Question about RCA DRC630N Portable DVD Player
Glitch with the power jack on our DRC630N
Have had this for about 8 months and when it is playing it will just shut off, if you giggle the power cord it comes back on only to go out again when you hits a lot of bumps. We bought a new power cord thinking there was short in the cord and the same thing happens. I'm guessing the recepticle that you plug the cord into is either bad or has shifted so it's not making a good connection. Can this be fixed?
  • RCA Master
  • 8,457 Answers
Return it for warrenty sevice,the connection jack port ave some kind of shorts.
Posted on Nov 17, 2009
Toshiba Satellite C655-S5082. Won't power on. Worked fine last night. Today it won't turn on. Plug it it and no power light. With power cord plugged in when I push the power button the light for...
Hi.
Take out the AC power jack and then remove the laptop battery. Plug AC power back in and see if the laptop will turn on. If it turns on let it boot the operating system and then shut down as normal, remove the power cord and reinsert the battery and again see if it will switch on. If it does then there has been a glitch with the battery. If it doesn't then there is a problem with the battery.
If the laptop won't switch on either with or without the battery then there is a possibility that the motherboard has developed a problem.
Good luck.
Jul 16, 2011 | Toshiba Computers & Internet
I have a latitude d620 i purchased used a couple of years ago. recently, my battery charger light has not been lighting unless i giggle the battery charger body. this has worked and the battery icon on...
1. Test power adapter for output voltage. Bend the power cable in various directions while doing this to be sure that there is no broken conductors in the cable.
2. If power adapter is Ok, connect it & see if the power LED on the laptop will glow when you jiggle the power connector in various directions. If yes, then the DC jack might be loose or damaged, & need to be either re-soldered or replaced.
3. If not, then disassemble the laptop. Remove any components that attach to the laptop's motherboard first (e.g. battery, hard drive, RAM, wireless card, optical drive, ... etc.)
4. Next, remove the keyboard & the LCD screen.
5. Finally, unscrew all screws that hold the upper cover & lower cover together so that you could gain access to the motherboard.
6. Inspect the solder points connecting the DC jack to the motherboard. Make sure that none of them is loose. If any, re-solder them.
7. Inspect the center pin in the DC jack. Make sure that it is not broken or loose. If it is, then you might need to replace the DC jack.
8. When you are done, re-assemble back the laptop.
Sep 22, 2010 | Dell Latitude D600 Notebook
We have an Emerson PD6620 Radio/boombox. For many years, we used the AC outlet to play the component. We tried the battery route with new D batteries (8) and the unit did not work. Is there an AC/Battery...
This 6620 has a small micro switch where the a/c power cord plugs in. It will not run on battery power untill you pull the power cord out of the radio jack.
Jun 28, 2010 | Emerson Audio Players & Recorders
Power cord plugged into machine,yet you always have to be playing around with the cord to keep it running on power source rather than battery. I replaced the original power cord with a generic one from...
Its a problem with the dc jack on the motherboard. the solder points underneath the jack have hairline cracks in them and in order to resolve the problem you need to resolder the solder points underneath the jack to make sure it stays in place. Then you won't have to play around with the cord to keep the power on.
Its going to require taking the motherboard out of the laptop and then you will need soldering skills and a solder machine with the solder to do it.
Aug 10, 2009 | Gateway MT3705 Notebook
To connect Asus Notebook to Yamaha RV-502 Av Reciever to play music
Hi, Most notebooks have a 1/8 female plugin from your audio card. (headphone Jack)
Now, you need a cord with a 1/8 male plugin on one end and two RCA Jacks on the other.
All you need to do is connect the cord to (AMP) RCA in and the 1/8 Jack to you notebook.
This will work fine. Good luck
Oct 12, 2008 | Computers & Internet
Uniden Power Max 5.8 - (TRU8880-2)
1. Disconnect Battery from handset(s)
2. Disconnect Phone Cord from wall jack
3. Disconnect Phone cord from base unit
4. Disconnect AC adapter from wall outlet
5. Allow to sit for 30 min
6. Reconnect Phone Cord to base
7. Reconnect Phone cord to wall jack
8. Reconnect AC Adapter to wall outlet
9. Reconnect Battery to hanset until you click or feel the plug snap into place
10. Re-Register Handset by placing on main base in most instances.
please rate this post
Aug 04, 2008 | Uniden 5.8GHz Dual Cordless Phone
Jack is loose where charger plugs in
This same thing is happening with my acer laptop. I sent it to the company about 3 months ago, and it happened again. I really need my laptop and cant take a month without it. I advise sending it in to be fixed to your laptop company.
Good luck (:
Jun 29, 2008 | Gateway (1532852) Power Supply
DP-01FX
I shut down the system, waited 30 seconds, turned it back on, and the recording went fine. Must've been a glitch.
Jun 18, 2008 | Tascam DP01 All-In-One Recording Package...
RCA DRC630N Portable DVD Player Logo
122 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
