Question about Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range
Thermador rdss30rs xlo burners don't light and right side burners don't light either. can light right side with lighter. while burners are on igniter spark continously.
  • Anonymous Mar 22, 2014
    XlO burners when shut off will not stop clicking noise continues
  • Anonymous Mar 28, 2014
    Left XLO burners are fine. RF burner sparks a few times but no gas flows and there is no flame. RR burner does not spark but the gas flows.
    Scholar:
  • 74 Answers
IF THE BURNERS DO NOT IGNITE
• Are the burner caps properly aligned and seated in the burner bases?
• Are the burner ports clogged?
• Is a fuse blown or is the circuit breaker tripped?
• Is the manual shut-off valve closed, preventing the flow of gas?
Posted on Jan 05, 2011
  • Edward Rico Aug 30, 2011
    The problem most likely is the control board with the display unit. If the power was out, then thre will be no spark or the display will be off. The right burners are manually operated and are independent from the control board and can be lit with a barbeque lighter. On older units the part number 486752 is discontinued, the only solution is to remove the part and find a place in the web where they can repair it.. I have found two places for repair, one in Ontario Canada and one in Texas. I'll keep on looking.... I hate whe the manufacturer discontinue essential parts on a range so expensive. I guess that's life LOL
XLo burners keeping clicking but don't light after the initial lighting
Electronic igniters go bad and they don't work well if wet. Make sure yours are dry and change it if it still doesn't work. If the burner lights with a match, gas is getting to the burner. If it doesn't light, have the line checked for a blockage.
Aug 17, 2014 | Thermador Cooktops
PC366BS no spark on two burners
Pots for the Thermator XLO gas burner can be repaired for good and you can save $200. I fixed them for two of my friends and my own pair more than year ago. Please email me (primorec@sbcglobal.net) for more info.
Jul 16, 2014 | Thermador Cooktops
Ge monogram ZGU366LPSS one burner does not light up
It will light with a lighter just not the igniter which means the igniter is not working, sometimes they crack and run to earth, remove the top and turn off the lights you will see it sparking where it's running to earth.
Mar 09, 2014 | Thermador Cooktops
I have a 36" Thermador
Sorry to read about your problem, I hope this helps you out.
you must have a bad control knob
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 20, 2010 | Thermador SGS36GS Gas Cooktop
Thermador Burners Won't Light
have you replaced the igniter the same as the specs needed to be installed..?
Jun 20, 2008 | Kitchen Ranges
Jenn-Air part RI302 4 pt gas re-igniter with flame rectification tytronics #Z21-20 and 7431 PO38-60
We had the same problem on a Thermador cooktop with the same RI-302 ignitor. Turns out it was one of the switches that sits on top of the gas valves. These switches cause the ignotor to fire when the valve is turned. In our case, one of the switches had malfunctioned and was "always on" causing the ignitor to continuously fire.
Oct 29, 2007 | Jenn-Air JJW8530C Expressions Collection...
Igniter issue - some do not turn on other do not turn off
I would try cleaning the burners. You can purchase cleaning brushes made specifically for this purpose and they work like a charm.
Sep 25, 2007 | Thermador PC366BS Stainless Steel Gas...
One of the Burners does not light.
I have the same problem and just took the cooktop apart to investigate. I disconnected the solenoid lines from the simmer controller (that is located under a metal guard to the right side under the burners) and checked them with an ohmmeter. It reads an open circuit, which suggest the solenoid is bad. When I turn the control knob on, I also read about 100V DC on the corresponding solenoid terminals of the simmer controller. I was surprised it was that high for a DC voltage, does anyone know if that is correct? I would hate to spend $90 on a replacement solenoid valve and then have it blow because the controller is putting out too much juice.
Dec 15, 2006 | Thermador RDDS30 Dual Fuel (Electric and...
Open Questions:
See all Thermador RDDS30 Dual Fuel (Electric and Gas) Questions
Thermador RDDS30 Dual Fuel (Electric and Gas) Kitchen Range Logo
639 people viewed this question
Top Thermador Kitchen Ranges Experts
Dan Webster
Dan Webster
Colin Stickland
Colin Stickland
Are you a Thermador Kitchen Range Expert? Answer questions, earn points and help others
