Question about Borland JBuilder X Enterprise (JXE0010USFVAAO)
Code in the correct place
I get this error message when trying to enter this code after the sord second.....
"": Error #: 200 : ')' expected at line 39, column 85
Is it in the write place?
DisplayClock1.setTitle("My Little Java Clock");
displayClock1.getContentPane().add(new DrawClock(hour, minute, second, Calendar ourcal = new GregorianCalendar(); /*notice how Java lets you break an instruction over a line*/
2 Suggested Answers
SOURCE: Java-problem in Firefox
I think they meant the software altogether.
Here's the link, just install.
If you already have java then repair your IE and reinstall Firefox.
Click Start, then Control Panel, then Add/Remove Program, go to Internet Explorer, right click IE then select repair.
Do the same thing for Mozilla Firefox, except this time uninstall then reinstall program.
That might work. Let me know.
Incase it's easier in Dutch:
Ik denk zij de software totaal betekenden. Hier is de verbinding, installeer enkel. Als u reeds Java toen uw Internet Explorer herstellen hebt en Firefox opnieuw installeren. Klik Begin, dan Controlebord, dan voeg/verwijder Programma toe, gaan naar Internet Explorer, met de rechtermuisknop aanklikken Internet Explorer, dan uitgezochte Reparatie. Doe het zelfde ding voor Mozilla Firefox, behalve deze tijddesinstallatie dan installeer programma opnieuw. Dat zou kunnen werken. Laat me het weten.
Posted on Jul 17, 2009
  • 1932 Answers
SOURCE: java calculator code
Hi you can download Borland Turbo Pascal 7.0 from below website
Posted on Jul 23, 2010
0 characters
1 Points
Which version of java is installed on my computer ?
You can view the currently installed version of java by clicking on the link below:
Once at the website, click Verify Java Version.
Dec 18, 2012 | ArcMedia JavaScript Source Code 3000 Pro...
I want to uninstall java but fatal error comes
you can turn your system back as it was
from windows files
get windows in previous date when java was not intalled
Jan 13, 2011 | ArcMedia JavaScript Source Code 3000 Pro...
Fatal error during java installation uninstall
go into Control PanelAdd/Remove Programs and scroll down to remove Java from my system. I click remove and it comes up with the window "Add or Remove Programs: Are you sure you want to remove Java(TM) 6 Update 13 from your computer".
I click yes and it says "Preparing to remove"
then configuring java.. and then come up with the window:"Fatal Error During Installation"
I've tried enabling logging.. it didn't work.. so that's all the info I can give, I have two HD's mounted.. if that helps.. I don't know. I tried using the install again.. it didn't work believe it or not s9.gif. Anyway please help
Jul 01, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Sony ericsson Handset showing ''Operation failed error''
This error occurs when your phone is checking the signature of a digitally signed java application and there is no match or is unable to do so. The most common cause is that the signature is expired. Try setting the date backwards on your phone - let's say one or two month :-) and have a look! I bet it works now....
Mar 21, 2009 | ArcMedia JavaScript Source Code 3000 Pro...
Error to compile java program
The main cause of this error is you havent set the environment variables correctly, you can do it as follows
Right click on "My Computers" select properties the click "Environment variables" then under "User variables for pcname"
select new and add the following paths
1)var name:path
var value:C:\Java\jdk1.5\bin
2)var name:classpath
var value:C:\YourJavaCodeDirName
click ok and its done
Feb 28, 2009 | Sun Java Programming Language (cdj-275)
I get an error message when i try to download java
Sep 20, 2008 | Sun Compilers & Programming Tools
I believe the error should read "java.lang.NullPointerException"
This error simply means that whatever your application code is trying to get is not there- its a null. Its either out of range or does not exist at all.
Jun 03, 2008 | Sun Java Programming Language (cdj-275)
Cannot install/uninstall Java
It is not necessary to install java in order to use java.
Just download java highest version, copy and paste the java software in the system drive(eg C:,D:,....), Then set path the java file.
Example, if you have the java file in your C drive, do the following steps
1. Goto start->Run-> type command. Command prompt(black screen) will open.
2. if it shows as C:> follow the steps, else Goto step 6.
3. set path="c:\Java file name"
4. type javac
5.after typing if u find compiler then Java is installed in your system.
6. Example... if it shows as F:> and if u have saved your file in C:, do the following.
7. cd..
8. cd..
9. cd C
10 .then it appears as C:>, follow from the step 3.
thank you.
May 07, 2008 | ArcMedia JavaScript Source Code 3000 Pro...
Borland JBuilder X Enterprise (JXE0010USFVAAO) Logo
21 people viewed this question
Top Borland Compilers & Programming Tools Experts
Yoav Shilon
Yoav Shilon
Are you a Borland Compiler and Programming Tool Expert? Answer questions, earn points and help others
