Question about LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher
LE error code
Shortly after you start the dishwasher it beeps with this error LE
  • dennis coombs Jun 29, 2009
    There is water in the bottom and if you restart it pumps out the water then you get the error code again. LG said it was a motor code error Does anyone know a good part number for the motor or maybe a beter motor looks like alot of people are having problems with these motors. THANKS
  • 258 Answers
Check you inlet and outlet water hoses, check for leaks and blockages
Posted on Jun 29, 2009
3 Suggested Answers
  • 412 Answers
SOURCE: I get error code le on LG dishwasher.
hi,
le means locked motor disassemble the filter and work your way down to the macerator(steel chopper blade) remove it and see if the side labeled "this side up" is really up, its in english... dont think the chinese labourers paid attention to the warning cause i have seen alot that were wrong way
if it was installed correctly order the complete motor/sump assembly btw you do know LG d/w came with a 2 year warranty right? and some of the water distribution system had a longer limited warranty
read your manual, it states warranty, then price the part, then call warranty depot to ask them their service call and labour to install motor/sump
This part taken from a LG repair manual:
(Display Condition LE = Motor Error
Possible Cause For Error Occurrence:
Wiring connection is OK?
The Impeller of Washing Pump is
locked.
The rotor of Washing Motor is
locked.
The Blade is locked.
Remedy:
Check the wiring connection.
Replace the cause of restriction.
Replace the Washing Motor.
Replace the PCB.)
good luck.........
Posted on Mar 12, 2009
  • 239 Answers
SOURCE: error code LE
bad sensor replace main motor
Posted on Apr 18, 2010
HOW TO FIX LE ERROR CODE ON SAMSUNG DISHWASHER DMR78AHS
An LE error code on your dishwasher stands for "LEaking."
There is, what I call, a drip pan on the bottom that the water is dripping into. Remove your dishwasher and take off the lower the side panels to get a look inside the drip pan. If you have water in there, try to find out where it's coming from.
If there are no signs of water, tip the dishwasher over on its side and remove the plastic panel on the bottom of the dishwasher. Once removed, you can disconnect the connector to the leak sensor (it's mounted upside-down, with 4 wires coming out of it. If I remember right, the wires are blue and red).
Flip the dishwasher back upright and plug it in and see if your LE error code pops back on. If it pops back on, then you have a bad board. If it doesn't, then you either have a leak, or the "fangs" on the leak detector are shorting out, somehow.
Oct 29, 2014 | Samsung Dishwashers
I have an LE code how can i reset
Try unplugging the unit for a few minutes. Then plug back in. If not try the Power button. I have an SE code (drainage problem) and my machine stops running altogether.
Sep 05, 2010 | Samsung DMR77LHS Tall Tub Dishwasher
Dishwashing cycle starts for about 3 minutes then flashing LE light comes on and the machine stops. Why?
The Impeller of Washing Pump is locked.
The rotor of Washing Motor is locked.
Remedy:
Replace the PCB.
Try the following steps:
Unplug the washing machine if you see an LE error on the two-digit display electronic readout. This error indicates a miscommunication between the control panel and wash motor.
Press and hold the "Start/Pause" button on the front panel for five seconds.
Plug the LG dishwasher back in.
Run a cycle. The LE code will clear.
Aug 31, 2010 | LG 24 in. LDF 7811 Stainless Steel...
Our dishwasher shows an LE error code when started. What is wrong.?
Le error is a motor error. either there is something lodged in the pump holding the blades or the motor itself needs to be replaced
Jun 22, 2010 | LG LDF6810ST Stainless Steel Built-in...
My LG dishwasher stops running 5 mins in
The LE code means there is a problem with the washer motor. ( Motor error ) Condition : The motor is working abnormally. Possible cause : Wiring connections. The impeller of washing pump is locked. The rotor of washing motor is locked. The blade is locked.
Remedy: Correct wiring connections. Replace the cause of restriction. Replace the washing motor. Replace the PCB.
May 02, 2009 | LG Dishwashers
Error le
Hi
Error Code LE is a Motor Error
locked.
locked.
Remedy:
Replace the PCB.
Please do rate the solution as "FixYa" and revert for further assistance.
Thanks
Rylee
Apr 17, 2009 | LG 24 in. LD-12BW5 Free-standing...
hi,
locked.
locked.
Remedy:
Replace the PCB.)
good luck.........
Mar 12, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
When I start a cycle after a few mins I get LE error code
I had a similar problem Check the wires a black wire was shorted in the door. Heat broke the insulation down. George
Mar 01, 2009 | LG 24 in. LDS 5811ST Stainless Steel...
LE ERROR CODE
This new....just call out LG to repair under warenty!!
Jul 22, 2007 | LG LDF6810 Built-in Dishwasher
LG 24 in. LDF 7811 Stainless Steel Built-in Dishwasher Logo
466 people viewed this question
Top LG Dishwashers Experts
Mike
Mike
Mike
Are you a LG Dishwasher Expert? Answer questions, earn points and help others
