Question about IOGear MiniView GCS62 2-port KVM Switch
KVM freeze, mouse and keyboard failure upon keypress
The keyboard and mouse are wireless Logitech MX duo, using a USB to PS/2 converter to plug into KVM. Computer 2 (linux box) works just fine, Copmuter 1 (Windows box) will freeze whenever I push any buttons on the keyboard. By freeze, I mean that the keyboard and mouse will no longer respond and I have to reboot (albeit if I touch the keyboard again after it boots windows, I lose functionality again).
I have an ASUS PSP800, 1 gig of ram, Windows XP Pro, ATI Radeon 9800, Intel Pentium 4 3 ghz (overclocked to 3.3), SB Audigy 2.
I can't figure out why it doesn't like it on the windows box, but the linux box is just fine. Suggestions?
When ever trouble shooting a KVM that has a problem with one computer always swap the cables at the computer end -- that will tell you if you have a computer or KVM issue.
Posted on Jan 09, 2008
I received a new PC at work that only has USB ports. Now, I am not able to plug in the one of the 2 cables (the green one) to the cordless recepter. QUESTION: Is there an adapter for this mouse or...
There are adapters available on or your local computer store that can convert a USB port to a ps/2 mouse or keyboard plug and vice versa. Make sure your keyboard or mouse support this function, though.
Aug 09, 2010 | Logitech Wireless Access Duo Optical...
I have iogear miniview kvm (gcs62) keyboard works but mouse conn does not. Mluse is usb mouse with ps/2 adapter. Direct connection via usb works. used to also work with adapter but having tried it with kvm...
USB mouse with PS/2 adapter is not guaranteed to wok with GCS62. This KVM switch is designed to work with PS/2 keyboards and mice only.
When the USB mouse with PS/2 adapter is used in a computer directly, it will surely work, because the USB port can give enough power for the mouse to work. And it can easily convert the signal.
Unlike in KVM switch, the switch serves as a bridge between the mouse and the computer. And the computer does not easily recognize the mouse.
I would suggest to use a regular PS/2 mouse. Or if you want to use USB keyboard and mouse, you need to have a USB KVM switch. Model GCS632U.
Thank you and good luck!
Jan 21, 2010 | IOGear MiniView GCS62 2-port KVM Switch
Where/how do I install the Logitech receiver to get the Logitech wirelless mouse and the wireless keyboard to operate. Where does the green circular mouse plug to on a Dell Vostro CPU?
most PS/2 type mouse and keyboard sockets are color-coded on the CPU's back panel.
violets are for keyboards. greens are for mice.
if it's usb type, plug it to any available USB port. it will be plug and play.
for wireless keyboard and mouse, you need to place the receiver away from any metallic objects so as to lengthen it's range and sensitivity.
Nov 15, 2009 | Logitech Cordless Mouse
I need to be able to use traditional mouse and keyboard ports on one computer and usb port on second computer can i convert the KVM-2 Corega swich to do this? This switch links my present two computers but...
When you say "traditional mouse and keyboard ports" i assume that you mean the green and purple PS/2 ports. If I am correct in my assumption then this is what you can do. You can buy PS/2 to USB converter for your mouse and keyboard. A simple google search should yield you plenty of shopping results. Just make sure that you buy PS/2 to USB converters, not USB to PS/2 converters or you'll probably get the wrong thing. Everything else should just be plug-n-play from there on out. Hope this helps.
Mar 14, 2009 | Belkin Computers & Internet
Belkin 2-Port KVM Switch
It is compatible with a wireless mouse, as long as it is a PS2 mouse.  if it is USB you could try using a converter, but it may not work.
Nov 04, 2008 | D-Link AirPlus G DWL-G122 802.11g/b...
KVM converter
Buy a usb hub and an usb extension, so that you can have 4 or 6 free usb at the front of your computer, and you can switch devices using usb rather then the mouse converter . Using the converter on mouse and keybord make easier for the plugs to slip out, and usb is better. Note some usb modem and some other device do not support usb hubs, you have to plug them straight into the free computer plug , if you have any.
Apr 09, 2008 | Computers & Internet
My Keyboard is Not Typing
press the connect butto the kbd along with the connect button on nthe usb port hub
release both the buttons together
it should work
Mar 28, 2008 | Logitech Cordless Comfort Duo PS/2...
Belkin KVM STandard 9 pin mouse/keyboard to USB COnversion
You need to have the keyboard connecter (purple) connected to your computer in order for the KVM switch to recognize it. The computer is providing some power through the keyboard connector and this is what the KVM switch is feeding on.
If you have a USB keyboard, you may want to change your KVM for a USB compatible one. If you just want to use the KVM to switch your monitor, you may plug the keyboard (purple) connector of the KVM to your computer's keyboard PS/2 port and also connect you USB keyboard directly to your computer. It should work.
Feb 08, 2008 | Belkin 2 Port KVM with Integrated Cables -...
IOGear MiniView GCS62 2-port KVM Switch Logo
1,306 people viewed this question
Top IOGear Computers & Internet Experts
Greg Cann
Greg Cann
John Anderson
John Anderson
Are you an IOGear Computer and Internet Expert? Answer questions, earn points and help others
