The ice cubes will dump into the tray and several minutes later I can hear the water start to run... and water will run directly into the ice tray holding the cubes. The result is that any cubes that have been made end up floating in water which then freezes solid. What could have happened/broke and how to resolve issue? Ice cubes which are made are normal sized and good... just issue with addition water.
SOURCE: Ice maker not dumping ice
Make sure the freezer is at least 17 degrees or colder (colder is better). If you have a square cover on the end of the ice maker see if you can pull it off and press on the gear face (don't turn just press). That may clean the electrical contact springs and get it working again. Basically if ya got water, 17 degrees or colder you will get ice. Other than that the ice maker motor module is likely bad (broken gear, etc.). Pretty common.
SOURCE: Ice Maker Dumping Water into Collection Tray.
Not to plug any company but... if you get Sears to fix it ask them for a Master Protection Agreement on it, that "Warranty" will cover most everything like that where the typical warranties don't. Just a thought if you don't want to "eat getting it fixed" ever again. Thanks for the post to others, it really helps if people know not to wait on such issues.
My lady friend has the same problem with her ice maker. The problem is, the ice tray is broken on the end. I took her ice maker out and found out it was broken. Its going to be hard finding a replacement since they don't make parts anymore.
Good Luck !!!
SOURCE: Samsung side by side RS2556BB. Ice maker is not dumping ice out.
you need to remplace your control board
is not suppling power to the ice maker heater element you will find the control boar nex to the wather valve
SOURCE: ice freezes into one solid block and won't dump out of the tray
remove cube tray from ice maker. clean with limeaway adn rinse. Spray with a light coating of PAM cooking spray. wipe dry and reinstall. be careful not to damage the sensor ( in center of tray)
