Question about Sharp AR-M208N Copier
My copier AR-M208 won't pick up paper from tray 2 It starts too then nope it says its jamed but not really, we open side door and tray close both then it will copy one or two pages the stop again
  • fblanchard Jun 30, 2009
    thank you so much, can plain rubbing alcohol be used?
    Scholar:
  • 175 Answers
It may be that either the feed rollers in that drawer are dirty or worn out and need replacement. You might also want to ensure that there is no dogeared paper in that drawer. Meaning that the edges of the stack are all nice and even, no corners bent over.
Posted on Jun 29, 2009
  • M. Colin DeWitt
    M. Colin DeWitt Jun 30, 2009
    Alcohol will clean it but it'll also dry out the rubber, Scrubbing it with a damp cloth (water) works much better and won't dry it out.
I installed the Sharp ar-5220 and received an error message. CH keeps blinking and does not allow me to press any buttons.
Make sure your toner catridge is installed properly then open the side door and front door , and close it properly the code CH means your machine door interlock is open. Vote for this rate this
May 27, 2011 | Sharp AR-5316 Advanced Digital Imager...
The printer is saying that paper was misfed and it says that procedure for clearing misfed paper is shown inside the front door : C and A
First you have to open all the doors see their are two papers are get jamed in side, one paper at C section that meens in fuser module and another one in lower papaer tray section you can find the nob of C when you open the front door please rotate that the C jamed papaer comes out and other one open lower right door op tray-2 and tray-3&4, you can see the Ajamed paper remove that and close all the doors if problem exists call expert-thankyou
Dec 15, 2010 | Ricoh Aficio 2035 Copier
Ar-m208 is displaying h2-00, how do clear this from memory or do a full restart? it started as a paper jam, than as it was booting from turning on i opened the paper tray it shut off and displayed this...
H2 error is heat roller over temperature, try pressing the "#" key then "Interrupt" key then "C" key then "Interrupt" key to get into simulation mode and enter 14 and press start the follow instructions on screen (should be press ok). This will reset the code and restart the machine. When the machine restarts if the error was not mechanical the machine should go. If not you have one of two most likely problems; you need to reset the thermal cut-out on top of the fuser unit or the fuser lamp is blown.
Oct 18, 2010 | Sharp AR-235 Copier
I have xerox workcentre xd105f, can't make copies,paper jam
P will flash on the screen when the paper tray is empty, paper misfeeds or the paper tray door isn't closed all the way. Make sure both (if you have 2 paper trays) are loaded, that the paper isn't folder and wrinkled, and ensure that the tray doors are closed firmly. Then hit start on the workcentre to continue any unfinished jobs.
Jun 19, 2009 | Office Equipment & Supplies
Got a paer jam and don't know how to open cover,
Turn of the printer, and do not close any of the tray or doors before all of the jams are cleared.
1). remove the paper from paper tray, removed the tray and remove the jams.
2).open the front cover and removed the toner cartidge assembly, remove any jams in this area, and behid the toner cartridge asembly.
3).left the flap at the front of the printer adn remove any jams heneath the lap.
4).Open the rear exit and remove any james.
close all covers and reinsert the paper tray and turn on the printer.
May 13, 2009 | Dell 1700 Laser Printer
PAPER JEM WHILE PRINTING. I NEED A HEIP TO REPAIR THE PRINTER.
first, if thare any paper is jamed in the paper tray, pull the paper stright out. take out the remaining paper. close the paper tray.
opne the front cover pull out the toner cartirdge, remove the jamed paper.
open the inner door (where the paper exit). make sure there is not paper jamed it.
close the front door. if any paper jamed inside of the machine, it should automatically eject it out.
Note: reset the printer by opening and closing the front door.
Apr 03, 2009 | Samsung ML-2510 Laser Printer
KONICA MINOLTA BIZHUB C350 WITH ERROR CODE C0960
Check your bypass tray, the tray is on the right side of the machine, the tray flips out for legal and 11x17 paper sizes. Check that there is nothing jamed inside, code says that the tray can't lift. so check for anything jamed inside down there. As to reset the code open then close the front door where you put the toner. Turning the machine on and off will not reset the code. but open and closing the front door will clear about 80% of the service codes.
Apr 02, 2009 | Konica Minolta Office Equipment & Supplies
Upon power up error code CH is displayed , with second drawer
The steady CH indicates an open right side door. Being that the tray 2 is lit up it could be the side door for the second tray and not the one on the main body. Pull tray 1 and 2 out completely and make sure there is no paper stuck in the machine behind where the tray goes. Double check that both side doors are closing properly and that nothing is broken or missing in that area.
Mar 21, 2009 | Sharp AR-5316 Advanced Digital Imager...
Minolta cspro ep2010
Do you have two trays or four trays for the paper? If you have four and the display is showing the bottom door is open... turn the copier off and disconnect the bottom two trays and turn it back on..... Just use the top two paper trays.. Or the problem is that a acturator is broken off the side door, look for any broken pieces of plastic. Also, recheck for any jamed paper left in the copier.Good Luck
Jun 12, 2008 | Office Equipment & Supplies
Paper jam in tray 2
the most common problem for a paper jam in tray 2 is that either the pick up rollers and separation pads are worn or that there is something stuck to the rollers that transfer the paper up through to trat 1.(most commonly from if people have been printing on stickers/labels) just eyeball it to see if anything looks to be stook and try wiping it off. DO NOT SCRATCH IT OFF as this will only make things worse!!!
Sep 05, 2007 | Office Equipment & Supplies
Sharp AR-M208N Copier Logo
125 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
