Question about Homelite Mighty Lite Lawn Trimmer
How to change the string
I have a homelit trimlite weed wacker and want to put new string on the head instead of buying it already full...is it hard to add new string?
  • 1,041 Answers
If it is a duel line trimmer then:
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
If it is a single line trimmer, just wind a single piece of string clockwise onto spool.
Jim
Posted on Jul 03, 2009
  • Jim Parker
    Jim Parker Jul 04, 2009
    Thanks for the rating!
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
Weed wacker started and wacked some weeds then the strings stopped rotating but engine very strong
pull off string housing check that all parts are there. run machine and see if shaft is turning-- if it is then put housing back on sometimes I havent put the housing on properly. if shaft is not turning. then repair is needed. or just buy a new one. cost of repairs on this stuff is not worth the cost. unless it's a profesional grade machine..
Jun 18, 2011 | Craftsman 27cc 2Cycle Full Crank Curved...
How do I re-string a homelite trimlite weed eater
A user manual can best describe and show diagrams of how this is done. Go here. You will need Adobe Reader to view this.
http://dl.owneriq.net/7/7d91348b-6b05-4cce-ad47-08aad2e1f2dd.pdf
The information you want is on pages 13-14. I picked out these general models for Homelite because you haven't listed one.
Oct 02, 2010 | Homelite Garden
The string head does not spin as fast as the
it sounds like the centrifugal clutch is slipping. take it to several shops and get some quotes. Most times you'll find that fixing a Ryobi is more expensive than buying a bnew one.
Sep 02, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Homelite Trimlite String Trimmer. String won't advance on tapping
remove assembly clean with soap and water and toothbrush(make sure when you dissasemble make notes of how to put back together!)Check spring make sure not broke or distorted-oil with silicon oil(walmart sells or auto parts store)reassemble reverse of dissassemble!!! hope this helps you!!!!
Jun 22, 2009 | Homelite Mighty Lite Lawn Trimmer
How do you fix homelite st 185 weedwacker pull start
Here is a link to that weed cutter...
http://www.odref.com/homelite/string-trimmers/ut-15039a.PDF
you need to unscrew part#37 .. it may be on very tight... hope this helps
Tobaz
Jun 17, 2009 | Homelite Mighty Lite Lawn Trimmer
Double spool on Weed Wacker
This isn't a solution to the problem. However, I think you should talk to someone at Home Depot or Lowes or wherever you bought the model, and see if the string is in there correctly; if it is, then u'r weed wacker must have some other mechanical problem. Sometimes it is just best to buy a new one. The more expensive models are the best.
Aug 10, 2008 | Electrical Supplies
Homelite Mighty Lite Lawn Trimmer  Logo
809 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
