installed new LG 18000 btu mini split heat pump, started it in heating mode, the unit first appears...
(More)
installed new LG 18000 btu mini split heat pump, started it in heating mode, the unit first appears to run fine but continues to cycle in and off without reaching temp. have already changed indoor board and thermister per LG tech support request, but unit still cycles without satisfing.
GE zoneline heat pump/ AC unit wont blow any hot air? When you turn the switch to high heat and the...
(More)
GE zoneline heat pump/ AC unit wont blow any hot air? When you turn the switch to high heat and the thermostat all the way on it blows ice cold air. Its like the unit is just blow the cold air from out side into the room. help
i have a 30 gig zone that what charging in my truck and my dog bit the wire in half ever since it...
(More)
i have a 30 gig zone that what charging in my truck and my dog bit the wire in half ever since it will not charg on my computer or any thang so how do i master reset it comepletlie
GE Zoneline HP PTAC A3B688DAALW1 WIRING DIAGRAM? Found a 6" L white wire with 1/4"F...
(More)
GE Zoneline HP PTAC A3B688DAALW1 WIRING DIAGRAM? Found a 6" L white wire with 1/4"F stake-ons loose from center terminal of Compressor capacitor 20/5uf going into the back wiring compartment. Not sure where it came loose from. There is a black multi stake-on terminal block up inside behind the capacitors. Attached it there to a unused spade but now fan does not run the indoor fan when in heat mode (compressor or elect. heat). Before the fan and electric heat worked but compressor just buzzed trying to start every 45-60 seconds. Elect heat had worked OK if turned all the way warmer past compressor mode.
