Question about Samsung DLP HL-P5663W 56" TV
Sound problems The sound on my tv is going out, how com i cant find replacements?
Panasonic tc-14e1m .. this tv no sound some channels have sound not clear. . Sound system cant change only have 'I' .. cant change ...
That might be the problem. Try to select the sound system to "Auto". If you can't, it main system memory IC is faulty, and should be replaced. If you wish to get some details; check the site linked here. Pull up older posts.
Sep 30, 2016 | Panasonic Televison & Video
Im using innodv smarttv i only get clear pictures but sound problem,i cant get sound i only hear sound like a radio without signal,i get problem when i use tv.help me,i cant get sound when using tv
Check the system setting. That is, if your country adopts PAL system, and you have set the TV to NTSC or SECAM system, this kind of fault can occur. Set the system settings to "Auto". This will solve the problem. Refer its user manual for details.
Aug 19, 2015 | Televison & Video
Hello i contacted you last week regarding a sound and channel changing issue with my tv. Sadly this issue has not bern resolved. I have a toshiba text tv and it,s connected to a hitachi digibox as i only...
Annamaria:
It sounds like you have not yet simply married your TV to your digibox (which I assume is a cable box) with the proper code. Go to Hitachi.com for the code.
Apr 11, 2017 | Televison & Video
Cant get a sound
there are so many reasons why your TV won't bring out sound. You need to troubleshoot first, in order to get to the root of the problem, before a solution can be proffered.
First, connect a DVD player to the TV, observe if there is going to be sound. If there is still no sound after connecting the DVD player to the TV, proceed to the next step. "The reason why I asked you to connect a DVD player to the TV is to confirm if the problem is simply not from the audio cord connected to the TV."
Second, get an headset, connect it to the earphone jack of the TV and observe if there is going to be sound. If there is no sound, then it is glaring now that your TV is having a defective sound card/IC that's why it is not bring out any sound. (Note that connecting an headset to your TV is optional because not all TV's has a space for headset). "The reason why I asked you to connect an headset to the TV is to also confirm if problem is not from the TV speaker. Though TV speaker problems are rare but sometimes, the TV speaker might be defective or the speaker wires may have loosed contact or cut into two, due to one reason or the other. But if the headset doesn't bring out any sound from the TV, then it is not so."
If none of the above seems not to be the cause of the problem, then the above troubleshooting has confirmed that the TV has got a defective sound card/ic. The sound IC/card of the TV has to be replaced for the TV to bring out sound again.
To be honest with you, replacing or fixing the sound card/ic of your TV requires the ability or experience to do so.
Now, if you are convinced you can fix or replace this yourself, please reply so that i can help you further. And make sure you troubleshoot first, before getting back to me.
Regards.
Sep 27, 2011 | Akai LCT3201AD 32 in. LCD Television
Tv stays on but there is no sound and you cant change the channels what is the problem
Regards.
Jul 10, 2011 | RCA D52W20 52" Rear Projection HDTV-Ready...
Cant get sound from tv on speakers.
lost remote and cant get sound from ks3102
Dec 16, 2009 | Koss KS3102 System
I cant see anything on the tv and i have 'the ring of fire' HELP!
your 360 is suffering from the "red Ring of Death", and will need to be sent away for repair or replaced outright.
Jun 12, 2009 | Microsoft Xbox 360 Console
5.1 sound from Sky hd through LG TV
link your optical cable from your HD box to your surround sound.
Then if you go into your HD services menu, press 4 then go to sound make sure its set to Dobly D
That should sort your problem out
Cheers
Little Dish Fitter
Feb 24, 2009 | LG 37LC7D 37 in. LCD HDTV
Tv tcl-14175 no sound on channels but ok on audio video mode
Hi
The first problem was always standby mode.... get back the original eprom IC 24CO8WP in to the PCB, then find the original remote control of you TCL Tv tcl-14175 then you power On In the Remote control while your TV is in Standby mode! then you see your tv is going ON... Because your unit is in Child lock Mode....
thanks!
Nov 21, 2008 | Samsung DLP HL-P5663W 56" TV
No picture after overnight off
which model
http://www.fixya.com/support/t293971-37_polaroid_lcd_tv_turn
May 07, 2008 | Polaroid FLM-3734B 37 in. LCD HDTV
Samsung DLP HL-P5663W 56" TV Logo
116 people viewed this question
Jerry Greenberg
Jerry Greenberg
