. Would the problem and the fix be the same?
  • Pandorra Jun 30, 2009
    Ok, my wiggling it didnt solve it, I still had to press the remote twice for it to close.
    President:
  • 3,197 Answers
If the main light blinks 10 times when the door reverses it is a sensor problem. Sometimes the sensors are misaligned just enough that the light comes on but closing will be intermittent. If the main light is not blinking 10 times and you have increased the down force it might be a bad RPM sensor board. This is a small printed circuit board just in front of the motor. I might add I have never seen one intermittent but there is always a first time.
Posted on Jun 29, 2009
  • 1 more comment
  • Don Maggard Jun 29, 2009
    Just use your hand and twist them a bit. You still haven't said if the main light is flashing 10 times. That would help me.
    That may take care of it. Sometimes you have to get really close to the sensor and you can then see it flickering ever so slightly. This is when they are most intermittent.
  • Don Maggard Jun 30, 2009
    Yes the fix would be the same.
My garage door opener is a 3/4 craftsman and one light is yellow and the other is green. I put my hand in front of the green light and the green light went off. the other side is a yellow light and it
Hi Vickie,
The safety beam portion of the garage door opener is set up to stop the door from closing if something (car, person, etc,.) is in the doorway.
When the door is open - if you press the hard wired push button (not the wireless remote) the door will either close until shut completely, or begin to close and reverse direction as soon as you let go of the button. When this happens, it *usually* means that a sensor is blocked - and reversing the door motor. If you try yhtis with the remote the door may not move at all or just bump down and stop.
You should re-align the sensors as described in the link below. Good luck!
How to Replace the Safety Sensor for Garage Door Opener Repair Guide Help...
How to Adjust Photo Eye on Garage Door
Nov 03, 2014 | Craftsman Professional 3/4 hp Hydro-Glass...
Erratic garage door opener
It is an adjustment problem. Any obstruction and the door goes up again. So try adjusting again but don't leave space to invite rodents that will cause damage to car wiring. I am just going thru that.
Dec 04, 2013 | Craftsman Sears Liftmaster Garage Door...
Garage door only opens 4 inches then reverses and stops
you need to replace gear when the door is fully closed. then do your tweaking.
Jun 01, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door won't close
Check if there is a shadow being cast onto one of the sensors as the door closes. We've had the rope for manually closing the door cast a shadow in full sun and trigger the "something crossed the beam" safety reverse. (Our temporary solution was to cast a shadow that remained constant from outside the door.)
Similarly check if there are any weeds or grass that are being blown or bent into the opening as the door closes. If there are plants in or near the doorway, trim them or use an herbicide to kill them and then trim the top growth after the plant dies.
Mar 03, 2009 | liftmaster Chamberlain Garage Door Opener...
Keypad will close the door but not open it
u have to push right side of enter button 3 to 4 times
Feb 16, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garage door wont close in cold weather
find force adjustment on logic board and turn clockwise A LITTLE to increase down force. Try to stop door. You do not want TOO MUCH FORCE as that is a SAFETY HAZARD.
Jan 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Opener will not reverse
FIRST YOU NEED TO RESET THE CHAIN .
Unplug power
Release the door from the opener close the door manually. take the chain loose and slide the traveler down to reengage with the trolley. Plug in power, run the unit with chain off untill it completes a clockwise cycle and stops. reconnect the chain and set tension.
Adjust the chain tension.
If it still moves 6-8 inches and flashes 5 times. the problem is in the rpm sensor.
Full diagnostics are in the owners manual - FREE at
http://help.chamberlain.com/help/en-us/InstructionManuals
Oct 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Lift master 1265lm 1993
check and see if a spring is broke on either side above the door in the middle. (big springs) that's my problem.
Aug 30, 2008 | Sears Craftsman LiftMaster Chamberlain...
Door hard to close have starts to close stops and starts to open again have to keep stopping and reversing door mult times to get closed
There should be two small white adjustment knobs on the side of the unit that you turn with a small flathead screwdriver. These are the load / limit adjusters.
What it happening is it think there is something stuck under the door (like a car hood, etc)
These adjustments are VERY sensitive, so be patient while adjusting them.
Feb 06, 2008 | Sears Craftsman LiftMaster Chamberlain...
Garage Door Opener Intermittingly Reversing
try adjusted the sensor controls on the sode of the unit other wise replace the logic board
http://www.chamberlain-garage-door-openers.com/circuitboardcompatibilitychart.htm
Dec 24, 2007 | Sears Craftsman LiftMaster Chamberlain...
Sears Craftsman LiftMaster Chamberlain Garage Door Opener Wireless Keypad Model 976LM Security+ Logo
734 people viewed this question
Top Sears Building Materials Experts
Glenn Mayer
Glenn Mayer
Mike
Are you a Sears Building Material Expert? Answer questions, earn points and help others
