Question about Sony Ericsson Z525a Cellular Phone
I turn it on and it says phone locked - Sony Ericsson Z525a Cellular Phone
    Sergeant:
  • 199 Answers
You need a code yo unlock your phone
Posted on Jun 29, 2009
When i turn on my phone it asks me for the phone lock code
If you know the lock code enter it then browse to the phone settings and under security turn the lock off. If you don't know it try the last 4 digits of your phone number, then follow the same directions.
Feb 28, 2011 | Samsung SGH-S5230 Cell Phone
Tip
How to lock a Samsung Intensity cell phone
Unlike flip phones, cell phones like the Samsung Intensity are subject to accidental keypad-pressing and dialing when they are in your pocket, purse, or even a holster. To avoid unintentionally using up voice or data minutes, you can lock your phone and temporarily disable the keypad.
There are two ways to lock a Samsung Intensity - the standard keypad lock and the security lock.
- To use the standard lock:
You can lock your phone at any time from the main screen by holding down the "0" key for about two seconds. The keypad will immediately lock, and you won't be able to use any functions or make any calls (except for calling the local emergency number). To unlock the phone, press the right option button (in the upper right corner of the keypad, next to the End button) followed by the Menu or OK button.
You can also set up Auto Key Lock, which will automatically lock your keypad after the backlight turns off. The Auto Key Lock setting can be found in the menu under Settings & Tools > Phone Settings > Auto Key Lock.
- To use the security lock:
The security lock also prevents your keypad from being used, but it requires a code to be entered in order to unlock the phone. To enable the security lock, go into the main menu and select Settings & Tools > Phone Settings > Security > Lock Phone Now. (You'll need to know your phone's security code in order to access this setting -- by default it is typically the last four digits of your phone number.)
To unlock the phone, press the right option button and then enter your phone's security code, followed by the OK button.
You can set your phone to go into security lock mode as soon as you turn it on by enabling Phone Lock Setting under the Security menu. Every time you turn your phone on, you'll need to enter the security code in order to unlock it. However, once you unlock it, it will remain unlocked until you either manually lock it or turn it off and then back on.
on Mar 04, 2011 | Samsung SCH-U450 Cell Phone
My phone won't turn on after i lock it.???
On some phones, the lock switch or key disables ALL the buttons, therefore even the on off button will be disabled. unlock it, turn it on, then lock it again.
If your saying that you removed the simlock from the phone and now it wont turn on, then you have unlocked it incorrectly and the phone is only fit for the trash
Apr 05, 2010 | LG GM730 Cell Phone
How i lock my stolen mobile N70
LOCK ? ? ? ?
Someone stole your Phone I take it -
1.if you dont have the phone with you than you CAN NOT lock it - SOL
2. if you dont want people to use your phone - - call your service provider and tell them that your phone was stolen - they will stop it from working ( in other words the thief can not use your MIN).
3. if you did once set up a lock code for it - then if the Person who stole it from you get locked out after a timed period or if They turn the phone OFF and turned it back on the lock code will keep them out.
hope this helps
thanks
Mar 31, 2010 | Nokia N70 Cellular Phone
Phone lock code.
go to Sony Ericsson service center for a reset or call me 99999-16148
Jun 03, 2009 | Sony Ericsson K550i Cellular Phone
Samsung u700 phone lock
Try this:
use v804 cable
set unlock
Phone Model: U700
Revision: U700AEGF1
IMEI: 355262011656698
Phone lock password: 00000000
SIM lock password: 0000
Connected to server
Unlock codes:
UNLOCK NETWORK LOCK: #7465625*638*778854298#
Enter codes WITHOUT simcard inside the phone.
You can check the current lock status using this code: *#7465625#
Disconnected from server
Mar 25, 2009 | Motorola Mobility RAZR V3m Cellular Phone
Need phone lock code
mechanic213 hello,
By default, all Sony Ericsson phones are locked with "0000" as a code.
Sep 29, 2008 | Sony Ericsson Walkman W810i Cellular Phone
Phone locked
go to settings-general-locks-phone lock-protection
and turn it off the default password for se is 0000
good luck!!!!!
Jun 14, 2008 | Vodavi 3530-40 Phase Lock Loop Unit PPLU...
Phone lock samsung j600
Please follow the instructions carefully but if the code fails to work, then ,make no more than 4 attempts as it may lock your phone. Can you let me know how you get on with it as well please. Thanks. Please also make sure that you back up any information on your phone as in certain cases the resetting also removes your contacts from the SIM and your pictures. Basically the SP lock needs to be removed before the Network lock is disabled, so if you only have SP lock on, you need to turn the Network lock back to active, disable the SP lock and then disable Network lock. A reminder 'how to' is below: Do a custom reset: *2767*2878# once this has finished rebooting turn the phone off. Next a SIM card from a different service provider needs to be pushed half in - (Push it fully in then slide it back out by about 1/2 a centimeter), Turn on the phone - you will now see an "Insert SIM" message, Now perform a full reset: *2767*3855# When the phone powers off, quickly push the SIM card fully in, and let the phone power back up. After you do the reset, check and make sure that your Network lock is active by pressing *#7465625# If it isn't active you must use this code to reactivate it: *7465625*638*00000000*00000000# Then you have to deactivate the SP lock first. To do that you need to input: *7465625*77*00000000*00000000# (this will reset the lock) Then you enter: #7465625*77*00000000# (to disable the SP lock). Then you disable the Network lock: #7465625*638*00000000#
Dec 14, 2007 | Cell Phones
Sony Ericsson Z525a Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
270rexton
270rexton
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
