Question about Nextar MA933A MP3 Player
When i plugin the headphones it makes a mettalic noise the guitar, drum and the back ground louder than the words.
    Problem Solver:
  • 9 Answers
Either the headfone hole is broken or you have to go to menu, equalizer, normal
Posted on Jun 29, 2009
MY FRIGIDAIRE MODEL FAQE770KW0 DRIER IS MAKING A LOUD NOISE AFTER IT GETS HOT
you might need a new roller on the back of the drum, As for being louder when warm it's the part getting hot from Friction that is wearing the roller or roller pin down.
Oct 09, 2014 | Frigidaire FAQE7077K Electric Dryer
Buzz coming from elec. guitar pickups only when using Aviom and headphones
It is a definite pickup grounding issue causing hum/"buzz" which diminishes when touching strings. Check the impedance of cable jack inputs and cable which should be 1/4"mono input/output jacks) . A personal preference but effective is to NOT run guitar direct into mixer but through an external amp w/ a headphone out jack . Noise gating/preamp filter also will help eliminate the "buzz"/noise from pickups. It is unfortunately the nature of the "electro-magnetic" beast when it comes to electric guitar pickups .Hope this helps.
Feb 23, 2014 | Aviom A16ii Personal Monitor Mixer 16...
Can I connect guitar to my Harmon Kardon receiver
Sorry. They are not compatible. The headphone jack is an output but you need an input for a guitar or bass. You will certainly damage the HK if you continue. There are no compatable inputs on the HK. The inputs are meant to be used with a 300mv output device, such as a CD or DVD.
Oct 02, 2013 | Harman Kardon Audio Players & Recorders
How to play with headphones
If you have a preamp output jack or a headphones jack on the back- those will work. They should interupt the speaker if you are wanting it for practice purposes.
if you do not have those, and want to add one, tap at the control grid of the Phase inverter ECC83/12AX7A which should be common grid to the final preamp tube, which should also be an ECC83/12AX7A and locate the coupling capacitor so you can tap ahead of it with a .1 microfarad 600 WVDC capacitor or one that matches the factory capacitor in series to the new jack, with shielded audio wire/coax to the new jack location, at the tip and the coaxial jacket should go to chassis ground at both ends. The grid is either pin2 or pin7 depending which way they chose to wire it. I do not have an Orange Amp schematic in front of me.
If you want to risk noise at that location, make it interuptable so when the headphones are removed, the circuit completes to the N/C contact of the headphone jack (which opens/opened when headphone plug is inserted.) back to the grid terminal. with that terminal connected by shielded wire back to the grid.
Instead of adding a capacitor, you can use the factory capacitor, just mount a terminal strip next to the phase inverter and move the capacitor to that new terminal tab and the wire to lead to the tip together on that ear, and the return wire from the headphone jack goes to the now vacated tube pin terminal. .
Look to see if on of the filament/heater pins is grounded to chassis- if so, just ground the sleeve contact of the jack. If it is not, determine which pin is closest to chassis ground potential and run the sleeve contact over to that pin. could be either 4, 5, or 9 Make sure to use an insulating headphone jack.
EL34 outputs should never be connected to a headphone.
Feb 06, 2012 | Orange Amps Orange RK50TCMKII212...
Is there any way to make the hb15tsk louder acoustically,I love the guitar.
In a word, NO. Changing type of strings might make it a bit louder, however the sound quality would drastically change if it does. Best to leave alone... Get a small amp, portable battery if needed... OR there are headphone amps that are designed to be used for practice.
Sep 02, 2011 | Washburn HB Series HB15CTSK Electric...
When i plug in my headphones, regardless of what type, i only get sound in the left side. How fix?
This is a long shot, but it may be that the output jacks to the amp is intended for balanced TRS cables and if you plug in a guitar cable TS type cable (tip-sleeve) it may ground out the right side headphone signal.. Remove the output cables if you have them and test your headphones.
Check in your user manual for things related to "panning" as well.
Aug 27, 2011 | Simmons SD7PK Electronic Drum Set
Bussing sound comes out the tube,even when it it connected correctly
Make sure you have the correct power adapter, not a substitute. Make sure your guitar is outputing enough... You LIKELY will need a guitar that has a preamp in the guitar, (not a passive pickup guitar). This device is nothing more than a small amp that drives a speaker which the sound travels up the hose. If your guitar creates a buzzing noise, then this device will do that too... Plug a set of headphones directely into your guitar to verify the sound is clean... NOTE, only one side of headphone will have guitar in it if the headphones are stereo type.
Jan 09, 2011 | Rocktron Banshee 2 Guitar Talk Box Talkbox...
Fender Frontman 65r Grounding Issues
It could be a grounding problem with your inputconnector.
There could be a bad connection between the jackinput and the faceplate/chassis.
HNY Gerard
Dec 05, 2009 | Audio Players & Recorders
Problem using Kaoss Pad for synths.
Okay, maybe this is rude, but TOTALLY ignore Musicaldude's solution, if you haven't already found out the ugly way. Boosting the signal that goes into the KP will just make the input LED light up red and you'll hear digital clipping [gross] and eventually hit a ceiling of all-crappy-staticy-noise and no real guitar left. Having it in the FX loop, and the Headphone-out workaround are smart moves already, except the Headphone out adds noticeable noise/hum vs the usual outs. But to help close the gap between your guitar's volume and the miniKP's internal synths (and program 63 and 65's feedback noizes, which build up even louder than the synths) unplug one of the RCA plugs from the KP's OUTput, pick one, left or right, whichever. You'll notice this gives you a guitar volume boost. BUT its still not enough...the synths and 63 and 65's feedback are still speaker-blowingly loud. Check the manual, it says you can adjust the wet/dry volume by holding down Tempo and Preset A together, then turning the knob and picking 1 thru 99. Make sure you're on the synth setting you want to use already. Do this thing. Play the synth with your finger, while you lower the number with that knob. Stay around 50 if you've got the one RCA plug dangling, around 20 if both are in. Whatever you think matches your usual playing volume. When its where you like it, hold the A or B button (wherever you want to save this) down and click Hold, this will save it onto that preset button. Now from now on, NEVER use 63, 65, or the synths if you're on whatever preset you DIDN'T just save. i.e. If you chose preset B, from now on you can just tap preset B and it remembers your volume adjustment from before, voila, normal-volume touchpad synth. But go back to preset A for every other effect, or you'll barely be able to hear the FX. KORG should've given us more preset buttons to save onto. Godspeed. I've never seen this site before, but I have this pedal, and experienced the same b.s. myself. Now I'm down to one preset button and quick knob-turning. Whee.
Aug 07, 2008 | Korg Mini Kp Kaoss Pad
Nextar MA933A MP3 Player Logo
29 people viewed this question
Top Nextar Audio Players & Recorders Experts
 Grubhead
Grubhead
topcat7736
Level 1 Expert
Joseph Hoffmann
Are you a Nextar Audio Player and Recorder Expert? Answer questions, earn points and help others
