Question about Zooper Baby Gear
I need a replacement clip for the center piece that goes in between my babies legs. It is a walk air zooper (?) Where can I order/buy another one. I live in vancouver bc.
    An expert whose answer gotĀ voted for 100 times.
    Sniper:
  • 55 Answers
Try the zooper website. They might have a replacement part you can buy.
http://www.zooper.com.tw/faq.html#9
Blessings!
Posted on Jun 29, 2009
Zooper sport replacement tires
Try eBay for Scooter tires. I've found different sizes there.
Sep 28, 2009 | Zooper CoolZone Sport Stroller
Zooper replacement tires
You can try any bike store they should carry all sizes of tires.
May 28, 2009 | Zooper CoolZone Sport Stroller
Broken front wheels on zooper double stroller
All is not lost yet, Contact Zooper directly to see if this can be fixed before throwing out your stroller.
info@zooper.com 1-888-742-9899 They have an online submission form on their website under the FAQ -"I have an older zooper stroller. How can I go about getting parts or service?" but when I went there, it seemed to be a warranty registration link instead.
Good Luck! from Moms Just Know
Oct 31, 2008 | Zooper Tango double stroller - Red
Kenmore 70 series won't spin
If the washer makes a noise from the front bottom center, when not agitating and not spinning, the motor/gearbox coupling has broken.
closed2a0a669.jpg open7976f3d.jpg It is designed to break, if the load gets enough that the motor may be damaged and is simple (enough) to replace
whirlpoool 285753, parts common to whirlpool roper ge kenmore and about a dozen other brands.
dissassembly instructions vary slightly between models but close enough, some have 2 clips some 3
  • remove screws under trims
  • raise control panel and flip it over backwards
    (note: do not dislodge air tube from level selector)
  • remove brass retainer clips at rear corners
    (note: position for reinstall)
  • remove lid switch connector
  • remove lid and body
the motor and gearbox are now exposed
  • undo bolt(s) holding spring clips to pump,
  • remove spring clips holding pump to motor(note position for reinstall)
  • unto bolt(s) holding spring clips to motor
  • remove spring clips holding motor to gearbox
  • there will be a plastic 3 legged 'spider' on the gearbox, and one on the motor, and a rubber ring with 6 holes that match the positions of the legs
  • remove the ring and spiders
  • take the ring and spiders to the local parts guy and get replacement,
    (Note the local parts guy will have the replacement, it is common to ge, whirlpool, roper, kenmore, new maytag, frigidaire and many others.)
  • use a piece of dowel, to hammer the center of the spider to the input shaft of the gearbox and the motor shaft,
    (note dont hit the legs they break.)
    (note: new spiders have metal center hubs, this is a common failure and the replacements have been strengthened)
  • turn gearbox shaft 1 leg up 2 legs down
  • turn motor shaft 2 legs up 1 leg down
  • insert new rubber ring over gearbox spider
  • insert motor into rubber ring
reinstall springclips
pump
pump springclips
body
control panel
in reverse order to above
gearbox coupling ~$17.00
time ~25 minutes, but I do 3-4/month
Oct 26, 2008 | Kenmore 22422 Top Load Washer
Removing the seat cover to wash
What I did is cut the hole about .5cm bigger (to fit buckel thru) and then resowed it by hand with a strong thread. I would not recomend washing it in a top load machine (it damaged our seat) best would prob. be dry clean.
Aug 02, 2008 | Zooper Jazz Jogger
Zooper walk air tire
You should be able replace it with a generic brand tube from Wal Mart- or any bike shop. Hope this helps!
May 03, 2008 | Zooper GoAnywhere Walkair Stroller
Zooper Boogie Black 2006 Need New Seat Insert
You can buy them on the internet. Hope this helps.
Apr 30, 2008 | Zooper Boogie Jogger
Making my zooper available to 2 children with an attachment
First of all, a heartfelt congratulations! Second, it's definitely challenging having children so close together.
The Zooper Boogie is a good stroller and it's engineered in a VERY specific way to provide baby safety and comfort. It does this by providing a slightly lower center of gravity focused on the rotating single front wheel. This makes it more maneuverable for parents and keeps baby at the center of the swivel. Attaching a second compartment on the front or back of this particular carriage would undermine the engineered balance, tremendously. At least one occupant would suffer from an extended swing when maneuvering that could be more than just uncomfortable, especially if it was extended forward over the front wheel. Some stroller companies might be willing to do this, Zooper doesn't.
The best alternative that they offer is the Tango which is engineered for two. I know that you mentioned that you wouldn't purchase a double stroller but modifying a single might be uncomfortable and possibly dangerous for your little ones. I would recommend against it.
Once again, congratulations on your blessings!
Nov 11, 2007 | Zooper Boogie Jogger
Zooper Zydeco
Our stroller had a similar break, just below the 'pivot point'. I have been in touch with Zooper directly (Dan Slaughter - dans@zooper.com) and had a new piece shipped to us in Toronto for about $20 American. Removing the old piece wasn't too bad, but I did have to drill out the old rivots. I am however having problems reinstalling the new piece, because of the wires contained within the steel frame (which allow the folding function). If you can do without the folding function, you're laughing. That's what I'm considering doing. Hope this helps. Jason.
Jan 31, 2007 | Zooper Zydeco Z344 Jogger
Baby Gear Logo
232 people viewed this question
Top Zooper Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Zooper Baby Gear Expert? Answer questions, earn points and help others
