Question about RCA L32WD12 32 in. LCD HDTV
RCA L32WD12 32in. HGTV LCD Television
The tv comes on and powers up to picture and sound. Everything is fine for 5 minutes. The tv then shuts down. Within a few seconds I am able to turn it back on and it will stay on for 5 minutes and then shut off.
  • 5 more comments
  • splash007 Mar 03, 2008
    Tv stays on for 1 hour then shuts off! Then 20 minutes and shiter each time? It seems like I have too power up the set for an hour for it to play for an hour?
  • Anonymous Mar 31, 2008
    The TV was working great for a year then all of a sudden the sound went out one day. So I turned it off and back on and everything was great! Now the video and sound turns off at random times. I notice it more in the morning time than in the evening. Turn tv off and wait a bit and turn it on and it works again.
  • gary12 Jun 20, 2008
    RCA L32WD12 a little over a year old the sound goes off then picture disappears. Turn off tv then back on runs good for a few minutes then repeats. Does RCA have a recall on this Item.
  • donnawlthr Mar 01, 2009
    tv turns off after 5 minutes of operation, able to turn back on , then turns off again after 5 minutes, sleep timer is off , removed remote from the same room, isolated tv in darken room, problem persist. thanks wllm ps tv approx 1.5yrs old
  • walladuece Apr 03, 2009
    I have the same problem tv turns off or picture goes blank and turns to a green screen or it will go blank an a half scramble different channal will appear with no sound its frustrating is there a recall on this tv
  • Anonymous Mar 19, 2014
    television powers on however no picture, do these have a picture tube
  • Anonymous Mar 23, 2014
    Tv turns on for about 10 seconds and the sound stays on but no picture
I had the same problem happen this afternoon, so I took it apart, and the source of the problem is the key controller panel (behind the buttons). It's held in place by 2 screws, if you take the case apart, which is literally only 15 or 20 screws, and then loosen the 2 screws holding the key controller panel on, and then use a small screwdriver to space it out from the button caps. Tighten the screws, and put it back together. Just be careful not to let it go too far to the other side, or you'll have a problem with the menu going on and off at random, which is just as annoying.
Posted on Aug 01, 2008
I have a rca hdtv L32WD12 a few minutes after turning it on no buttons works on the tv or the remote
Posted on Sep 20, 2011
Tv screen has gone black but still have sound when you shut the tv off and turn it back on the screen comes up but it flashes and goes black again
Hi Bob, The link below is a YouTube video showing how to fix a RCA television(DIFFERENT MODEL) NO picture GOOD sound, Also there's videos down the right side of the link that may help as well........CHEERS..
RCA 46LA45RQ tv repair No picture no power troubleshooting
May 01, 2016 | RCA L46WD250 46 in. LCD HDTV
I have a LG 42LB1DR LCD TV that comes on with picture for about 5 minutes and then the screen blanks out and the sound quits. I took the back off and blew off the heavy dust on the transistors between the...
There is 4 capacitors on the power board that need to be replaced. I have fixed 2 of these in the past now, with the same problem. They are green in color.
Oct 26, 2009 | LG 42LB1DRA 42 in. LCD Television
52 in sony tv plasma i turn it on an it comes on
Sounds like the lamp is burning out, hopefully it's a replacable type.
Mar 29, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
RCA TV, model number 32V550T. No picture but sound is fine.
this sometimes is quite simple to fix as it cud be a dry joint on the circuit board where the tube motor sits.
or it cud be the tube is on its way out, which wud be cheaper to buy a new tv rather than have it fixed
Feb 24, 2009 | RCA 32V550T 32" TV
Picture & sound shuts off
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Oct 06, 2008 | RCA L32WD14 32 in. LCD Television
Replaced convergence fuse tv worked then shut down
Sounds like the convergence power supply is defective. If you need more info let me know
Apr 29, 2008 | RCA HD52W59 HDTV Projection Television
No picture sound is fine
tv comes on then turns blue at that time it shuts down. The power is on and then it blinks 5 times!!!
Apr 27, 2008 | Sony KP-65WS500 65" Rear Projection...
RCA P52937SG
ch over the power supply for the conv this is the stk730-020 that run your conv
Apr 15, 2008 | RCA P52937 52" Rear Projection Television
Tv turns off after it gets hot
RCA TV's of that vintage are known for having bad solder joints in the power supply stages and they become very remperature sensitive.
Mar 17, 2008 | RCA P52937 52" Rear Projection Television
RCA L32WD12 32 in. LCD HDTV Logo
927 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
