Question about Square QO 30 Amp Double Pole Circuit Breaker
Double breaker will not shut all the way off to reset to on
  • 565 Answers
The breaker is bad and needs to be replaced when they do that.
Posted on Jul 04, 2009
  • Bob
    Bob Jul 10, 2009
    Thanks for the positive feedback and taking time to vote.
Samsung as dryer will power up but wont tumble
If it powers up but the motor doesn't work then one of the 2 power wires works. Find the 30 amp double breaker and shut it off and back on to reset it
Oct 14, 2013 | Samsung DV218AG Gas Dryer
After removing faceplate on hallway controller two wires crossed and sparked after replacing faceplate nothing worked. checked breaker outside and nothing has been tripped now what
Double check your breakers, shut them all the way off, then back on. Sometimes when they trip they don't move much and they can be easially missed. Resetting all of them will let you know if it really isn't a breaker. If it isn't, it sounds like you may have broken or fried a wire somewhere. This can be very dangerous. I recommend calling an electrician to troubleshoot asap.
Sep 16, 2013 | Heating & Cooling
Reset button not working on kitchenaid garbage
Look for small pieces in the disposal... likely pits, glass, etc once these are removed press the reset. also check the breaker. Double breakers can be tripped but you can't tell to look at it. Just shut it off and turn it back on.
Aug 22, 2013 | Hardware & Accessories
JDR8895AA Jenn-Air Double Oven free standing. Power was shut off during goutside generator maintenance; that was a week ago. No lights / noise on contol panel and 3 sec push on clock button doesn'
Not to be a smart aleck but have you checked the breaker box to see if the breakers are on also the standby breakers? Not sure how your'e wired though.
or reset to factory.... 1. Press and hold upper oven Keep Warm and Upper Cancel pads for 3 second. Should get a single beep. Then clock will show 12:00.
per repair manual Jenn-Air Repair-Manual-JDR8895AAB-JDR8895AAS-JDR8895AAW
Mar 06, 2018 | Jenn-Air JDR8895AA Dual Fuel (Electric and...
Machine shut down.. all lights off, tried resetting fuse box, plugged and unplugged machine
Double check the outlet -- plug a lamp or some other appliance into it and let me know if the outlet is getting electricity. If not - find the breaker box and reset it there.
Best of it
Gary @ Fix Ya
Jun 07, 2011 | Exercise & Fitness
Electrolux 30" electric double oven
Some oven elements are "plug-in" style, held in place with spring clips, It is possible that they have dislodged during cleaning. Good luck, Rob
Dec 31, 2010 | Ovens
My oven door lock is in the out position. Oven door won't shut
Try shutting off circuit breaker for a few minutes to let control module to power down, then turn breaker back on. This may reset the control board back to factory default and retract the lock servo. If this doesn't work then a service tech will be needed.
Aug 01, 2009 | GE Profile JTP56 Electric Double Oven
F10 Error code on double oven.
Sir,
Check out this link
suggest to reset it by shutting off both main breakers to the stove , wait for one minute and switch breakers on again.
Thanks Good Luck
Appreciate to rate as "Fixya"
May 15, 2009 | Frigidaire 30 in. Electric Gallery Series...
Furnace circuit breaker fried
shut the breaker off,loosen the screws and the breaker will lift off the rail,loosen the wires on the breaker,bring breaker to store when buying replacement,snap new breaker in place on rail,make sure lugs are tight on new breaker,turn breaker on
Nov 09, 2008 | Haier Energy Star ESA3183 Air Conditioner
Built-in Electric Double Oven
The fan is controlled by a temperature sensitive switch. Apparently the switch is not shutting off when it should. It will have to be replaced. If you are not comfortable working around appliances, you will need to call a service technician. There is usually a set of maintenance instructions in the top of the oven. Check it out for any suggestions. Temperature switches can be purchased on line.
May 18, 2007 | Whirlpool RBD306PD Electric Double Oven
Square QO 30 Amp Double Pole Circuit Breaker Logo
101 people viewed this question
Top Square Electrical Supplies Experts
Steve
Craig Butler
Craig Butler
Jim D
Level 1 Expert
Are you a Square Electrical Supply Expert? Answer questions, earn points and help others
