Question about KitchenAid KESC307 Electric Kitchen Range
Error code F1E0 AND Replace UI ???
I have a Kitchenaid error code: f1EO and it also says to replace the UI? What does this mean. Its for the oven of an electric 36" thats only a few years old. To my knowledge the oven has never been used but the cooktop I use a lot.Sincerely,Michael Burnsburnsmd@hotail.com
I think thats the unit I have - it's stainless steel with a glass covered cooktop with 4 burners of varying sizes with electric oven below and micowave with vent overhead.
  • 15,935 Answers
F1-E0 - EEPROM Communication Error - Disconnect power for at least 30 seconds and then reconnect.
Allow at least a minute after power has been restored and if error code reappears, replace control board (clock).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Posted on Oct 01, 2010
Kitchenaid KESK901SSS range has error code F1E0 after spilling water on it. What is part number that needs replacing. Appliance insurance says they cannot find part.
This website has your answers to your specific fault code:
Kitchen Aid Appliance Fault Codes
It states:
F1-E0 - EEPROM Communication Error - Disconnect power for at least 30 seconds and then reconnect. Allow at least a minute after power has been restored and if error code reappears, replace control board (clock). I hope this helps you. The next link shows what bad part may be:
KESK901SSS Parts List
Nov 27, 2017 | KitchenAid Kitchen Ranges
ERROR CODE: F1E0 REPLACE OVEN UI
F1 E0 Error
EEPROM communication error
1. Disconnect power for at least 30 seconds.
2. Re-apply power and observe for at least one minute.
3. If code re-appears, replace control board (also called ERC or clock).
Mar 26, 2014 | Kitchen Ranges
Kitchenaid microwave error f6e0
1. Unplug oven or disconnect power.
2. Open the back panels and make sure the P6 and P2 connectors are fully
inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step 6.
- If they are plugged in, go to step 3.
3. Visually inspect all wires between P6 on the appliance manager and P2 on the
lower user interface.
- Make sure wires are not cut or pinched.
- If the wires appear to be intact, perform a continuity check between
P6-1 of the appliance manager and P2-1 of the user interface board.
Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to
P2-5(UI). All the measurements made should be less than 5 ohm . If any of
these measurements exceeds 5 ohm, go to step 5.
4. Replace the appliance manager. Ensure all connectors are properly inserted.
5. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
6. Replace all parts and panels before operating.
7. Plug in oven or reconnect power.
8. Observe for longer than 1 minute to determine if error has been repaired.
9. If error does not appear, initiate a bake cycle. Let the cycle run for at least
1 minute.
- If no error occurs, cancel the cycle, the problem has been repaired.
- If error occurs again, restart the troubleshooting procedure at step 1.
At step 4, replace the lower oven user interface board if appliance
manager has already been replaced.
- If both are replaced the problem has been repaired.
May 15, 2013 | Cars & Trucks
Kitchen Aid range: error code F1E0 replace oven UI
F1-E0 = EEPROM communication error
3. If code re-appears, replace control board (also called ERC or clock). If you bought this control board used I am afraid it is bad. That error is only for a bad control board.
Here is a new board you may purchase. It is a little expensive but the supplier has a 365 day, any reason, any part return policy and you can be certain that you have a quality part.
Nov 10, 2012 | Kitchen Ranges
I have a microwave problem. My KitchenAid Convection/Microwave oven is showing error code "F6 E0" on the display screen. This occured after power lose and restore.
Hi Kent:
F6 E0 means that you are having a Lost Communication Error between the appliance; unfortunately this is the worst error code you can get on this model because there is no way to test for which part is definitely bad. You'll need to uninstall the oven and remove the top panel and the left side panel. make sure the wires are secure going from the interface control board to the program manager board on the left side of the oven. If it checks good, you'll need to make a guess and just replace one of the control boards because one of them is bad and you can't test to see which one is faulty.
Here is the actual tech manual instructions for that code:
PROCEDURE: Before proceeding, press OFF, OFF, START to enter Diagnostic mode and verify the error codes. Ensure AM software, UI software and EEPROM CHECKSUM versions appear on the lower text line. If AM software and EEPROM versions do not appear, UI and AM may not be communicating. Verify this for the lower oven UI and for the microwave (upper oven) UI. The lower oven UI will show the AM software version for the lower oven appliance manager, and the microwave UI will show the AM software and EEPROM versions for the microwave appliance manager.
