Question about Hayward SAND FILTER, PRO SERIES
Vaccuuming It seems when i attach my vac hose to the skimmer closest to my filter and then turn off main and @nd skimmer that it works for a bit then the pump starts to cavitate with surgings and vac stops picking up. i shut off go and do a 30 sec. backwash and it performs again then stops. I have even openned filter and hosed entire system.
  • 110 Answers
Do you have a 'Earth' dirt filter system?
If yes - these system clog up very quickly when 'vac'ing - if can - when pool is v-dirty - 'vac' on waste setting (will loose lots of water but)
Also - get yourself some filter socks for the skimmer box filter - this will help heaps!
When can / if can - repalce filter system with a sand filter system - much easyer to use - easyer to vac pool - easyer to add chemicals - just easyer.
Posted on Jul 07, 2009
When vaccuming pool,after attaching hose to skimmer water pressure resort to priming stage.wyh?
Thank you for posting your question here on Fixya.com.
It happens because you are introducing a lot of air into the suction line when you attach the vacuum hose. Once the pump draws that air thru and expels it you should go back to normal pump flow in order to vacuum. To help eliminate this problem, place the vacuum under the water and take the end of the hose you will attach to the skimmer and place it over a return outlet. This will fill the hose with water and force most if not all the air out. Attach the hose to the vacuum plate and vacuum away.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Sep 07, 2010 | Emerson Pool & Spa
How do I vaccum the pool? I dont know if I turn the Veriflow to out and then where do I hook in the hose?..Its my girlfriends pool and she just expects me to know. Thanks
Oh then you DO need help. To vacuum you don't need to change the valve setting on the filter, but if there is a valve on the intake selecting main drain/skimmer you can select skimmer only, but I usually only do this after I have the hose primed. . You attach the hose to the skimmer inlet. Usually there will be a round plate attched to the hose that fits into the skimmer ( you may have to remove the basket) If you don't have that round plate on the hose, then you can insert the hose driectly into the bottom of the skimmer. Before you attach the hose, connect it to the skimmer head on the pole. Submerge the head and hose. Allow to settle to bottom. Put all the hose into the pool. Take the other end and hold over the discharge back into the pool to fill the hose with water (prime) until air bubbles stop coming from vacuum head. Then hold your hand over the hose (to keep from loosing prime) and quickly attach to skimmer. You may hear some air, and the pump may stop pumping fully mommentairly untill it is pumping full water again. Now you can select the valve to divert all the flow from the skimmer
Aug 13, 2010 | Hayward SAND FILTER, PRO SERIES
We don't know how to vaccuum with the Hayward filter
Find the hose and the vac head and the pole. Assemble. Put the vac head into the water. Find a water return. Put the hose over the water return to fill the hose with water. Find a skimmer, remove the cover and the basket. Insert the hose into the hole (dont let the water out of the hose after you fill it!!!) With the pump on, run the vac over the bottom of the pool until you have cleaned all of the bottom and the sides as far as you can. There should be a brush there also ... with the pole on the brush head. brusl all the pool - sides and bottom.
Other stuff you should know. You should have a Alk level of about 100 ppm, CL level of about 4 or 5 ppm, pH should be around 7.2 / 7.4. Once a week, you should shock the pool ... put in enough CL to bring the level to 20 ppm. You should have about 80 ppm Cyanuric acid. Dry CL comes with Cyanuric acid, liquid does not. If this is a gunnite pool, your CAL level should be around 300 ppm. If you use salt to make CL, your salt level should be 3200 <>. Dont expect the salt generator to meet all your needs. CL you make needs protecting by the cyanuric acid. The more you run the filters, the clearer the water will be. Backwash or clean carts when pressure goes up 10 lbs over fresh clean start pressure.
I hope this helps you. Thanks for your interest in FixYa.com
Jul 31, 2010 | Hayward Pool & Spa
Just had pool opened. They turned port dial to 2
Welcome to FixYa
Dear Sir/Madom,
If your skimmer is tied to your main drain, then both holes have to be uncovered for your skimmer to work.
