Question about Minolta bizhub 200 All-In-One Printer
Printing envelopes We can not figure out how to print envelopes off of our bizhub 350 printer Thanks
1. Load the envelope paper into the bypass tray.
2. From the Copy Screen on the operation panel, select Paper.
3. Select the bypass tray.
4. Select Change Tray settings.
5. Select Normal for the paper type (do not select Envelope for paper type).
6. Select Custom size.
7. Enter the envelope size.
8. Select OK three times to return to the copy screen.
Posted on Jul 21, 2009
Address printing too small on envelope
Adjust/increase the Text font size from PC then print.
Jan 16, 2013 | Konica Minolta bizhub 350 All-In-One Laser...
Bizhub C350 envelope problem
Load the envelopes in the bypass tray select paper on the copier control panel select by pass tray change tray select normal DO NOT select envelope select custom enter size, on printer preference select envelope tray and print
Apr 18, 2012 | Minolta bizhub 200 All-In-One Printer
How to insert envelope in the bizhub C280. Where is the feeder for envelope
To insert envelope for printing use manual by pass tray.Manual by pass tray is at the lower left side of machine.Insert envelope there and start printing.Also check the pressure lever in fixing unit.Make sure it is set on envelope printing setting.
Aug 03, 2011 | Konica Minolta Bizhub C300 All-In-One...
Dont know where to put envelopes in to print on them
Put the envelopes in Manual by pass tray.The opening side of envelope should be upward and blank side where you want to be print will be downward.
Nov 08, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
Need to pring envelopes on my konica Minolta hub 350 printer
Place envelopes in either drawer 1 (top drawer) or the by-pass tray. Generally, the envelope is placed side to be printed down. (On the printer you can set up custom envelope sizes.)
Select Print. Click 'Properties' for the printer. In the resultant dialogue window, set the printer to print to the 'envelope' print path.
Click OK, click Print. (test print direction first)
Check your printed envelope. You may need to change the orientation of the envelopes to print with the opening at the top.
Jul 30, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
How do I get our Bizhub 350 to print on envelopes.
Create your document at the appropriate size, #10 Env.
On the device, set the BYPASS tray to a size setting of the same. Look under the custome sizes as there may already be one there.
There is a switch just inside the device, near the bypass tray where you set it for envelopes. this opens up the feed gap to allow for the thicker envelopes.
this is all contained in the manual.
Dec 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
I have a Mac computer. I can't choose to print an envelope and use the bypass tray at the same time. So how do I print an envelope?
on the copier insert the envelope face down
under customer size settings for the bypass enter the size of the envelope # 10 envelope is the biggest you can select select the application you are using and make the correct selections for envelopes in the application
Sep 30, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
How to print #10 Envelopes
How to copy/print onto envelopes.
Solution
Konica Minolta does not recommend copying/printing onto envelopes, asthe MFPwas not designed to run envelopes. Additionally, envelopes do not meet the
standards set for paper specifications. Their multi-layer make-up, adhesive, and odd size make it unreliable and potently damaging to the MFP.
Nov 13, 2007 | Office Equipment & Supplies
Minolta bizhub 200 All-In-One Printer Logo
12,025 people viewed this question
Top Minolta Office Equipment & Supplies Experts
Adorjani Laszlo
Norman  J Weimar Jr
Norman J Weimar Jr
Ben
Ben
Are you a Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
