Question about Dishwashers
Cuisina DW002 Dishwasher - all the lights on
My dishwasher stopped midcycle, now all the lights are on but none of the buttons will press to set it up for a cycle. I've tried pressing and holding all the buttons and switching it on and off. It looks like it needs to be reset.
SOURCE: ge triton xl dishwasher
will not drain
Posted on Dec 26, 2007
  • 4 Answers
SOURCE: Dishwasher lights blinking
QuietGuard3: Clean light flashing 7 times? Press Heated Dry, press Normal Wash, then press Heated Dry again and press Normal Wash again (that's 4 button-presses) and that should fix it.
Posted on Jul 01, 2008
SOURCE: Kenmore dishwasher Lock On light flashing
holding the button for four seconds will not do it, you have to hold it until the light stops blinking and
will go back to normal, normall takes more than four seconds to unlock the unit, this is something
the sears repair techs know becouse the are trained on all this things but, they will not share this things, becouse thats how they make money
Posted on Apr 18, 2009
  • 4 Answers
SOURCE: Frigidaire Dishwasher FDB956RBC0
I successfully replaced the broken handle for my ELECTROLUX 24" Built-In DISHWASHER Model FDB956RB.
Try to check to make sure you reassembled all the parts and wire connectors properly.
Other than the broken handle, did you have other problems prior to replacing the handle/latch?
Posted on Nov 28, 2009
SOURCE: whirlpool dishwasher ADG 7550. Starts
high i have the adg7550 and the beeping again and again is the water sensor inside the left hand side.apparentley taking the plug off and cleaning contacts solves the problem this did work for me twice but now its being a pig.hope this helps.
Posted on Oct 21, 2010
Samsung 7050 will dishwasher restart if opened in midcycle
if you have control dial or push buttons,1 set them for START 2 close the door and start normally
Apr 04, 2018 | Samsung Dishwashers
My Bosch SHU66C02UC dishwasher stopped midcycle with water in the bottom. We checked the fuse and it is fine. I'd rather not pay for a repairman as it is quite expensive.Thank you.
Some suggestions: try pushing the drain/cancel buttons and see if that drains the water; check the filter or trap in the bottom of the dishwasher for blockage; check the hose that links the dishwasher to the under-sink drain pipe for blockage. You could google the model number and find the owners manual, which might have trouble shooting suggestions.
Sep 05, 2017 | Bosch Dishwashers
My Kenmore dishwasher 16023 stopped working yesterday. I'm not sure if it stopped working midcycle, because the dishes were not clean when I I took them out and there some water pooled at the bottom....
Firstly be very careful working with electricity.
Try plugging a lamp or similar into the outlet to see if it has power.
If it does sounds like it then has internal problems.
Most older appliances cost more to repair than they are worth. I suggest time to upgrade.
Nov 02, 2017 | Kenmore 24 in. 16023 Built-in Dishwasher
Talking about a kenmore 665.16389300 dishwasher. the "normal wash" button is blinking, but none of the other buttons seem to work and the cleaning cycle will not start when i press the...
Hi
Open the door. Within 3 seconds press the following sequence --Try pressing normal wash, heated dry, normal wash, heated dry, normal wash, heated dry three times within 6 seconds and then press cancel to reset the dishwasher. If that doesn't help then try pressing Saini Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air Dry, Saini Rinse, Air Dry, Saini Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally. If the light is still blinking try and reset the power to the dishwasher and try again. If still the light is blinking then check for the connections on the keypad, it may be due to moisture or shorted connections on keypad. Hope this helps... Please post back if you need more information.
Daniel
May 18, 2011 | Kenmore Dishwashers
Dishwasher stopped midcycle. Panel not lighted,nor start button. No fuse has tripped and other appliances in the area work fine. What is the problem?
Brand of dishwasher???? Under warranty ???? LG appliances have serious problems with motors. Stay away from LG appliances.
Louie Almond
Mar 27, 2011 | Dishwashers
Green start button won't stop blinking
START/RESET status indicator light flashing
You have pressed the indicator light flashing START/RESET pad while the START/RESET dishwasher is running. This will cancel the cycle. The light will stop flashing after the dishwasher drains (about 90 seconds).
Press the pad once to start the dishwasher. Press the pad a second time when the dishwasher is running only if you wish to cancel the cycle.
Power to the dishwasher was turned off while a cycle was running and power has just been restored to the dishwasher. The blinking lights indicate that the dishwasher is draining the potential water inside.
The light will stop flashing after the dishwasher drains. A new cycle will start automatically.
Good luck
Nov 29, 2010 | General Electric GLD6966RSS Stainless...
No power to dishwasher - no lights, etc.
check ,,fuse on control board..onthejob
Feb 18, 2009 | Dishwashers
Dw stopped in midcycle.
There is a thermal fuse located on the electronic control board housing that may have failed.This replaceable part (gray or white) is clipped on to the side of the housing.
May 31, 2008 | Kenmore 24 in. 17032 Built-in Dishwasher
Dishwashers Logo
189 people viewed this question
Top Dishwashers Experts
Marvin
Marvin
