Question about RCA D52W20 52" Rear Projection HDTV-Ready Television
HYUNDAI WTP-20 I have a Hyundai TV set WTP 20 and after I opened the back cover to try to repair the broken main power button, nothing happened anymore and with the remote control : nothing nothing nothing and manual use : nothing. help me ! thanks
    Champion:
  • 205 Answers
Replace main power button or seek qualified repair man
Posted on Jun 29, 2009
Problem with a Hyundai HQP421 HR Plasma TV
ur board is fried or almost fried. the price to fix is a lot more than to buy new
Dec 01, 2016 | Hyundai ImageQuest HQP421HR 42 in....
Hyundai coupe central locking problem
it may be a control module issue as well which is also a dealer item..unless a parts store can do it cheaper..(I would honestly go with the dealer tho)
Dec 22, 2013 | Cars & Trucks
Need a code for a hyundai television serial number 6011604481
HYUNDAI HU-TV2121 processor N403 KALORA HHEN16MD01.Videoprotsesor LA76810A - the very bottom hidden button (right of the circuit), click once highlighted FACTORY. More P + and P-switching options.
HYUNDAI C2910, C2519, C2988
1. Set the volume -0
2. Press the remote button "MUTE"
3. While holding "MUTE", press "MENU" on the front of the TV.
4. On the top right corner will light up the letter "D", and in the left corner shows an adjustable parameter and its value.
5. Pages menu change button "CAL"
Switching parameters conducted green and red buttons on a blue field panel. Change made a yellow and blue buttons on a blue field.
HYUNDAI H-LCD2000
To enter service mode simultaneously press "MENU" and "STANDBY".
Press "MENU" again.
HYUNDAI, ITT 29M03 C2131 chassis CPU M37160M8-064FP
In the main menu code 6, 4, 8, 3.
Tools submenu contains the switch to the next of which is done by putting 6, 4, 8, 3.
HYUNDAI 359, 387, 8FHIFI, CB5373Z, 6578F processor CCU SEL04 / SEL07A
Mode 1: Close contact in the hole near the keyboard and just press "S"
Mode 2: Close contact in the hole near the keyboard and just press "S" again and click on contact. Exodus - LOAD.
HYUNDAI processor SAA1293-03-03 SAA1293A
With remote control TV "Horizon" graphics without clicking "SERVICE", the indicator shows a CH, a paz-click on 'appears OP, then choose the volume of registers numbers "1-4" and numbers "1-9" change bits. Then click on "Memory" (you can also lock the pins 15 and 23 in the control circuit SAA1250). Exodus - POWER OFF.
HYUNDAI
chassis CCU11 - "•?" (C) (H)
Chassis CCU12 - close contact in the hole near the keyboard and just press "S". Exodus - LOAD.
HYUNDAI chassis M1, ITT, NOKIA, SALORA 6390, 7190, MV4000, PL14 24 101 852 SAT SOLI, 882 SAT SOLI, 885 SAT SOLI processor CCU-SALO-07 (CCU20XX)
entrance "C"> "*"> "O / V"> "#"> "M". Exodus - "power".
HYUNDAI chassis EUROSTEREO-1. DIGIVISION 1963 .. 2, 1971 .. 2, 2 .. N6 processor NES3-... NES2-..
Log "-/--" "MENU" "TV" - for a second. Exodus - POWER OFF.
HYUNDAI chassis STEREO PLUS. 5575SFN, 28T7 processor ST92T93
Entrance - "i" "M" "P +", output - TV.
HYUNDAI 3875EX DIGIVISION
Gun "AV7 universal" fully fit.
Sign in service "1-/11. (Button with painted upper corner). TV must be turned on and display a feed.
Recommended initial value: V.AMP-027. V.LIN-038. S.COR-020. V.POS-023. H.POS-041.H.AMP-022. P.TILT-013. P.AMP-024. P.CORN-007. GREEN-032. RED-032. BLUE-032. V.BRE-005. LUM.DEL-000. AUDIO-032.OPBYT1-002. OPBYT2-064. OPBYT3-000. PRLOSK-000. RESERVE-000. Writing in memory - click "E".
Memory 24c08 can put a clean, turn on TV it propyshe processor itself.
from electronics-planet .blogspot
Jun 12, 2011 | Hyundai Televison & Video
OK, following your advice of March 9th I got a new lamp from Mitsubishi and replaced it tonigh in my Mitsubishi rear projection model WD-62725 TV. The old lamp was clearly broken. However I have...
hi,
That sound may from the color wheel. Open the angine, open block front of lamp.
open cover of color wheel and grap it.
mas_baz_23.jpg Rotate color wheel manualy , listen it. If hear fristing sound, means color wheel is bad. Replace it too.
mas_baz_24.jpg Good luck.
Mar 24, 2011 | Televison & Video
Have 10 Broken monitors with simalar problems. 1. Dell e153FPB- Video for 2 seconds than screen goes blank. 2. Dell e153FPB- After 20 mins, Display stops working. 3.Dell e1724FPB-Video for 2 Seconds than...
Pleasec look through my albums so you will know what to look for.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Dell bd: http://www.lcdrepair.us
Apr 24, 2010 | Dell UltraSharp E153FPb 15" LCD Flat Panel...
My remote control for my hyundai lcd tv is broken and the power button on the tv doesnt work either is there a remote that i can buy that will work straight away
try charles hyde and son web site (CHS) or amazon if still got old remote will need model number
if not can find with tv make and model number
Dec 15, 2009 | Hyundai Electronics E320D 32 in. LCD...
RCA 52in. Projection TV D52W19B does anyone
Hello butmommy03,
This is the procedure but first I must warn you. You are dealing with one of the most dangerous parts of a TV The High Voltage anode or the CRT and the flyback transformer. That being said this is what you have to do:
1) unplug the TV from the wall or power strip.
2) take the back of the TV, and find the High voltage trippler and using a screwdriver grounded by a clip-lead to the grounding strip touch it to the exposed metal of the input to the High Voltage trippler.
3) using a soldering iron de-solder and remove the wire from the HV trippler.
4) Once this is done, angle the chassis to expose the bottom of the Deflection board, if this is no possible you will have to remove the deflection board to get a look at the bottom, once this is done and you can view the bottom of the board using a soldering iron and a de-soldering pump you can remove the solder from around the pins of the flyback transformer about 10 pins in all. Then remove the screws that hold the flyback in place. this is the procedure you requested,
However again I must ask you not to do this yourself and to get a qualified TV technician to troubleshoot this TV for you.
Thank you,
Shuttle83
http://www.electron-age-technologies-llc.com
Jun 27, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
2005 Hyundai Tucson
2005 Hyundai Tucson
Battery is fine I had it checked. The Tucson will not start. It will crank and crank but nothing.
Apr 30, 2009 | 2005 Hyundai Tucson
Tv locked; can't unlock with remote even though we have the original manual
I had the same problem with my hyundai hf2215 tv. Hold down the DISP button on the remote for at least 30 seconds and the lock comes off and tv returns to normal.
Apr 27, 2009 | Televison & Video
Hyundai 42" Plasma TV
Try www.hyundai-world.com That is the manufacturers website. Good luck. Ask them if that set can played in the USA without a special power supply.
Nov 19, 2007 | Hyundai HPT-4250 Television
RCA D52W20 52" Rear Projection HDTV-Ready Television Logo
177 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
