Question about IBM Wheelwriter 30 Typewriter
Ibm error codes 11408
Typewriter won't feed paper or type, gives error 11408
SOURCE:
  • 3594 Answers
SOURCE: We have an IBM 6747 electronic typewriter. When
On the rear of the print solenoid plunger is a plastic cap either white or yellow it is probably broken. They are available but a little tricky to install.
Posted on Mar 04, 2009
  • 3594 Answers
SOURCE: We have an IBM 6747 typewriter electric typewriter
Either the print solenoid is gummy or the plastic cap on the plunger is broken. They are available but a little tricky to install.
Yes it is worth fixing.
DickyO
  • 3594 Answers
SOURCE: All of a sudden, the typewriter quit typing.
The plastic cap on the print solenoid is probably broken, they are available but a little tricky to install.
DickyO
Posted on Mar 19, 2009
  • 3594 Answers
SOURCE: IBM Selectric II typewriter stuck in correcting position
If you know how to remove the right dust cover (black inside the T/W below the carrier) next to the R. side frame is the correction set up mech. spray some WD40 on the arms especially where they pivot, they should free up.
DickyO
Posted on Jul 02, 2009
  • 3594 Answers
SOURCE: needing bold typing on IBM Wheelwriter 6 Series II
To get bold you need a WW 10, 15, 1000, 1500 or any of the later models have this faeture.
DickyO
Posted on Aug 18, 2009
Ibm 6787 error 067
MIght be time for a new one, sometimes the instros help:
Sep 19, 2014 | IBM Lexmark Personal Wheelwriter 2...
Wheelwriter 30 paper advance
The paper release lever may be in the release mode. try holding the left platen knob and pulling lightly on the paper is should not allow the paper to move freely, if it is ok try holding the left knob and turning the right knob in the direction you would to turn the paper in it may have come loose if so turn it all the way back in do not over tighten it your machine does not click when the platen is turned it uses electronics to hold the platen on line.
credits : JUSTOLDJIM
thank you
Aug 08, 2008 | IBM Wheelwriter 30 Typewriter
Typewriter repair manual
I just replaced a ribbon in a 3500 IBM wheelrider ribbon with the following product which is supposed to be combatible.
DataProducts Compatible Typewriter Ribbon
Dataproducts Lift Offf Tape Catridge
I had no problem istalling the tapers, forwarded the ribbon as instructed, but when I type no tryping appears on my paper.
Aug 22, 2014 | IBM Typewriter Wheelwriter III 3 with 2...
IBM Wheelwriter 6 typewriter. The print wheel does not move when typing and acts as if in stencil mode
From your posting it sounds like you have cracked plastic print solenoid cap. We sell them for 20.00 with instructions.
DickyO
216-269-3918
Apr 29, 2014 | IBM Wheelwriter 6 Typewriter
IBM Wheelwriter 6 Typewriter - while typing, characters just quit printing on paper. Checked ribbon, machine etc. Everything checked out?? What could be the problem.
It is probably the print solenoid that has a broken cap. I have seen a few advertisers that sell the repair kit with instructions. It is fairly simple to repair.
Jan 02, 2014 | IBM Wheelwriter 6 Typewriter
How do I go to the next line on a type writer?
Some ideas; Ifthis a manual the paper should advance when returning the carriage with the bikg lever. If it is electric it should feed on return
The feed pawl on the L.end of the carriage gum up try a little WD40 on it.
DickyO.
Jun 29, 2012 | IBM Vintage 1960s Selectric Changeable...
When I type there is nothing on paper. Lights and everything else on typewriter seems to be working. Could I have pressed a code or something to cause this?
Mosy likely the plastic print solenoid cap is proken. We sell them with shipping and instructions for 20.00.
DickyO
Cleveland Business Machines
216-241-0027
Aug 18, 2011 | IBM Wheelwriter 6 Typewriter
Someone used the typewriter and hit some code in error.
If it is in the delay print mode it will print when you hit ret. If this is not the case you probably need a print solenoid cap, they are available but a little tricky to install.
DickyO
Feb 24, 2009 | IBM Wheelwriter 30 Typewriter
PAPER FEED
You probably have a keyboard problem. With the T/W turned on tap the space up key and the micro up & down keys if they space without pressing them you may need a keyboard. If you find the offending key try popping off the key top this may get you by for a while.
DickyO
Aug 07, 2008 | IBM Wheelwriter 30 Typewriter
IBM Wheelwriter 30 Typewriter Logo
53 people viewed this question
Top IBM Office Equipment & Supplies Experts
James Cagle
James Cagle
Jim Keysor
jasbo
jasbo
Are you an IBM Office Equipment and Supply Expert? Answer questions, earn points and help others
