Question about Nokia 3110 Cellular Phone
Forget code i have forgotten my phone lock code (not simm)provided by me.i am not able to unlock my nokia 3110 phone.plz help me.although i have switched off that option but now i think it didn't follow the command.now its asking 4 the code which i don't remember.so wat to do?
  • 258 Answers
Ok the default codes are 12345, 1234 or 00000, 0000(zeros) if it is your code that you have put in and dont remember use another phone and call your phone network provider, ie.vodaphone to help you ok
Posted on Jun 29, 2009
My imei no. is 354862026555404 i forget my security code plz plz plz give me a solution 2 unlock it....
HI
PZL TRY THE FOLLOWING
THERE ARE THE LIST OF NOKIA SECRET CODES ..
*#7780# Restores Factory Settings (Memory, language, counters are not included)
Nokia 3110 Secret Codes
*#746025625# [*#sim0clock#] : Checks if the SIM clock can be stopped. SIM clock stop is a kind of stand-by mode which will save battery time. This code doesn't work with software version 4.59.
*#3110# : Checking the phone's software (SW) - Also called "Firmware Revision Information".
*#92702689# [*#war0anty#]
Press the following warranty code
7332 (OK) : Displays the date of the last repair - if found ('DATE NOT SAVED'...)
9268 (OK) : Displays Serial Number
7832 (OK) : Displays (if found) the date where the phone was purchased ('DATE NOT SAVED'...)
37832 (OK) : Set the Purchasing Date MMYY
(Warning : You can only set this once.)
87267 (OK) : Transfers ALL phone numbers, pictures, sounds from one phone to another
6232 (OK) : Displays the Month and Year of Manufacture (0997)
This code is able to check, activate or remove SIM card restriction (SP-lock)
Use the * key to get the p, + and w chars
'Y' has to be 1,2,3 or 4 - depending of what lock you what to deal with.
#pw+1234567890+1# for Provider-Lock status
#pw+1234567890+3# for Country-Lock status
#pw+1234567890+2# for Network-Lock status
#pw+1234567890+4# for SimCard-Lock status
# = DOUBLE-CROSS
W = PRESS "*" THREE TIMES
P = PRESS "*" FOUR TIMES
+ = PRESS "*" TWO TIMES
MASTERCODE = 1234567890
Y = NUMBER 1 TO 4
[Master Code] is a 10 digit code, based on the phones IMEI number.
[ No requests for the "Master Code" will be entertained. ]
Eg. To remove restriction on Lock 1 type following code:
#pw+(master code)+1#
If you just want to check your phone use 10 random numbers Eg. 1234567890 as the (master code)
eg. To check if phone if restricted on lock 1 type the following code:
#pw+1234567890+1#
1: Insert sim card of different provider.
2: Turn on the phone and press the UP VOLUME key for 3 sec. then release it and the phone says PIN CODE?
3: Press the "C" key
4: Then Press * and wait until it disappears and appears again, then press * one more time and 04*PIN*PIN*PIN#
The phone should now say : PIN CODE CHANGED (or ACCEPTED) and the SIM card is accepted until you restart the phone again. NOTE: On version 5.04 Nokia has removed this option.
Fast silent mode
*#06# : Checking the IMEI (International Mobile Equipment Identity)
REGARDS
ANIRUDDHA
Sep 21, 2011 | Nokia 3110 Cellular Phone
I have forgotten my security code how can i unlock it
If you forget the security code means get the master reset code for that one, master unlock code is a code that completely resets your phone, removing any security locks , get the code from this site Onlinegsmunlock.com , it has the best services for the master reset code for your Nokia 3110 model mobile.....I hope that it may helpful to you....
Aug 17, 2011 | Nokia 3110 Cellular Phone
I have forget my password so please help my mobile IMEI no is 356852029787086 please send me immeditly to my email id (vigneshwar.vs@gmail.com)
If you forget the security code means get the master reset code for your nokia mobile, because does not remember security code you have to reset your mobile its a only way to use the mobile, so get the master reset code for your Nokia 3110 model mobile from this site Onlinegsmunlock.com, it has the best services for the master reset code for your nokia mobile.....I hope this may helpful to you.........
Aug 11, 2011 | Nokia 3110 Cellular Phone
I've lost my imei and i've forgotten my security code dont know what should i do?
If you forget the security code means get the master reset code for that one, master unlock code is a code that completely resets your phone, removing any security locks , get the code from this site Onlinegsmunlock.com, it has the best services for the master reset code for your Nokia 3110 model mobile.....I hope that it may helpful to you....
Aug 03, 2011 | Nokia 3110 Cellular Phone
What is my restriction code. nokia 3110. IMEI no. is 356789020560619. kindly provide the same at the earliest pse.
May i know it restricted by Which Network In which Country?
If you could provide those Details means i will check and tell is there unlock service for Model or not,!!!You can check and get Restriction code for Your Phone at
Superunlockcodes.com at Low cost and Follow the instructions to remove the Network Lock step by step:
Nokia 3110 Unlocking InstructionsWarning : Do not enter any wrong unlock codes on your Nokia 3110 mobile phones. If you enter over a certain amount of wrong unlock codes on your Nokia 3110 mobile phone, your phone may get hard locked and sometimes become unusable.
1 - Switch on your Nokia 3110 without any sim card.
2 - Don't bother as to what is displayed on your Nokia 3110.
3 - Compose #pw+CODE+1#.
4 - The Nokia 3110 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia 3110 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
The letter p appears if you press the button star(*) three times quickly
The letter w appears if you press the button star(*) four times quickly
The symbol + appears if you press the button star(*) two times quickly
The CODE you need to enter is the unique unlock code for your Nokia 3110
Each Nokia 3110 mobile phone has an unique unlock code. You can buy the unique unlock code for your Nokia 3110 mobile phone using the form above.
May 25, 2011 | Nokia 3110 Cellular Phone
I have forgotten my password on security keygurd and 12345 did'nt work at all plz help me my model is 2690
To Unlock the Nokia from the Security Lock You can use the Master Reset Code.,You can get the Master reset code at Reliable cost at http://www.mobile-unlocker.com/unlocking-services/rs2wp6/ and Unlock it.You can check for Your model in the availability list.
Nov 07, 2010 | Nokia 3110 Cellular Phone
Forget the phone lock code
you can give me your imei number i can tell you the lock code
for imei number press *#06#
Feb 12, 2008 | Nokia N70 Cellular Phone
Nokia 3110 Cellular Phone Logo
70 people viewed this question
Top Nokia Cell Phones Experts
270rexton
270rexton
