Question about Kenmore Washing Machines
Noisy and smells hot; doesn't spin properly. - Kenmore Washing Machines
  • 15,935 Answers
It appears your drive belt/coupling has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Sep 15, 2010
Maytag Neptune MAH5500 smelled like burning plastic at the end of the cycle. (The whole basement smelled bad.) The smell seemed to be coming from the plastic part at the top where it latches.
Tub bearings get worse, if they faulty, the machine would be noisy and getting louder. Sudden burning smells usually mean an electrical failure of a component but if this has stopped and the machine is working properly, its possible that something has got caught up in the rim of the tub or gasket area and during spin it has got "burnt" by being dragged around the edge. Have a close look at your clothes that were washed on that day for signs of burning or damage and around the top at leading edges of the tub for signs of melting or damage.
Mar 21, 2017 | Maytag Washing Machines
My front loader Ariston A1636S. Is washing and pumping water out very quiet, but when it comes to spinning has become noisy, and perhaps describe as a grating noise. But no strange smells.
Most common causes of noisy spin are something has found its way between the drum and its casing or the heater has come adrift from its fixing and is rubbing on the drum
Mar 31, 2015 | Ariston Technologies Washing Machines
Smelly water & not going into spin
Try cleaning out the pump access port. It is at the front of the machine.
All sorts of stuff gets into these pumps on front loaders. A partial clog will go what you describe.
If you use a mesh laundry bag it will keep this from happening
Mar 23, 2014 | Bosch Washing Machines
1997 nissan pathfinder smells hot after running awhile
Check your valve cover gaskets, bet they are leaking and that is burning off.
Jun 27, 2017 | 1997 Nissan Pathfinder
My washing machine wont wash or spin proprly
the water is not pumping out because you have a blockage in the filter unit which is located at the bottom of your machine or possibly a weak pump. the reason that your machine smells is because the water is not discharging. check the filter first for any blockages, i.e coins, bra wires etc. if that doesn't sort it you may need a new pump
May 12, 2012 | Hotpoint Ultima WF860 Front Load Washer
Model number WDSR2080G3WW. GE Top Loading Washing machine will not spin. It fills, agitates and drains but does not spin. Lid switch engages, motor tries to start the spin it won't spin, so the motor...
The reason for the hot smell must be investigated. If it is the motor that is getting hot it won't be a new motor for very long. The hot smell might be coming from a drive belt or a clutch and there could be a brake mechanism that is binding or not fully releasing.
Clearly the next step is to closely observe the operation of the mechanical parts...
Sep 15, 2017 | Washing Machines
Noisy & shaking spin cycle and smell
The shaking could be your shocks beginning to go bad, an unbalanced load, unbalanced machine, or even possibly weak flooring. As far as the smell you can purchase a product called "AFFRESH" at your local parts distributor which works well to removed the mildew in the gasket. You just put the tablets in and run the machine through a cycle. You could also wipe the gasket out with a wet rag.
Be sure to leave the door cracked open between cycles this will help prevent mildew from building up.
Hope this helps _MJ_
Jan 28, 2010 | Frigidaire Washing Machines
Washer makes alot of noise
time to replace the belt , might need a tub bearing too / tentioner pully might have froze . remove the back panel with the washer unpluged look to see if the tentioner is at its fullest possition if so replace the belt .
Sep 06, 2009 | Maytag PAV2300 Top Load Washer
There was a rubber smell, now washer won't spin.
It is possible that the bearings supporting the drum have seized
Was the machine noisy before it stopped?
If there is tension on the belts and the drum is locked then the motor will spin and burn the belts.
Aug 18, 2009 | GE WBSE3120B Top Load Washer
Smelly drain and wont spin properly
check filter may need pump then flush through on hot wash.
Jun 29, 2009 | Washing Machines
Washing Machines Logo
13 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