If you have a separate line all the way back to your equipment from your main drain, then you may want to try to open both holes in the skimmers. Turn off your Unit to unscrew the retaining screw on the valve, and then slide the big end over.
If you've not had your pool run all winter, then you may have leaves/debris caught in the line.
If so-you can swing by a plumbing supply house and get a powerflush hose attachment.
  • Make sure that none of the holes in any of your skimmers are covered by the oval tab in the skimmer.
  • Then, if you have any valves on the inlet to pool pump, rotate them in such a manner to isolate the skimmer line that isn't working, making sure that it is open.
  • Place the hose and powerflush device in the upper inlet port of the pool pump, with the pump lid/cover and basket removed. Then, pressurize the line back to the pool with tap water.
  • If it doesn't release right away, then let it sit a little while, as you may have to "pulse" it as water pressure drops as water leaks around the clog.
  • Pulsing it means to turn the water on for a few minutes, then turn it off. Then, turn it back on, and then turn it off again.
Look down into the bottom of the skimmer. It will have either one or two holes, depending on your model. These holes are where the pool plumbing attaches to the skimmer. Most skimmers have threads inside the holes, and a copper or PVC threaded fitting screws into these ports. Squirt food coloring just above the holes and see if any of it is pulled down into them. This indicates a leak which may be caused by a poor seal between the skimmer threads and the fitting. If you put your finger into the holes, you should be able to feel where the top of the fitting meets the skimmer threads.Repair any cracks or breaks in the skimmer walls with epoxy putty.Use the silicone sealer to repair areas where the skimmer has pulled away from the pool wall, where the corners are cracked, and in tile cracks. These leaks are the result of a cracked bond beam or shifting soil from water getting into the ground around the skimmer.
Also Check this Link
I hope you got an idea...thank for Using FixYa...
Jul 03, 2010 | Hayward SAND FILTER, PRO SERIES
Losing pressure 2-3 min vacuum hose is attached to skimmer
de filters clog very fast i suggest put vac in pool put hose over pool attach a wet vac to get water out of hose remove wet vac and vac saves de and water
Jul 09, 2009 | Hayward 1HP Super Pump II Inground Pool...
I have the 15' X 42'intex metal frame. Pool and
YOU CAN DO THIS 2 WAYS IF YOU WANT TO USE SKIMMER THERE IS A PIECE THAT GOES INSIDE SKIMMER TO ATTACH YOR VAC HOSE TO HEAD O VAC FITS ON END OF POLE TWO PUSH PIN ATTACH HOSE TO VAC HEAD AND INTO SKIMMER IF YOU WOULD LIKE TO BYPASS HOOK VAC SAME WAY BUT DONT USE SKIMMER PUT HOSE OVER POOL AND DRAW WATER JUST ENOUGH TO CREATE A FLOW BY PUTTING THE END OF HOSE OUTSIDE POOL TO A WET VAC JUST LONG ENOUGH TO GET WATER FLOWING DONT KEEP IT CONECCTED LONGER THAN 20 TO 30 SECONDS GOOD LUCK
Jun 27, 2009 | Intex Krystal Clear Model 635 Pool Filter...
The jets quit working when I prime and attach the vaccum hose
you could have a leak in the vac hose or a shaft seal on the pump, if there is a wet spot under your pump there is a good chance the shaft seal is BAD.... some pumps are so strong you can starve the PUMP for water, the trick is to set your valve more towards the main drain./ hope this helps.. i'm your local pool pump motor repair guy
Jun 20, 2009 | AO Smith 2 hp Swimming Pool - Jet / Well...
How to connect the vacuum system in the swwiming pool
http://www.geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=564116
Generic problem for all Vacuums
Posted by herpor on May 02, 2008
How to connect the vacuum system in the swimming pool
This is not a problem that I can help you with, you need to contact someone in your area that deals with swimming pools and they have vacuums that are specially designed to do the swimming pools and they can better direct you in what to do.
Don – The Vac Man
Go Ahead. Use Us.
May 02, 2008 | Vacuums
Hayward SAND FILTER, PRO SERIES Logo
125 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
