Question about GE Tritonr XL GSD6260JCC Dishwasher
Kenmore Elite Drawer Dishwasher leaking
I have a 2 year old Kenmore Elite Drawer Dishwasher (Model # 465.1334) that is leaking. The bottom drawer leaks out the right side of the drawer and the top drawer leaked so much the other night, that the water was going into the basement.
  • Anonymous Mar 19, 2014
    leaking
  • GE Master
  • 43,501 Answers
Here is a tip that I wrote about dishwashers and them leaking.
Leaking Dishwasher
heatman101
ppi
Posted on Sep 29, 2010
I have a Kitchen Aid 2 drawer dishwasher and its about 2 years old. My problem is the top drawer will not drain during wash cycle. The bottom drawer drains fine. model number KUDD03DTSS 10
You may have clogged pump to the drawer. open drawer, lay on your back under the dish drawer, removed the black cover (3 screws) remove 2 screws to the pump and allow the water to drain out into a bucket or bowl. make sure the pump can turn easy. Reassemble and test unit again. If fails, replace pump.
Pump
I hope this helps, good luck
I’m happy to help further over the phone at https://www.6ya.com/expert/gere_bf68e6055dd61249
Aug 14, 2011 | Dishwashers
.After running my dishwasher on eco/fast cycle,
If the dishwasher is completing the wash cycle without any problem then the suds can occur either because you not using correct detergent. This model does not tolerate the tablets. You have to use the powder.
Water remaining in the bottom of drawer is linked to drain hose either blocked or not looped high enough under the kitchen sink.
I would suggest check this document for correct installation.
Nov 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
The bottom drawer is leaking
replace the pressure switch to stop the flow of water that is the cause of overflowing
Jun 04, 2010 | Fisher and Paykel DD605FD Stainless Steel...
Our two drawer dishwasher model 603dd was working - it showed the "flood button" and then the power cut out and now there is no power to it. Its two years old. Id it worth fixing?? id there anything we can...
I am assuming one of the drawers has caused water to leak into the base of the dishwasher cabinet
Disconnect the mains power connection.
Extend the bottom drawer out as much as possible. Use towels and hair dryer to dry out the base - especially the flood switch that is located towards the back middle of the base.
Leave it open until the moisture disappears. Reconnect mains power and try to start one of the drawers.
The water can leak due to kink or crack in hoses or simply too much foam from detergent.
Hope this fixes the problem - hopefully nothing to replace.
Feb 17, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 flood keeps going off all the time on the top drawer and every other time on the bottom drawer. About 3 years old. No hose leaks that we can see, not flood switch any ideas?
About 3 years either the lid seal is going bad or the actuators had a problem. These things prevent the seal from properly seal on the top of your tube then causing a leak to the bottom hosing of each drawer. If you pull out the tube you can see the bottom housing is wet. Based on what you described, I can see the bottom is on the top drawer. When it leaks so much, part of the leak is coming down to the lower one. The flood at the lower bottom housing is less then from the the upper one.
Nov 10, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Kenmore Elite bottom freezer drawer won't shut
Has something fallen behind the drawer, and is preventing it from sliding back all the way? Remove the drawer by pulling it all the way out and lift it up and out. Look for anything that has fallen back there.
Dec 31, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
How can I fix my Fisher and Paykel DD 6031 Dishwasher? its leaking
I have Fisher & Paykle DW DD603-SS (5Y old)
The upper drawr started to leak H2O out and in to the bothom drawr???
What is the problem and also please what is the solution?
Thanks, JB
Jun 23, 2008 | Fisher and Paykel 24 in. DD603H W Built-in...
Kenmore elite fridge crisper drawer freezing stuff
If you have a side by side model you need to look at the refrigerator compartment wall on the left of the bottom drawer and move the slide control to the warmer/fruit/vegitable setting instead of the meat setting.
I hope this helped. Please rate my help or ask for more help please. supertechks
Apr 05, 2008 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
GE Tritonr XL GSD6260JCC Dishwasher Logo
1,521 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
