Home | Ricoh | Aficio 1035 Grayscale Copier | Help me immediately, ple...
Ricoh Aficio 1035 Grayscale Copier
Problem for Ricoh Aficio 1035 Grayscale Copier
Help me immediately, please
By vafayegham on Jun 29, 2009
in aficio 1035 , scanner and printer have a kit for either or one kit for all ?
Best Solution
posted on Jul 04, 2009
Very Helpful)
tswiercinsky
Rank: Guru  Office Equipment  Expert
Rating: 88%, 286 votes
Actually, the "kit" is a DIMM that plugs into the controller on the right side of the copier (when looking at it from the back of copier) On this model, you need to add 64mb of RAM if you want to add functionality to print and scan, along with the DIMM. Yes, there are 2 different DIMM's for this,....one is Print and one is Print/Scan.
PS: there is a kit to install said items that includes buttons for the controll panel and DIMM, however, the memory is separate (laptop memory or SO DIMM)
Was this helpful?
Yes
No
1 person thought this was helpful
Solution #2
posted on Jul 09, 2009
Not Rated)
ricohlovers
Rank: Master  Office Equipment  Expert
Rating: 91%, 8 votes
Hope this will help you.
PRINTER INSTALLATION
B003/B004/B006/B007 1-2 SM
Printer Controller Installation
!CAUTION
Unplug the main machine power cord before starting the following procedure.
1. Remove the left rear cover [A] (2 screws) and slide out the controller board [B]
(2 screws).
2. Install the printer ROM DIMM [C] on the controller board.
3. Remove the parallel interface cover [D].
4. This step is required only in the USA models.
Attach the FCC label [E] on the controller panel board aligned with the slot [F]
so the label is hidden when the left rear cover is replaced.
NOTE: If the NIB (G574), Postscript kit (G577), memory board (G578/G579), or
IEEE1394 Interface (G590) are to be installed, remove the HDD and install
them before proceeding to the next step.
5. Put back the controller board and replace the left rear cover.
Paper Height Sensor Installation
6. Remove the connector cover [A] and lower rear cover [B] (5 screws).
7. Pull out the two paper trays [C].
8. Install edge clamp [D] in the opening.
9. Connect the four paper height sensors [E] to the cable [F].
10. Install the four paper height sensors [E] as shown.
11. Install the four cable clamps [G], then clamp the cable as shown.
12. Lead the cable through the opening [H]. Secure the cable in place with the
edge clamp attached in step 8.
13. Connect the cable to CN234 on the PCB [I].
B003/B004/B006/B007 1-4 SM
14. Install the paper height sensor feeler [A] on the bottom plate shaft [B] of each
paper tray.
15. Reassemble the machine.
Paper Limit Sensor Installation
If the optional bridge unit has been installed, skip steps 16 and 17.
16. Peel off the black tape [C] from the anti-static brush [D], then pull out the cable
[E].
17. Connect the cable to the sensor [F], then install the paper limit sensor unit [G]
Paper Sensor Installation
Perform steps 18 to 20 only if the optional bridge unit has been installed.
If it has not been installed, go on to step 21.
18. Remove the connector cover [A] and bridge unit [B] (2 screws, 2 connectors).
19. Open the right cover [C] of the bridge unit and peel off the black tape [D], then
pull out the connector [E].
20. Install the paper sensor [F] (1 screw, 1 connector) and reinstall the bridge unit.
Completion
21. Remove the bottom cap [G] of the operation panel. Install the Printer key [H]
on the operation panel as shown.
B358I518
B003/B004/B006/B007 1-6 SM
22. Do not connect the parallel cable at this point. Turn the machine on and check
the setting of the following copier SP mode:
• SP5-907: Plug & Play Name - select the correct one.
23. Print out the configuration page to check if the printer controller is installed
properly.
(Configuration page: User Tools/ Printer Settings/ List Test Print/ Config. Page)
24. If the parallel cable is going to be connected, first turn off the machine. After
connecting the cable, turn the machine back on.
1.3 POSTSCRIPT UNIT (G577)
!CAUTION
procedure.
NOTE: To install the Postscript option, the printer option (B361) must be installed
first. Please refer to section 1.2 for details of the printer option installation
procedure.
1. Remove the left rear cover [A] (2 screws).
2. Remove the controller board [B] (2 screws).
3. Install the Postscript DIMM [C] onto the
controller board [D].
4. Put back the controller board and replace
1.4 MEMORY (G578/G579)
!CAUTION
procedure.
NOTE: To install the memory option, the printer option (B361) must be installed
procedure.
3. Remove the HDD [C] (2 connectors,
3 screws).
4. Install the memory DIMM [D] onto the
controller board [E].
5. Re-install the HDD and put back the
controller board.
6. Replace the left rear cover.
1.5 NIB (G574)
!CAUTION
procedure.
NOTE: To install the NIB option, the printer option (B361) must be installed first.
procedure.
3 screws).
4. Remove the NIB slot cover [D].
5. Attach the NIB [E] to the controller board
[F] (2 screws).
6. Re-install the HDD and put back the
controller board.
7. Replace the left rear cover.
B361I101.WMF
B361I102.WMF
B361I105.WMF
[C]
[A]
[B]
1.5 NIB (G574)
!CAUTION
procedure.
procedure.
3 screws).
[F] (2 screws).
controller board.
1.7 CHECKING THE CONNECTIONS
1. Plug in the power cord and turn on the main switch.
2. Enter the printer user mode and print the configuration page.
(User Tools/ Printer Settings/ List Test Print/ Config. Page)
The same data can also be printed using the printer service mode.
(“Print Summary”: SP1-004)
All installed options are listed in the “System Reference” column.
Was this helpful?
Yes
No
Solution #3
posted on Jun 29, 2009
Not Rated)
ronnie59
Rating: 93%, 69 votes
Sending you the website where you can check the specification of your aficio 1035 as I understand this printing and the scanner are separate optional kit
http://www.faxworldcom.com/PDFDocs/1035/1035_1045_Brochure.pdf
Was this helpful?
Yes
No
Popular Solutions for Ricoh Aficio 1035 Grayscale
Questions and Unsolved Problems for Ricoh Aficio 1035 Grayscale
Do you recommend Ricoh Aficio 1035 Grayscale Copier?
Answer
Answer
B4250 PRINTER PICKS UP PAPER THEN ERRORS , WILL NOT CONTINUE, CAN PULL PAPER BACK OUT , OPEN AND... (More)
Answer
My Hp 2550 Printer is orinting Prodomiatley RED.I have only recently spent $240 replacing the 3... (More)
Answer
IR 1600 COPIER SHOW ERROR CODE 9 HOW CAN I SOLVE THIS?
Answer
my hp k850 inkjet printer prints one paper and it not working any more until i restart it.
Answer
minolta cf3102 error 3c50 anybody know what this is
Describe your problem:
Select a Category:
Sponsored Links
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Browse popular Problems
More Common Problems
Most Common Problems for:
For Ricoh Aficio 1035 Grayscale...:
Top Copier Experts
Rank: Guru Guru
Solutions: 1496
Experience: The Truth is a set of corrected errors. Erwin Schroedinger
Ask Me
Find more Copier Experts
Top Copier & Fax Repair
(877) 434-9747
Full service mobile shredder repair service to...
Pacific Coast Shredder Repair
(800) 816-6855
Over 50 years in the office equipment repair &...
EBS Scantracker
Chat Now
X
Continue
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