If the lower oven UI is not displaying the AM software version, go to UI IS NOT DISPLAYING AM SOFTWARE VERSION.
If the upper oven UI is not displaying the AM software and EEPROM versions, go to UPPER OVEN UI IS NOT DISPLAYING THE AM SOFTWARE AND EEPROM VERSIONS.
If lower oven UI and microwave UI are both displaying an error, go to LOWER OVEN UI AND MICROWAVE UI ARE BOTH DISPLAYING AN ERROR.
UI IS NOT DISPLAYING AM SOFTWARE VERSION:
A. Unplug oven or disconnect power.
B. Open the back panels and make sure the P6 and P2 connectors are fully inserted on the appliance manager and on the lower oven user interface board.
- If they are not plugged in, plug in connectors and go to step F.
- If they are plugged in, go to step C.
C. Visually inspect all wires between P6 on the appliance manager and P2 on the lower user interface.
- If the wires appear to be intact, perform a continuity check between P6-1 of the appliance manager and P2-1 of the user interface board. Complete for P6-2(AM) to P2-2(UI), P6-4(AM) to P2-4(UI) and P6-5(AM) to P2-5(UI). All the measurements made should be less than 5 ohms. If any of these measurements exceeds 5 omhs, go to step E.
D. Replace the appliance manager. Ensure all connectors are properly inserted.
E. Replace the wiring harness (signal). Ensure all connectors are properly inserted.
F. Replace all parts and panels before operating.
G. Plug in oven or reconnect power.
H. Observe for longer than 1 minute to determine if error has been repaired.
I. If error does not appear, initiate a bake cycle. Let the cycle run for at least 1 minute.
- If error occurs again, restart the troubleshooting procedure at step A.
At step D, replace the lower oven user interface board if appliance manager has already been replaced.
Hope this helps; also keep in mind that your feedback is important and I'll appreciate your time and consideration if you leave some testimonial comment about this answer.
Thank you for using Fixya, and have a nice day.
Dec 10, 2011 | KitchenAid Washing Machines
Shortly after end of 1 year warranty, KEMS378SSS04 began displaying F6E0 Lost Communication on lower over UI (not on the microwave). Turning power off/on (multiple times required sometimes) fixes the...
Below is the complete instruction sheet.
You are having a communication error between the appliance. Here is the actual tech manual instructions for that code:
manager.
EEPROM VERSIONS.
P2-5(UI). All the measurements made should be less than 5 ?. If any of
these measurements exceeds 5 ?, go to step E.
1 minute.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
May 22, 2011 | Ovens
Kitchenaid oven says Error code F3E0, oven sensor-upper what'sup
It means the sensor that lets the thermostat know what the temperature of the oven is has failed. You need a new sensor.
F3 - E0 Oven temperature sensor (RTD) opened (upper oven, if double oven) Replace Oven temperature sensor (RTD)
Note: Applies to all F3-E... codes.
From KitchenAid themselves
F3 E0
Get one from the people in the first video. Very easy fix.
https://www.youtube.com/watch?v=VZKHpduF9RI
kitchenaid oven temperature sensor replacement Google Search
Sep 17, 2009 | KitchenAid Ovens
Replace oven UI -KitchenAid KGRS807SSS Gas Kitchen Range Problem
Unplug the stove for at least two minutes or throw the breaker for the same time. So far, has worked 100% of the time for me for all error codes. Apparently something gets out of whack and turning off or unplugging must reset the system.
Oct 19, 2008 | KitchenAid KGRS807SSS Gas Kitchen Range
Err F1E0 Replace Oven UI
The part CNTRL-ELEC solved our problem. The warranty repair person replaced it and it has worked fine for a week now.
Aug 24, 2008 | KitchenAid KEMC378 Electric Double Oven
KitchenAid KESC307 Electric Kitchen Range Logo
2,697 people viewed this question
Top KitchenAid Kitchen Ranges Experts
Colin Stickland
Colin Stickland
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a KitchenAid Kitchen Range Expert? Answer questions, earn points and help others
