Question about Fisher Washing Machines
Fisher and Paykel IWL16 not getting water
Getting code 49 on IWL16, inlet valves don't seem to be getting 24 volts, powered with 27 volts externally and valves opened. Is motor control module bad or could the diverter valve out of position affecting the command to the motor control let valve?
  • 1 more comment
  • soccergord Jun 29, 2009
    I can't get the valves to operate in diagnostic mode, only when I apply power externally. Does the diverter valve position (if open) affect any of this? I don't want to spend $150 for a motor controller
    if I'm unsure I need it.
    Getting code 49 on F&P IWL16, inlet valves don't seem to be getting 24 volts, powered with 27 volts externally and valves opened. Is motor control module bad or could the diverter valve out of position affecting the command to the motor control let valve?
    so what about the diverter valve?? Maybe I don't understand how it works. If it where open, could the motor controller not want to send power to the inlet valves
  • 15,935 Answers
The control board is faulty.
Not sending the voltage to the solenoids to open.
THanks for using FixYa!!
Posted on Jun 30, 2009
    Genius:
  • 1,847 Answers
Code 49 is a faulty cold water valve fault code. Check that the valve harnesses are connected connected correctly or check that the valve is not an open circuit. If you replaced both the valves, the wires and plugs to them are ok and it's still not working then you need to replace the Main Motor Controller module, there's no way to reset this fault sorry. Thanks Kevin
Posted on Jun 29, 2009
    Sergeant:
  • 296 Answers
Hi
Fault 49 usually points to the cold inlet valve, either open circuit or not connected correctly. we often come across machines that the motor controller is the problem too.It says that the valve tests ok and it needs the motor controller replaced.
regards
Fix cold water valve code 49 fisher and paykel wt**t26***
water valve on back where inlet of water replace blue
Mar 02, 2018 | Fisher and Paykel Washing Machines
Fisher and paykel washing machine, mw511.fault error of 3,4 and 8. How do I fix it?
If you are counting from left to right that is error 49 which means the control board is getting a bad reading from the cold water valve. That can be caused by a bad inlet valve or a bad connection on the wiring to the inlet valve or the control board itself is faulty. Unfortunately most times it is usually the control board needing to be replaced. Best get a technician out to test it.
Jul 31, 2016 | Fisher and Paykel Washing Machines
Fault 49 pops up on the screen
If your washer is a Fisher Paykel Top-Load Washer Error Codes = 49 I found this online by typing "Washing Machine Fault 49" into a google search engine...
Error Fault Condition - Water Inlet Valve Fault.
Repair or Check - Unplug the washer from power. Reconnect any non secure wires on the water inlet valve. Replace the wire harness if it is found to be damaged. If the wiring is okay then measure the resistance of the water inlet valves using an ohm meter. If the resistance of each water inlet valve solenoid is not 60 to 62 ohms then replace the complete water inlet valve assembly.
Parts for Replacement - Water Inlet Valve Assembly or Wire Harness.
Mar 09, 2016 | Washing Machines
Cold&hot water valve dont seem to unscrew or do you have to buy the whole part
Fault 49 would most possibly be faulty motor controller board.
Not the water valves at all.
Mar 22, 2012 | Fisher and Paykel Fisher & Paykel Washer
I purchased Fisher paykel washing machine from New zealand.Model no is IW 512 & sr No 552634 nz.I am getting fault code of 49.Please advise. The following are other symtoms It stopped abruptly after...
Fault code #49 is 'faulty cold inlet valve' You need to replace it with another COLD valve as F&P says they are different to the hot valve.These valves do not use mains voltage and must be replaced with the F&P part. Access via the 2 screws at the rear of the facia.
Remove the inlet valve retainer via the 2 screws between the inlet valves.
TIP.... I cut away the top of the valve slot so that the valve can be lifted straight up and out, without having to move the mixer box or spill any panni.
Don't forget to swap the seal from the old valve to the new one.
Once the valve is replaced the retainer makes everything secure again.
Good luck....Nomess
Aug 25, 2010 | Fisher and Paykel Washing Machines
Error Code 49 Fisher and Paykel Washing Machine
the code error (49) is telling you that the inlet valve is not working make sure the hoses are not blocked. if you have fitted the valve and is still not working then i would try using the unit on cold if it still does not work then there must be a short in the p.c.b control board.
hope this helps a little more
Jul 12, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
Code 49
it probably Needs a new cold water solenoid valve.
Sep 02, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Error Code 49 on Fisher & Paykel Intuitive Eco
Fault 49 usually points to the cold inlet valve, either open circuit or not connected correctly. I often come across machines that the motor controller is the problem too.
Jan 06, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Code 49 and Manual Book
Fault 49 usually points to the cold inlet valve. I have come across many with this fault that the valve tests ok and it needs the motor controller replaced.
Fisher & Paykel IWL 16 ''I need service'' message & fault code 12
The first thing to do is to check if the water valve is good - probably burnt /stuck open.
regards
Nov 16, 2008 | Fisher Paykel Eco IWL16
Washing Machines Logo
114 people viewed this question
Top Fisher Washing Machines Experts
Mike
Gerry Harvey
Gerry Harvey
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
