Question about Echo Rapid Loader, Trimmer Head
Don't know how to install new string on Echo SRM 2400
Don't know how to install new string on Echo SRM2400 weed eater.Have new double line
  • 1,040 Answers
Cut two separate pieces of string, about 7 ft. each.
Stick the end of the line in the hole on the inside of spool.
Wind clockwise onto spool, putting the line that is closest to the ground on first.
Once you have winded this piece on, lock the last 4 inches of line through the slits on spool.
Repeat process for second piece of line, locking the last 4 inches in slot opposite the other locked in piece.
Put the spool on the trimmer, feeding the end of lines through either hole on trimmer.
Before you push the spool all the way on, pull the strings out of the locked position.
Jim
Posted on Jul 03, 2009
  • Jim Parker
    Jim Parker Jul 06, 2009
    Did this solution solve the problem?
    Jim
  • Jim Parker
    Jim Parker Jul 07, 2009
    Thanks for the rating.
    If you should have any questions about
    "Drywall Finishing/Patching", or know someone who does, put your
    questions to Category:"Tools- Building & Power- HAND TOOLS" at
    FixYa.com
    Thanks Again,
    Jim
How to check fuel needle setting in Echo 2100 weed eater
Jack, Check the attached links for trimmer carb. tuning,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
How to Tune Up an Echo Trimmer
http://www.echo-usa.com/getattachment/e8f287f6-0f5c-4f36-b0fa-ea8fa4a550b9/SRM2400241025012501S2510es_120194
echo srm 2100 weed eater
May 07, 2016 | Echo Garden
Echo srm225 grass trimmer will not start
Search Results
    Echo String Timmer/Weed Eater Model SRM-225 Won't ...
    ? 2:50
    www.youtube.com/watch?v=uFN82KDj3a8
    Nov 1, 2013 - Uploaded by mountainbikekayak So this is Part I of showing it want start but adding prime it wants to. Part II will show replacing the fuel filter did not fix it and then replacing the ...
Sep 16, 2015 | Echo Garden
I have a problem with an Echo-SRM 310
wrong primer bulb installed have to get right one this one not letting fuel come in
Nov 10, 2012 | Echo Garden
I cannot remove string holder from my Echo weed eater. I push down, turn it to the left, but it will not release.
hi jhhorn, don't push down while turning. just turn it till you hear a click then pull it straight out
Jul 18, 2011 | Echo Garden
Echo srm-210 weed eater will not run at high rpm, have new fuel lines & filter, new air filter, new carb. What the hell !!!!
If everything is new than something is out of adjustment. Try readjusting high RPM needle valve if it has one. Go to smalleng.com and look for tutorial or you tube has a lot of interesting tutorials on this kind of thing. Good Luck...
Jun 04, 2011 | Garden
Troy built weed eater won't feed line
Check the size of the line,(OD), make sure you are using the correct size, sometimes cheap line will be problematic, also, you said you are re-stringing it, try a new batch of string, the old string inside the hub can get chaffed and will stick to itself...
Aug 22, 2009 | Troy Bilt Tb70ss Gas Trimmer
Need to add new string to a weed eater xt 12
    For manual go to;
    http://www.poulanpro.com/poulanpro/manualSearchPrepare.do;jsessionid=332BA6FC1EA2792C79A0A463204716AA
    Preparation Instructions
  1. Press the lock and rotate the spool counter-clockwise.
  2. Remove the locking ring if your weed eater has one.
  3. Take off the automatic feed button.
  4. Wipe away any debris.
  5. Push down on the spool to release the locking tabs.
  6. Remove the spool from the chamber. Restringing the Weed Eater
  7. Feed the line into the lower deck, traveling the line in an upside down J fashion (almost like sewing on a button but do not tie off the line). This secures the internal end of the line.
  8. Wrap the line following the directed arrows. Do this until it wraps to the depth of the chamber.
  9. Secure each of the lines into its own upper and lower deck grove settings.
  10. Install the spool back into its chamber.
  11. Pass the lines into the left and right holes and snap the spool into place.
  12. Once the spool is in its sleeve and fed into its left and right eye holes, pull both ends simultaneously.
  13. Reinstall the locking ring if necessary.
Do it yourself repair: common repairs for a weed eater Amazingly, weed eaters are one of the simplest yard tools to take care of. One of the first things you should do to keep your weed eater in good condition is to clean it. It is important not to clean your weed eater with water or gas, which may destroy the engine. The best, and easiest way to clean it is by blowing off dirt and grass with an air compressor or a leaf-blower after every use. The next most important thing to maintain on your weed eater is string. When the string gets low you can remove the lower part of the head (the part that the string comes out of) by pushing in slightly and turning the head counterclockwise. Cut the new string no shorter than 6 inches or the weed eater will not advance the string properly when in use. Thread the string back though the guides, making sure to follow the arrows on the guide. If the string is not put through the guides the right way, the head may pop off during use. Next, replace the bottom of the head by pushing and turning clockwise. You can totally skip this step by buying a string replacement cartridge. Though it is much more expensive, it saves you the trouble of having to restring your weed eater yourself. window.google_render_ad(); If you find that the head of your weed eater is worn on bottom or hard to get off to replace the string then it is time to replace it. This can be done very simply by unscrewing the two screws at the top of the head and slipping it off. Then, just slide the new one on and tighten the screws. After a few months of use, you may find that your weed eater is losing power or that it is making a strange lower pitched noise. This may be caused by a dirty filter. To check, unscrew the knob or wing nut on the carburetor. Inside you will find a small square screen, this is the filter. If the filter is gray or black then it is time for it to be cleaned. The easiest way to clean it is to blow it out with an air compressor. It can also be washed with plain water, but you must let it dry before placing it back into the carburetor. Once the filter is white or only light grey it is ready to use again. Always make sure to mix the gas and two-cycle oil in the proportions that are listed in the weed eater’s manual. Never use anything but two-cycle oil, normal car oil will not work and will damage your engine.
Jun 01, 2009 | Garden
Echo Rapid Loader, Trimmer Head Logo
2,153 people viewed this question
Top Echo Garden Experts
Jim London
Jim London
Roland W VanLue
Roland W VanLue
colesmowers
Are you an Echo Garden Expert? Answer questions, earn points and help others
