How can I set the time and correct day on a Lathem 2121 Time clock????
  • 2,237 Answers
This post is for projectors, not clocks. sorry.
Posted on Dec 28, 2009
Why is the time not changing
is it plugged in? maybe the motor has gone out. maybe the a spring has come loose. lots of things can cause this. maybe the exhaust bearing needs lubed lol. try www.gatewaytime.com for service, parts, maintenance, and time clocks.
Aug 12, 2014 | Lathem Manual Clock Time Recorder - 2126
Need to set time on 1500e lathem
Hello
To enter the programme setting mode, you should plug the AC adapter to AC outlet and remove the cover. Thereafter press 'Select' button once. The the clock goes into the programme mode showing "UP Arrow" on the display positioned at "Time"
Function of three control buttons.
'SELECT": You can select the desired programme setting modes by pressing "Select" buton. Selected programme setting mode is indicated by the "upward arrow" mark on the display.
"CHANGE": When you press "Change" button, you can increment the set value.
"SET": You can set the value selected on the display by pressing the "Set" button. Thereafter you press this 'Set" button again, you can return the clock to normal operation mode. OK.
Dec 14, 2011 | Audio Players & Recorders
Lathem 2126 lost 20min over the course of 2 months. Replaced motor...now loses 30 minutes over the course of 1 week?
The motor is going out or the feed pawls are worn out. Upgrade to a TCX-11, they automatically set for daylight savings. www.gatewaytime.com
Jan 18, 2011 | Lathem Manual Clock Time Recorder - 2126
HOW DO I CHANGE THE RIBBON IN THE LATHEM TIME RECORDER 5000E?
send it into Gateway Time Systems in Pittsburgh...they will replace the ribbon, clean and lube it, and make sure the program is up to date for you. they did a wonderfull job on my company's time clock and they barely charged anything. i found them @ www.shop.gatewaytime.com good luck :), Adam
Aug 10, 2010 | Lathem Time Lathem VIS6002 Ribbon...
I have a lathem 1000e and it will not print when the card is pushed in...it will work a couple times then, nothing...any ideas?
Dec 04, 2009 | Lathem Time Lathem VIS6002 Ribbon...
I am trying to set the companies time clock for daylight saving time. Thank you Betty
send it into Gateway Time Systems in Pittsburgh...they will replace theribbon, clean and lube it, and make sure the program is up to date foryou. they did a wonderfull job on my company's time clock and theybarely charged anything. i found them @ www.shop.gatewaytime.com  goodluck :), Adam
Nov 02, 2009 | Lathem Time Lathem VIS6002 Ribbon...
We use a lathem time clock model #pc50 and we cannot locate the manual. how can i download a manual for this machine?
First off, I did NOT have a lamp issue! All I needed was a product "manual" as I could not find the one the company used to have. Secondly, there is no problem to solve; if I would have had the manual, I could have hooked the device up myself.
Thank you for NOT helping!
Sep 14, 2009 | Lathem Time Office Equipment & Supplies
Replacement ribbon for a brother fax machine
yes it does mean that. send it into Gateway Time Systems in Pittsburgh...they will replace the ribbon, clean and lube it, and make sure the program is up to date for you. they did a wonderfull job on my company's time clock and they barely charged anything. i found them @ www.shop.gatewaytime.com good luck :), Adam
Jun 20, 2008 | Lathem Time Lathem VIS6002 Ribbon...
Lathemtime clock 2121 series
This site doesn't have much in the way of Lathem clocks or support. Go to http://support.lathem.com for assistance.
Nov 04, 2007 | Lathem Time Office Equipment & Supplies
93 people viewed this question
k24674
jasbo
jasbo
