Question about Brother SE-270D Computerized Sewing Machine
Safety feature activated?
I recently cleaned out my bobbin case and know when i try to embroidery it makes a funny noise and says safety feature activated. What does this mean? Please help!
  • 1 more comment
  • Godsgirl Nov 20, 2007
    I seem to have tripped my safety feature too and can't turn it off. Please help!!
  • lstoldt Dec 02, 2007
    I fixed mine. I put in a new needle and realigned the bobbin case. When i put the bobbin case back in originally i didnt get it right.
    It runs like a dream know.
  • lcconner Dec 26, 2007
    New machine, but it keeps saying the safety lock is on. Seems the needle bar is in wrong placement as it hits the throat plate. Have tried turning off/on sewing machine, embroidery, several different stitiches but nothing seems to reset it so that it is in the correct position.
If you can return the machine and get your money back. this machine is nothing but TROUBLE and will continue to have problems.
Posted on Nov 28, 2007
My 500D hadthe fault the safety device has been activated. It made an awful grinding noise just before and then the warning came up, now the needle won't move and the hand wheel doesn't turn.
If the safety device has been activated, something is seriously wrong with your machine that could be a hazard. Take it for service.
Apr 03, 2017 | Sewing Machines
How do i know if i have the bobbin in right to embroidery on my brother se 400 could that be why the safety thing comes up when I tried to use it for the first time
Your owner's manual should have specific instructions on how to load the bobbin in your machine. Be sure that you are using a bobbin specifically for your machine. Although bobbins sometimes appear to fit, if they are not engineered properly, you may experience issues.
Your manual should also have instructions of what to do if/when you see the "safety" warning. In my mind's eye, if there is a safety issue, something could be potentially dangerous with further attempted use of your item (thus the warning). That would be like trying to operate your car with an activated safety warning. Whatever could be malfunctioning may not be dangerous but why risk trying to use it if the result could a front wheel falling off, the brakes failing, etc.
Nov 11, 2016 | Brother Sewing Machines
How to deactivate the safety device on the Singer Futura SES 1000 embroidery machine? How can I get the hand wheel to turn again to get the machine to sew/embroider?
You can't--something is stopping the wheel from turning, and until you find out what is stopping it, your machine will be locked up. Take a look below the bobbin case, and you'll see a ***** holding a little door. It allows you to clean and see on the other side of the bobbin basket. Chances are, there's something like a broken off needle stopping the gear that turns the hook. It can also be caused by threads wrapped around the tension disks, or around the inside of the hand wheel itself. The hand wheel can be removed by removing the cap in the center--it is hiding a ***** that holds the wheel.
Feb 29, 2016 | Singer Sewing Machines
Machine locked up with needle down in the machine
If you can, try to remove the needleplate and the bobbin case from the machine. Once the bobbin case is removed, the needle should be free.
Embroidery Problems Brother Sewing Machine
Dec 05, 2015 | Brother PE-500 Embroidery Machine
Brother innovis 1200
remove the embroidery unit, change the needle and check again in the bobbin case for tangled thread. Same problem here and this is the way I've fixed it
Aug 04, 2014 | Brother Sewing Machines
My 6003 Elna machine stop and says stop for safety purposes How do I get it unlock from that It wont do anything
This is usually what happens if the bobbin case gets dislodged, its just held in place by a magnet but if you have a jam up, often gets moved out of position. Remove top metal plate, take out bobbin, and have a look at the bobbin case, should be two metal markers or red dotsmfront side that align. Lift the case out by grasping edge and lifting up and towards you, clean underneath with the little brush, remove any jammed up threads, then return case to position, aligning the marks.
Feb 24, 2012 | Elna Sewing Machines
The safety device has been activated
Turn off the power supply and open the needle plate.
Remove the bobbin and bobbin case.
Clean the shuttle and surrounding area from any lint or thread that may have accumulated during use.
If the problem continues, the machine will need to be serviced by a Brother dealer.
Mar 03, 2010 | Brother SE-270D Computerized Sewing...
A brand new Singer Quantum Futura CE 200 Sewing/Embroidery machine, have not been able to embroider or sew a single stich, all I have been able to do is wind the bobbin. When I'm going to start...
Dear Magarita, The safety device is activated when thread gets entangled around the bobbin case. First check by removing the plastic see-through plate. If necessary remove the 2 scews on the metal needle plate and remove the bobbin case completely. Put it back and test by turning the handwheel. It should turn freely.
Hope this solves your problem.
Dec 08, 2008 | Singer CE-200 Quantum Futura Computerized...
Safety Feature engaged Brother 270 D
Push the button to put the needle in the up position. Take the hoop off the unit and chekc everything. Rethread the top thread. Take out the bobbin and remove the bobbin plate (the plate, not just the cover). Check under and around the bobbin shuttle as best as you can for threads and lint. Use the brush to remove any lint clumps. If it still not working I would try switching the machine off. If you leave the item hooped and you didn't adjust your design any with the machine before you started stitching you should be able to put it back correctly. Turn the machine back on and try again, skipping ahead in the design to where you stopped before of course. If it still doesn't work contact Brother customer service.
Nov 24, 2008 | Brother SE-270D Computerized Sewing...
Brother 2001 sewing and embroidery machine.
The fact that your machine is turning hard says you still have some thread inside the machine that is binding up and activating the safety device. It must turn easily before it will work properly again.
Sometimes the machine must be disassembled to remove these threads.
Jun 16, 2008 | Brother Sewing Machines
Brother SE-270D Computerized Sewing Machine Logo
304 people viewed this question
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
